09-11-2019, 10:07 PM
Real Name: Russ
Real Name: Russ
What material to make a platform from?
Hey folks,
I am looking to make a platform to mount a fuse block, relays, etc. What is a good material to use that is heat resistant and a can be used for something like this? I was trying to find some sort of plastic but haven't had luck figuring it out yet.
Thanks
09-11-2019, 11:57 PM
Powdercoated aluminum or steel
09-12-2019, 08:39 AM
you could use ABS sheet assuming it's not crazy hot, the thickness you need would depend on the size and what you're mounting to it but it's all pretty cheap
or if you want to get fancy the perforated metal used inside electrical cabinets to mount everything
09-12-2019, 09:56 AM
Antman used a cutting board. Check his build thread.
Build thread
09-12-2019, 10:31 AM
HDPE plastic
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
09-12-2019, 11:26 AM
Real Name: Russ
Real Name: Russ
Thanks guys. I saw Antmans thread and really liked that idea and was thinking of doing something similar. I currently have a Slee ARB mount with a single compressor. I am looking to make a platform that goes over the stock fuse box and on the free space of the mount, basically an L shape. I would mount everything so it could be disconnected easily to access the stock fuse box. I made a cardboard template that fits pretty good and have an idea for the mounting. The temperature under the hood is what worries me with certain materials.
I'll take a look at all the suggestions, I appreciate the information.
Thanks
09-12-2019, 11:38 AM
Real Name: Bump
Real Name: Bump
I followed Antman's lead and used a cutting board as well. Zero issues and it has been many months through the Texas Summer.
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
09-12-2019, 01:07 PM
Real Name: Russ
Real Name: Russ
That's what I like to hear, what kind of cutting board did you use?
09-12-2019, 01:20 PM
abs sheet. tap plastics is located in many places and can cut for you. you can also heat and bend with just a heat gun
09-12-2019, 01:27 PM
plastic cutting boards are made from HDPE because it is stable and food safe.
09-12-2019, 01:34 PM
Order a piece of HDPE off amazon.
IG: ksotrdpro
2015 Inferno Red TRD Pro | Piaa Platinum LED Headlights | Shrockworks Dual Battery Relocator | National Luna Dual Battery Kit | Optima Yellow Top | SPOD SE | ARB Air Compressor | Rago MSP | Expedition Essentials T4RPAM | C4 Fab Rock Sliders | C4 Fab Dual Swing Rear Bumper | Frontrunner Slimline II Rack | KC C-Series Lightbar | Cooper Discoverer STT Pro 285/70/17 | Dobinson C59-701V | Fox 2.5 Shocks with Remote Resi and DSC | ProComp 2.25" Front Spacer
09-12-2019, 04:33 PM
Real Name: Bump
Real Name: Bump
Literally went to Walmart and bought the small $0.89 cutting board.
A little thinner than most would like with a little bit of flex, but you can see how I installed it in my build thread, and it is rock solid. Easy to custom shape with a jigsaw as well!
Post link: https://www.toyota-4runner.org/3287213-post49.html
Reason: added link to post
09-12-2019, 04:45 PM
Banned
Real Name: Mark
Banned
Real Name: Mark
Get a sheet of 1/4 inch aluminum. You can cut it with a band saw or jig saw. Or by hand. Clean up the edges with a file, smooth with sandpaper. Paint it or not. Don’t use plastic. Yuk.
09-12-2019, 07:53 PM
Marine Starboard. Color options galore
