Old 09-11-2019, 10:36 AM #1
2barevo 2barevo is offline
Real Name: Chris
2barevo is on a distinguished road
Real Name: Chris
Help with check engine is on and truck is in limp mode.
Need help. Battery went dead recently. The dash indicator Check engine and "Trac Off" lights are on after I jumped the battery. Multi terrain light is also blinking. Tried to drive it and it's in limp mode. Any suggestions?
Sent from my ONEPLUS A6013 using Tapatalk
2barevo is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 10:52 AM #2
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
The TRAC and Multi terrain lights something just come on as a result of the CEL.
Best thing to do is pull the code for the CEL and post that.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 11:57 AM #3
Real Name: Chris
Real Name: Chris
I'm having the battery charged at the local shop. Hopefully its not totally dead. Could be the cause of the problem. Will pull CEL when I get the battery back.
Old 09-11-2019, 02:59 PM #4
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
I wouldn’t worry about the light and codes unless they come back when you put a good battery back in.
I had an issue after a jump start in my 4th gen. Maybe it was in limp mode, but it wouldn’t accelerate at all and was limited to something like idle rpm range.
Turning the vehicle off and back on did nothing. I just decided to disconnect/reconnect the battery and tried to reset the ecu. That did it for mine.
When the vehicle was first jumped, I was sitting in the vehicle when the cables were connected and I started right away. I thought that maybe some sensor was trying to recalibrate or something and the quick start messed it up.
When I restarted after disconnecting the battery, I waited for a little with the key in the on position and then started.
Not sure if that helps at all, or what was really the problem in my situation,.
Mantilgh is offline   Reply With QuoteReply With Quote
battery , check , engine , limp , mode
2014 4Runner w/ 1900mi, Check Engine + TRAC Off, Limp Mode apenso 5th gen T4Rs 41 03-19-2023 03:37 PM
3rd gen Limp mode? MandAtaco 3rd gen T4Rs 7 03-07-2023 12:15 AM
Disable limp mode? mark.stevens.399 4th Gen T4Rs 2 03-17-2018 12:02 PM
2006 V8 4Runner limp mode HELP!!!! HanIsa97 Problems & Warranty Issues 0 08-23-2017 08:07 PM
Trans in limp mode '92 T4R luther91 3rd gen T4Rs 2 06-15-2015 07:14 PM
