Old 09-14-2019, 07:20 PM #1
Oregon1 Oregon1 is offline
Oregon1 is on a distinguished road
Fading check engine light
2018 Limited - 22K miles
Washed, drove all morning on errands, went to start it later and it wouldn't turn over. All the lights etc were fine. Tried a few times - ended up pulling the batter cables and let it sit, attached back - started up with no issues.
Drove to Home Depot - turned it off and the check engine light started to fade in and out. Never full glow - like a dimming light bulb but not consistent - erratic. Got out - it beeped at me - pressed the lock on the key fob - nothing. Opened the door - no chime. Got in and it started right up - no check engine lights.
Drove to grocery store - turned off - light went glowing again - no door chime - but this time it locked when I pressed the key fob on exit. Came back - nothing. Wouldn't unlock. Pulled the cheat key from the fob, got in, and started up. No lights. Thought hey maybe its the fob - tried the other..same result. Glowing barely noticeable check engine for about 5 minutes after its shut off - then the door starts to chime. But now the fobs not locking or unlocking. When I walk away it beeps three times and inside its flashing the missing key symbol.
Pulled to see a code and only P0504. Why would it only dimly glow for a bit with the engine off - but clear as a bell and runs fine when on...
Go....
Edit - And I just went out with no key near it - and after an hour - the check engine iight is still half on.
Battery? Evap?
Oregon1 is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 08:51 PM #2
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Maybe something got wet during the wash?
thennen is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 09:07 PM #3
Don’t think so. Didn’t open the hood and I drove it for an hour after. As a note I did go out a few minutes ago. The light was off and the fob worked again.
Old 09-15-2019, 07:11 AM #4
NoLight's Avatar
NoLight NoLight is offline
Real Name: Charlie
NoLight is on a distinguished road
NoLight's Avatar
Real Name: Charlie
Did u get gas while u were out? no idea what the code means but try ur gas cap maybe loose or off. Wife does this alot!!
Immune, Steve!
NoLight is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 10:37 AM #5
thennen's Avatar
thennen's Avatar
Has it self-resolved then, you think?
Old 09-15-2019, 01:33 PM #6
Oddly this morning it’s fine. I did remove the pedal commander while it was going on but it lit the same light for a few hours after it was removed so not sure if related or not. Although I suspect anything I plug in can screw something up. I’ll keep an eye on it.
Old 09-15-2019, 01:34 PM #7
No but in Oregon we’re not allowed to pump our own gas so any other time that’s a possibility for sure.
check , engine , fob , light , started
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
VSC, Trac & engine check light with Rod blown through engine. 4RMac 3rd gen T4Rs 10 05-20-2012 04:42 PM
