Old 02-10-2020, 10:34 PM #61
OffKamber OffKamber is offline
OffKamber will become famous soon enough OffKamber will become famous soon enough
Installed a bunch of armor. RCI Full skid system (easy Install). Only issue is that there was a 2" gap which exposed the foam between front bumper and RCI front skid plate. I purchased their skid plate filler and cut it up to fill in the hole.
Installed RCI skids on control arms and plates. Also installed RCI rear diff skid. Everything was easy except the rear diff skid. The side lips that go around the axle where not properly molded by RCI. I had to spend about an hour bending and hammering the diff skid to mold it properly...
Ultimate Mall Crawler Build-img_2105-jpg  Ultimate Mall Crawler Build-img_2106-jpg  Ultimate Mall Crawler Build-img_2107-jpg  Ultimate Mall Crawler Build-img_2108-jpg  Ultimate Mall Crawler Build-img_2085-jpg  Ultimate Mall Crawler Build-img_2086-jpg
OffKamber is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 10:36 PM #62
Installed SSO roof rack. Easy install. Took an hour.
Also installed Goal Zero solar. With the Goal Zero solar and controller to get juice from alternator... I am in love with my off grid electrical system.
Ultimate Mall Crawler Build-img_2103-jpg  Ultimate Mall Crawler Build-img_2104-jpg
Old 02-10-2020, 10:44 PM #63
Installed SSO Slimline bumper and Stage 2 fender mod. Also added X20 12K winch and Rigid 30" lightbar. Fairly easy install.
This install took extra time as I NEEDED to relocate my radiator pump for my supercharger or the winch would not fit. I also added Baja fog lights while I had the bumper off.
I also added a front facing camera onto the bumper right under the fairlead (that is why my Factor 55 is to the side... to make room for the camera).
I made two "upgrades" to the bumper. First is I added some rubber molding to the rear where the bumper is very tight with some cooling lines. Second I will describe in next post.
Ultimate Mall Crawler Build-img_2112-jpg  Ultimate Mall Crawler Build-img_2115-jpg  Ultimate Mall Crawler Build-img_2083-jpg  Ultimate Mall Crawler Build-img_2082-jpg
Old 02-10-2020, 10:48 PM #64
When I finished installed SSO bumper and high clearance mod... I noticed that my front bumper was a bit flimsy. I pulled back the rubber moulding and drilled 2 small holes on each side. I then used zip ties to secure the bumper in place. The moulding slid right over the zip ties without having to modify the moulding in any way.
Ultimate Mall Crawler Build-img_2079-jpg  Ultimate Mall Crawler Build-img_2075-jpg  Ultimate Mall Crawler Build-img_2081-jpg
Old 02-10-2020, 10:50 PM #65
I also added the anytime backup camera mod to the 4Runner. Simply install. However, it took me 30 minutes to get it working with my Alpine 309 system. Eventually I figured it out (it needs to run as an accessory in the Alpine system - then you can use front or rear camera anytime).
Ultimate Mall Crawler Build-img_2110-jpg  Ultimate Mall Crawler Build-img_2111-jpg
Old 02-11-2020, 01:49 AM #66
papadop88 papadop88 is offline
papadop88 is a jewel in the rough papadop88 is a jewel in the rough papadop88 is a jewel in the rough
F'in rad man!
papadop88 is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 09:32 PM #67
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Loving it. The matte green (Halo green) looks nice. Also like the winch for a mall crawler, can pull out some minivans. Gucciest ride on the trail.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 09:57 PM #68
Got my SSO rear bumper. Didn't have much time due to work so paid a shop to install it...
Reviews: It's heavy but I like the trailgator for camping. I wouldn't trade it for another bumper but would only recommend it if you have a supercharger (assuming if your looking at this rear bumper you already have a ton of added weight in other places...).
Also, it has some noises... but honestly every rear bumper with a tire carrier and accessories will have noises. It's part of the trade off. I have been tweeking with it to reduce noise and eventually will be able to reduce most of it... it's all about getting the exact allignment between bumper and frame (playing with various spacers) and adjusting the rubber bushings.
Lastly... I wish that there was a secondary attachment from the SSO roof rack to the tire carrier to keep the tire carrier a bit more stable. With all the added weight (34" tire and hi-lift) I would like maximum stability.
- On this specific topic as well: On my Jeep I've always had three points of attachment for tire carrier. Every tire carrier made for Toyota that I've seen has only 2 points... would be nice to add a third point (seems easiest to do by attaching to roof rack).
I also replaced my springs with 650 pound springs.
Old 07-17-2020, 10:01 PM #69
Also added king bumpstops. Had to get custom mounts as they didn't exist for front. Tested the hell out of them and it's day and night difference in performance. No more fears of hitting washboard bumps at any speed. Even dented my steel skid plate hitting some bumps offroad but didn't feel any hard impact due to kings.
Old 07-18-2020, 01:18 PM #70
BimmerBen BimmerBen is offline
BimmerBen is on a distinguished road
Very interesting wrap in the front. Reminds me of 2021 Tahoes
BimmerBen is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 10:22 PM #71
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Pictures arent loading
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 12:34 AM #72
More mods... 99% done with build! Only thing left is I am waiting for a dual jerry can holder from SSO to replace my rotopax. Not happy with Rotopax in general... take up too much space for the amount of liquid they hold.
Jerry can holder will go onto same spot where the rotopax are right now...
Anyways... to the build:
Installed a drawer setup from Goose gear. Purchased there drawers and the flat section to delete my cargo tray pullout (which I never used). Easy to install. Used nutserts to make additional ancho points and install my Alu-cab slideout for the fridge...
On the right you will also see a yellow and red cone thing. That is the Geyser shower system I mounted with ratchet straps. Fit's perfect and works much better than expected and better than portable showers with shower heads!
Ultimate Mall Crawler Build-1-jpg  Ultimate Mall Crawler Build-2-jpg  Ultimate Mall Crawler Build-3-jpg
Old 10-12-2020, 12:37 AM #73
Added a table to my Southern Style Offroad tire carrier. Fairly simple... just drilled some holes and put in some bolts... Works perfect and invisible when closed.
Ultimate Mall Crawler Build-1-jpeg  Ultimate Mall Crawler Build-2-jpg  Ultimate Mall Crawler Build-3-jpg
Old 10-12-2020, 12:40 AM #74
Added a tranny cooler with a fan. Tired of overheating the tranny...
Wired it to turn on at 185.
Also changed out tranny fluid. This is what it looked like after 13,000 miles...
Ultimate Mall Crawler Build-1-jpg  Ultimate Mall Crawler Build-2-jpg  Ultimate Mall Crawler Build-3-jpg  Ultimate Mall Crawler Build-4-jpg
Old 10-12-2020, 12:42 AM #75
Replaced radiator with CSF aluminum radiator. Engine was also overheating a bit. Please note that I am supercharged, have an extra 1500 pounds when overlanding with gear, bumpers, skids... and am not planning on re-gearing.
4runner , black , fun , stage , week
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 3rd gen T4Rs 93 09-08-2017 05:04 PM
Kraze's Mall Crawler build thread Kraze 3rd gen T4Rs 310 11-04-2015 11:11 AM
'06 XSP to Mall Crawler Build Thread (PICS) SellSwords 4th Gen T4Rs 11 03-15-2015 06:30 PM
Mall crawler here tgormtx New Members 4 12-24-2014 10:31 PM
My New Mall Crawler/ DD mat305 Classic T4Rs 15 06-02-2011 05:41 PM
