Old 09-19-2019, 08:42 PM #16
MrGainzz's Avatar
MrGainzz MrGainzz is offline
MrGainzz will become famous soon enough MrGainzz will become famous soon enough
MrGainzz's Avatar
Winter tires for my 2019 4 runner limited?
I have 3 sets of tires for winter ,summer and overlanding and I bought Nokian Hakkapeliittas R3 with trd Pro wheels for winter.
MrGainzz is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 10:06 AM #17
chef744's Avatar
chef744 chef744 is offline
Real Name: Gino
chef744 is on a distinguished road
chef744's Avatar
Real Name: Gino
I live in Ontario and have been using Goodyear Wrangler Duratracs the last 3 winters and have been using the tires all year round. Zero issues even with the winter we had last year. 275/55/20.
chef744 is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 01:38 PM #18
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Originally Posted by CO-Cygnus View Post
275/55/R20 will fit the limited wheels and opens up more options for you like Nokian Hakka 9s and R3s.
Well yeah, but now you've gone to a way wider tire which is exactly the opposite of what you want for snow tires.
I like the 17" wheel option. Though then you can't brag about your dubs.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 02:50 PM #19
CO-Cygnus's Avatar
CO-Cygnus CO-Cygnus is offline
CO-Cygnus will become famous soon enough CO-Cygnus will become famous soon enough
CO-Cygnus's Avatar
Less than half an inch wider than stock 17s and a true winter tire will be far better than an AT tire with the 3PMSF.
I turned my limited 20s in to winter wheels and got a set of 17s with AT Tires for Spring, Summer, and Fall.
CO-Cygnus is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 07:59 PM #20
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
After running two Canadian winters on my Michelin Premier LTX 245/60R20 Michelin Premier all-season tires (20" Limited rims), I began searching for a second set of OEM alloy rims last summer (2018) to run a set of dedicated winters.
I found some 2018 TRD Off-Road take-off rims with very low mileage at a reasonable price, and then installed Toyo Observe GSi-5 265/70R17 winter tires. Fit perfectly on my 2011 Limited.
The Toyos did a very good job up here in Northern Ontario.
Having a second set of rims removes some of the hassle associated with the seasonal changeovers with only one set of rims. The winter rims may take a beating (corrosion!) if road salt is used on your roads. That is why I decided not to run steelies - they rust far too quickly up here.
Winter tires for my 2019 4 runner limited?-toyo-jpg
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 05:00 PM #21
mauthe's Avatar
mauthe mauthe is offline
mauthe is on a distinguished road
mauthe's Avatar
Built a set this year. Living in Alberta and traveling to mountains often it’s a no brainer. We’ve always had them for the commuter car but added a set on the runner. Hakka 9’s studded
15 4Runner LE
mauthe is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 10:39 AM #22
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Falken Wildpeak AT3W
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 11:59 AM #23
ljhartigan ljhartigan is offline
ljhartigan is on a distinguished road
Mauthe, can you tell me the tire/wheel combo you have there? specifics please I would like to duplicate if I can $.
ljhartigan is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 06:29 PM #24
thecamster21 thecamster21 is offline
Real Name: Cameo
thecamster21 is on a distinguished road
Real Name: Cameo
Newbie here! Just bought a 2019 Limited in nautical blue. What is that mod you did with the front grill? I like it! Looks sharp. Thanks!
thecamster21 is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 06:56 PM #25
MrGainzz's Avatar
MrGainzz's Avatar
Thank you! I replaced the OEM limited front grille with Toyota heritage grille which is what trd pro has.
Old 10-13-2019, 07:05 PM #26
lyodbraun's Avatar
lyodbraun lyodbraun is offline
lyodbraun is on a distinguished road
lyodbraun's Avatar
Either cooper AT3-4s or the ATW which is what I’ve been using all summer they stick great in wet can’t wait to see how well they do in winter...
lyodbraun is offline   Reply With QuoteReply With Quote
Old 11-02-2019, 01:12 AM #27
ryencoke ryencoke is offline
ryencoke is on a distinguished road
How'd you black out the lower chrome bar below the heritage grill?
ryencoke is offline   Reply With QuoteReply With Quote
factory , size , tire , tires , winter
FS: 2019 Limited Wheels and Tires, $850, Denver, CO FatGopher For Sale: Suspension/Wheels/Tires 1 04-08-2019 09:48 AM
Off Road/ Winter tires for '13 Limited senorquill 5th gen T4Rs 17 03-14-2014 01:03 PM
Winter Tires Limited mikeync 5th gen T4Rs 19 12-03-2009 04:34 PM
Winter Tires for 03 Runner LTC9024 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 03-31-2004 06:22 PM
Winter Tires for 03 Runner LTC9024 4th Gen T4Rs 5 10-29-2003 02:24 PM
