Old 09-12-2019, 07:31 PM #1
CMTAZ CMTAZ is offline
CMTAZ will become famous soon enough
Parking Lot Lift
Well I decided to lift my 4Runner with the goal of building the biggest, meanest, baddest Toyota 4Runner in…........
the Safeway parking lot. Strike fear in the other highlanders and RAV4s.
Actually, a nice member, sent me 4 Bilstein 5100’s and a different drop kit. The 5100s have a TOYTEC spacer ABOVE & BELOW the tophat. No one knows exactly how many miles are on the shocks, but they were removed when the member bought the truck (85,000 miles).
Right now I am concentrating on the fronts. Although I could probably just have them put on the way they are, I do not want to do that. The real goal of my lift aside from striking fear in the other highlanders and RAV 4 at Safeway is to:
1) LEVEL the truck, reduce nose dive
2) give the vehicle a little better stance
3) allow for a more aggressive tire (maybe a 275)
4) finally if I actually do take this off road (only on an easy trail or path), a little more clearance
5) SLIGHTLY firm up the ride
This has me wondering many things.
Is there a driver’s side and a passenger side?
Should I purchase new bushings for the shocks?
what if the springs are aftermarket? (again, Is there a driver’s side and a passenger side, I don’t mind a little firmer ride, I do not want a stiff ride)
Is there a way to tell if these are the original springs?
Ideally i'd like to use the 5100s (set to 1.75”) and the OEM springs. If I can build all this before the install, it would allow for an easier swap.
If there is a way to tell what springs these are that would be useful. I do not want to stiffen up the springs too much. A little might be ok, but I’m not looking for heavy duty rated springs.
I believe I could have the Bilsteins disassembled, and remove the TOYTEC spacers. The shocks while dirty, do not appear to have oil leaking out of them. I’m thinking that I could use the Bilsteins, and the springs that came with them, or buy new shocks and bushings and use the tophats and springs.
Since I drive less than 10,000 miles a year (Safeway is close by ) and live in Phoenix, longevity probably outweighs high mileage.
any ideas or advice would be helpful.....
Parking Lot Lift-img_20190912_151936-jpg  Parking Lot Lift-img_20190912_151925-large-jpg  Parking Lot Lift-img_20190912_152245-large-jpg  Parking Lot Lift-img_20190912_151947-large-jpg
2018 SR5 Premium - Eibach Pro Truck Lift Kit - TRD Wheels - Falken Wildpeak AT/3 - Tyger Armor Step Bars - Clear Bra - Kenwood DMX706s head unit - PowerBass 6.5" coaxial & 6x9" component speakers (tweeters replaced by JBL 3.5" coax) - Kenwood Excelon 5 Channel Amp - Pioneer 12" Shallow Mount Subwoofer - RAV4 Convex Mirrors - LED Headlights - Lexus LED Fog Lights (clones)
CMTAZ is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 02:45 AM #2
Compromised4Runner Compromised4Runner is offline
Compromised4Runner is on a distinguished road
- yes there is. The drivers side (front) coil is a little bit longer. To compensate for the driver side weighing more.
- fine either way. If it ain't leaking...
- Could be rated for a higher weight. The front would be lifted more than you had anticipated.
- Don't have a solid answer for you, but ..
1. They look old and dirty as ****
2. Generally people pair bilstein 5100's with stock coils. If these were ICON or Fox then I'd assume they were AF.
Compromised4Runner is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 12:05 PM #3
Thank you !!!
I will be starting the disassembly in the near future.
Once everything is apart hopefully i can tell the driver's side spring from the passenger's spring.
thank you.....
feel free to post more advice and tips
Old 09-13-2019, 04:49 PM #4
I think the driver is half a coil more. Should be able to count the "rings".
Edit: the front one in this pick should be the driver's side.
lift , miles , shocks , side , springs
I want a lift but parking garages are more important Jfunk 3rd gen T4Rs 10 12-02-2013 12:50 AM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Parking break/e-Parking issue kakarot 3rd gen T4Rs 11 03-25-2012 05:16 PM
Will I fit into a 6'-8" parking garage w/ daystar lift? zachb_NW 4th Gen T4Rs 15 05-14-2011 07:44 PM
Maybe OT: Parking at JFK airport long term parking ok? RaysMD 4th Gen T4Rs 6 02-25-2005 11:08 AM
