Old 09-25-2019, 03:19 PM #16
OffKamber OffKamber is offline
OffKamber will become famous soon enough OffKamber will become famous soon enough
Originally Posted by uh0h50 View Post
Seconded. That front end looks unfinished. Sick color choice nonetheless OP.
If you mean the Toyota grill and logo... honestly didn't even notice it is not wrapped until you just pointed it out. It matches well with everything in person. If I start noticing it... (Now that ya'll pointed it out!)... I'll wrap it as well.
... The rest of the front is wrapped in Black.
OffKamber is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 03:23 PM #17
I didn't want to post until I got permission from the owner. I paid more because I had a lot of tint work done as well (including front windshield and moonroof). He said average cost for this type of wrap (2 tone) would be $3300. I am assuming single tone would be cheaper.
Old 09-25-2019, 07:55 PM #18
Crush2.0 Crush2.0 is offline
Crush2.0 is on a distinguished road
Did you add to factory moonroof tint if so what percentage?
Crush2.0 is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 12:25 AM #19
asdfasdf asdfasdf is offline
asdfasdf is on a distinguished road
Looks great so far. Looking forward to the progress.
asdfasdf is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 01:30 AM #20
80% on moonroof and on windshield. It was mostly for the purpose of blocking out heat from the sun... I used ceramic tint.
Old 09-26-2019, 01:48 AM #21
Did a lot of electrical work today. Will post in several posts so I can comment on each individually...
ARB fridge installed. Easy install... used the ARB outlet and wiring kit to go from battery to cargo area. Easy to hide wires under door trim panels. I didn't hide them in cargo area as they sit behind the fridge and it was getting late. Also installed fridge monitor in center console box so I can monitor but it's not exposed (as it is kinda ugly).
I installed a switch from aironboard.com and used a 30 amp relay (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1)
Only reason I used this specific relay is because it was the largest gauge wires I could find as you need thick wires to get from battery to cargo area per ARB. Seems to be working fine so far.
I used the relay and switch to easily control when fridge is on as I do not have dual batteries yet. Plan to eventually.
Ultimate Mall Crawler Build-img_0208-jpg  Ultimate Mall Crawler Build-img_0226-jpg  Ultimate Mall Crawler Build-img_0229-jpg
Old 09-26-2019, 01:53 AM #22
photo upside down...
Old 09-26-2019, 02:00 AM #23
Next was the front parking sensors... I needed them as I park about 2" away from wall in my carport to make sure I am blocking maximum amount of sun. I only installed two on front bumper as that is all I needed. Ordered this kit on amazon... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Also installed a switch for it as I did not plan to connect it to the obd port and wanted ability to turn it on/off only when parking. Photo of switch is in post above. Few photos inside here. It is too dark to take photos of the sensors outside but can take some later if requested...
Ultimate Mall Crawler Build-img_0212-jpg  Ultimate Mall Crawler Build-img_0213-jpg
Old 09-26-2019, 02:06 AM #24
Next up was the cell mount and charger for it. Cell mount (RAM) is basically what a lot of people on this forum have done. Nothing special. Used bolts instead of double sided tape to make sure it stays in place. Turned out solid. I wanted a USB charger next to RAM mount so I don't have wires all over the place. Found a nice spot. Tapped into the cig lighter port on the lower part of the dash for power. Need to buy a 6 inch charging cable though...
Ultimate Mall Crawler Build-img_0215-jpg  Ultimate Mall Crawler Build-img_0217-jpg  Ultimate Mall Crawler Build-img_0218-jpg  Ultimate Mall Crawler Build-img_0219-jpg
Old 09-26-2019, 02:18 AM #25
Lastly... installed the Alpine ILX 309 unit. Easy install (surprisingly). I basically followed the Youtube instructional video for most of it. I ended up using the PDF on the website for the wiring portion though... as I have an Alpine sub and amp and it required a different wiring setup. Install went flawlessly.
Only modification I made was the plastic trim panel. I have black(ish) trim from the factory. The Alpine unit ONLY comes with silver trim. Initially I planned to take apart the trim from the unit and get it wrapped or painted. I later discovered that it's impossible to do that because you need to totally dissemble the head unit to separate the screen from the rest of the unit. I took off like 15 bolts and then I gave up as it seemed like I can break something.
I ordered the Metra dash kit from amazon. It came in a gray color (not black as advertised).
I ordered the same Metra dash kit from Crutchfield. It matched the color of my stock trim perfectly. Not sure why the issue with Amazon?
Anyways... I broke off the silver trim that came with the Alpine unit and easily installed the Crutchfield Metra kit. Came out perfect.
The unit is extremely easy to adjust up/down and tilt once installed so I set it to how I wanted it (not blocking the vents).
I saw a couple of people do this on the forum but behind the screen there was a large gap that you can see into the electronics of the dash. The Alpine unit came with a plastic box to block out that gap. I installed that box on the Metra kit and it worked perfectly to look as clean as possible...
Ultimate Mall Crawler Build-img_0219-jpg  Ultimate Mall Crawler Build-img_0220-jpg  Ultimate Mall Crawler Build-img_0224-jpg
Old 10-10-2019, 10:29 PM #26
Lift and tires done.... full Kings w/ Res, all control arms, rear track bar.
Ultimate Mall Crawler Build-img_0273-jpg  Ultimate Mall Crawler Build-img_0274-jpg
Old 10-12-2019, 08:57 PM #27
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Does it tilt or move freely with alittle pushing or do you need tools. I had an old flip out deck years ago in a jeep and it was motorized to tilt at will (helpful when the sunlight hits it)
ForRun is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 12:42 AM #28
K9kodi K9kodi is offline
K9kodi is on a distinguished road
Looking awesome
K9kodi is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 01:12 AM #29
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
That wrap looks killer, love how you left a little more of the black front/ rear exposed for accent. really makes the wrap pop and ads depth. wheel spacers, fender flares and black rims would set this off.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 09:03 AM #30
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Now that’s what the new army green 4Runner should look like. Nicely done!
TRD PANTHER is offline   Reply With QuoteReply With Quote
4runner , black , fun , stage , week
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 3rd gen T4Rs 93 09-08-2017 05:04 PM
Kraze's Mall Crawler build thread Kraze 3rd gen T4Rs 310 11-04-2015 11:11 AM
'06 XSP to Mall Crawler Build Thread (PICS) SellSwords 4th Gen T4Rs 11 03-15-2015 06:30 PM
Mall crawler here tgormtx New Members 4 12-24-2014 10:31 PM
My New Mall Crawler/ DD mat305 Classic T4Rs 15 06-02-2011 05:41 PM
