Old 09-13-2019, 12:55 PM #1
Rusty Shackleford's Avatar
Rusty Shackleford Rusty Shackleford is offline
Rusty Shackleford is on a distinguished road
Dash Lights Blinking - Causes?
Hey all, I don't post much on here, but I have searched and haven't been able to find this same issue in another thread. After driving for extended periods of time, say 20 minutes or more with the A/C on, my 4Lo light starts blinking, the traction control light comes on, and so do the ABS and e-brake lights. This only happens when the A/C has been running. My theory is condensation from the A/C is dripping onto a sensor causing these lights to come on. Can anyone point me in the right direction of how to go about fixing it?
Dash Lights Blinking - Causes?-dashlights-jpg
'14 SR5 | Bilstein 5100's w/ front set at 0.85 | 275/70-17 AT3's | Method NV's
Rusty Shackleford is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 04:21 PM #2
lyodbraun's Avatar
lyodbraun lyodbraun is offline
lyodbraun is on a distinguished road
lyodbraun's Avatar
Take it to the dealer if it’s still under warranty?
lyodbraun is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 08:08 AM #3
I'm over 72k miles, so I think I'm outside of warranty coverage, unless it's different for electrical components.
Old 09-16-2019, 10:19 AM #4
PapaRappa PapaRappa is offline
PapaRappa is on a distinguished road
I had this happen to me when a shop, installing Dobinsons springs on my TRDP, broke the wire running down to the ABS sensor. My Dash lit up like a Christmas tree same as yours. It’s not a ton of help but I do think you should check to see if something is affecting that sensor specifically, the ABS sensor.
Once the dealership replaced the sensor cable my 4Runner was good as new.
PapaRappa is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 10:21 AM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Take a good luck at and clean / tighten the battery terminals. This happened on my wifes Camry and the positive battery cable clamp was hosed.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 11:06 AM #6
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
I don't know if this particular thread will help you, if it doesn't i'd check rigtec's posts because he is/was a great resource especially with electrical problems, who grew fed-up with this place and I don't blame him at all. Instrument Cluster warning Icons all lit-up!
good luck.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 01:01 PM #7
Thanks for the reply. I'll do some research on the ABS sensor and see where that leads.
Will do.
good luck.
Rigtec's post has some great info. I will definitely take a look at the 10A ecu fuse. And I'll also get my battery checked out. I'm sure it's original to the truck (2014), so maybe it's getting a little long in the tooth.
Old 09-16-2019, 01:26 PM #8
theCROM theCROM is offline
theCROM is on a distinguished road
Dealer might reem you.
theCROM is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 03:00 PM #9
I would expect nothing less. That's why they are the last option.
Old 09-17-2019, 08:16 AM #10
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
i forget what sequence lights came on for me I know it wouldnt let me go from 2 wheel to any 4 wheel modes. Abs was flashing...
Turns out it was a rear wheel bearing when I took it to the dealer. Some sensor back there wasnt having it
good luck!
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 09-28-2019, 11:52 AM #11
Hey all. So it's been a while since I made this thread, and during that time I had no issues with the lights coming on, until yesterday after the a/c had been running. It's so strange that it only seems to happen on days when I ran the a/c, but anyhow. I crawled up under the truck today and did my best to inspect all of the ABS wires and make sure the connections were tight, and everything looked fine from the outside. I don't really have the tools to check the wiring, so I plan to call my buddy's shop on Monday.
All of that is fine, BUT my question is this - is the truck safe to take on a road trip to Asheville NC next week? It's about 370 miles one way (~5.5 hours). I don't plan on doing any wheeling while I'm there as we're mainly going for hiking and kayaking.
a/c , blinking , light , lights , theory
4WD blinking lights Srgagliardi 4th Gen T4Rs 17 07-28-2021 01:26 PM
Blinking 4wd lights fierohink2 3rd gen T4Rs 3 11-21-2017 04:38 PM
Random clicking and blinking of the dash 4x4Homer 4th Gen T4Rs 4 04-26-2017 08:45 PM
H2 to H4 blinking lights mdavidkelly 4th Gen T4Rs 7 02-03-2015 08:02 AM
A/C lights blinking friendofbeer 4th Gen T4Rs 5 02-16-2005 11:55 AM
