Hey all, I don't post much on here, but I have searched and haven't been able to find this same issue in another thread. After driving for extended periods of time, say 20 minutes or more with the A/C on, my 4Lo light starts blinking, the traction control light comes on, and so do the ABS and e-brake lights. This only happens when the A/C has been running. My theory is condensation from the A/C is dripping onto a sensor causing these lights to come on. Can anyone point me in the right direction of how to go about fixing it?
'14 SR5 | Bilstein 5100's w/ front set at 0.85 | 275/70-17 AT3's | Method NV's
I had this happen to me when a shop, installing Dobinsons springs on my TRDP, broke the wire running down to the ABS sensor. My Dash lit up like a Christmas tree same as yours. It’s not a ton of help but I do think you should check to see if something is affecting that sensor specifically, the ABS sensor.
Once the dealership replaced the sensor cable my 4Runner was good as new.
Take a good luck at and clean / tighten the battery terminals. This happened on my wifes Camry and the positive battery cable clamp was hosed.
__________________ 2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
I don't know if this particular thread will help you, if it doesn't i'd check rigtec's posts because he is/was a great resource especially with electrical problems, who grew fed-up with this place and I don't blame him at all. Instrument Cluster warning Icons all lit-up!
good luck.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
Thanks for the reply. I'll do some research on the ABS sensor and see where that leads.
Will do.
good luck.
Rigtec's post has some great info. I will definitely take a look at the 10A ecu fuse. And I'll also get my battery checked out. I'm sure it's original to the truck (2014), so maybe it's getting a little long in the tooth.
Hey all. So it's been a while since I made this thread, and during that time I had no issues with the lights coming on, until yesterday after the a/c had been running. It's so strange that it only seems to happen on days when I ran the a/c, but anyhow. I crawled up under the truck today and did my best to inspect all of the ABS wires and make sure the connections were tight, and everything looked fine from the outside. I don't really have the tools to check the wiring, so I plan to call my buddy's shop on Monday.
All of that is fine, BUT my question is this - is the truck safe to take on a road trip to Asheville NC next week? It's about 370 miles one way (~5.5 hours). I don't plan on doing any wheeling while I'm there as we're mainly going for hiking and kayaking.
