Old 09-15-2019, 08:27 AM #1
JPK_NJ JPK_NJ is offline
JPK_NJ is on a distinguished road
What to do ? Dealer Caused Paint Damage Front End
Looking for other member's reasonable opinion of how they would handle this. Dealer accepted fault. Truck is 19' TRD ORP w 3k miles. Barcelona Red, which Ive now learned shows chips bright as day. Thin layer of red paint, then bright white base coat.
Basically a result of a road test gone bad / aka following a dump truck! All relatively minor stuff but on an almost new truck that was pristine prior is very irritating. I'm also a person that likes "everything perfect" slight OCD ha
Two Large chips down to metal on Hood crease area
Deep stone gauge in TRD Pro Grille Garnish and lower bumper
Cuts / scrapes across the entire grille top piece - the body colored piece that sits right below the hood and above the "Toyota".
Dealership manager wasn't avail to speak with yet. Monday
JPK_NJ is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 11:11 AM #2
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
I had some minor damage to leading edge (minor scratches and two small slight dents less than 1" each) of the roof that was not visible in the dark alcove they place the sold cars in the middle of the day. It looked like loading/unloading damage or some road hazard was kicked up on it while on the delivery truck. Within 10 minutes of arriving at home and putting it in the garage I spotted it in. I immediately called and told them I'd be back in the AM. Also fortunately, when It arrived at the dealer a couple days before it was available for me to buy it, I had the salesman snap some pictures of it as it sat. He sent me 3 or 4 and looking back at them you can see the slight damage in them in those pictures but they don't stand out as damage. I emailed them all the pictures when I got home for them to see.
I met with everyone and they looked at it as the detail guy showed up to work. They all spoke out of earshot then I was told the roof was never detailed. Okay wtf, they then detailed the whole truck then took stock of what was wrong. The only thing left at this point were the small dents. They called the dent removal guy they do business with and scheduled him for the next day. He worked his magic for 1.5 hours and it was all fixed. Each trip to the dealer ( I live 70 miles away) they topped off the fuel tank.
It was at this time I realized how sad of a place the toyota free-service waiting room is and I swore I'd only be in one if I absolutely had a warrantee issue.
Good luck, your issue sounds even more clear cut than mine was, I'm sure they got a guy on speed dial to fix this as well. I'm thankful I asked for the pictures ahead of time, still pissed at myself for missing it.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 11:53 AM #3
Super clear cut issue. Forgot to add, the 4runner was in their possession for about a week while they fixed my KDSS. It was only when I went to pick it back up I noticed. They also do a walk around iPad vid of all vehicles when you drop it off and the damage was not visible in the video so dealer accepts it's on them.
The question is should I just accept them having a body shop repair / partially paint the hood and ordering two new grille pieces (garnish & top body color panel) or should I involve a regional or national toyota rep? It's not like just buffing out scratches. The actual paint is gone, down to base metal.
To make matters worse, it was actually the service tech's fault my 4runner needed to go back in for kDss repair. When they replaced my front bushing at <1K miles, the tech didn't properly secure the front strut/shock. So it was shimmying around for 2K miles which then made itself known by actually tearing open the bushing under the kDss valve. Hence the second repair job
Old 09-15-2019, 11:55 AM #4
Dinosaur Overland's Avatar
Dinosaur Overland Dinosaur Overland is offline
Dinosaur Overland is on a distinguished road
Posting the pictures might help
Dinosaur Overland is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 11:58 AM #5
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
Not sure what you are asking, you said they accepted fault and I assume they have agreed to repair it?
Are you looking for something beyond that? If so, why do you feel entitled to more?
Grape Ape is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 12:00 PM #6
rsimi72 rsimi72 is offline
rsimi72 is on a distinguished road
Oh man. Sorry. It can all be fixed. Still a big bummer. The grille garnish should be easy as they can just replace it. The hood is, in my opinion, more concerning. It’ll have to be painted to fix those chips correctly. It seems you have to let them fix it. I hope they have access to a good painter. I would ask questions and I would maybe even talk with their painter. I wonder if you have choice in who does the work. I have rejected paint work before. In my case it was the quality of the finish work, sanding, polishing, etc. I’d would try to inspect final work in daylight and dry weather. And let your OCD be a strength. You will live with it for a long time. Most likely it will all turn out fine. Any chance they can add some paint protection film for your trouble? Repainting is typically a bit softer than factory paint. The extra protection would be helpful and you may feel better about it walking away. Really sorry. Good luck. Keep us posted.
rsimi72 is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 12:45 PM #7
CavPro's Avatar
CavPro's Avatar
Originally Posted by Old Red View Post
the smaller grille painted piece up top actually comes from Toyota painted, so they should be able to just swap that out
Have you ocd'd on the waviness in that piece yet?
Old 09-15-2019, 12:54 PM #8
The hood is my biggest concern as that will truly never be "as it was prior". The colored grill and garnish replacement Im perfectly ok with. If it was only that, I'd be happy with them just covering the new part replacement and call it a day. Accidents do happen but I kind of feel like their negligence or bad luck shouldn't be passed down to my new truck which I own outright and planned on keeping forever. Anyway, maybe Im making too big of a deal but here are the hood areas. I also hope the kdss suspension isn't messed up from their sloppy mechanics error that had me driving around 2k miles with it not fully bolted down. Pics of hood area and bumper (less concerned with this as Im sure Ill get more )
What to do ? Dealer Caused Paint Damage Front End-image2-13-jpeg  What to do ? Dealer Caused Paint Damage Front End-image1-33-jpeg  What to do ? Dealer Caused Paint Damage Front End-image6-jpeg
Old 09-15-2019, 01:25 PM #9
CavPro's Avatar
CavPro's Avatar
IMO that should be very easy for a professional to fix. The key is getting someone to do it right. What worried me most about my damage was the dealer had an in-house body shop and I didn't want them painting it, luckily it didn't need painting. As stated before, the dealer has accepted responsibility, you have to give them a chance to fix it first. I went into my deal a little jacked up but didn't let it show and it turnes out it was all self-inflicted unnecessary worry. It'll work out.
Old 09-15-2019, 02:00 PM #10
Jernik's Avatar
Jernik Jernik is offline
Real Name: Jeremy
Jernik is a jewel in the rough Jernik is a jewel in the rough Jernik is a jewel in the rough
Jernik's Avatar
Real Name: Jeremy
Instead of breaking the finish on the whole hood, if they have a good airbrush guy to touch up the chips it should be good.
When I worked at a used car dealer, we had these guys come in and it was amazing what they could make disappear. I always wondered how well it would hold up...
Then I got a new Dakota - noticed a spot underside of the bumper (plastic painted "dress up" panel that held foglights) was scratched like they lightly drug ot over something taking it off the truck. We agreed to try the touch up artists first before breaking the factory coat on the whole piece. They did a great job, and the repair still looked good as new when I sold it 10 years later. Granted, it was in a more protected area than right up on top of the hood, but it held up better than I thought it would.
I've also applied the factory touch up paint myself with decent results (it held up and protected fine, but was definitely noticeable - unlike the airbrush repairs). The only concern would be if the chips are too deep for airbrush to fill completely.
Of course, you could also have them paint the whole hood. Most quality paint shops I've been to are pretty good at matching and blending.
I wouldn't sweat the repair too much. On the plus side you haven't had to fight them, so that's +1 for them IMO. It sounds like they are trying to do you right - it could be worse.
Toyota noob
Jernik is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 02:18 PM #11
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
I wouldn't let them repaint it. Have a real body shop do the work. Tell the dealership you want control over where your car goes. Dealerships aren't paint shops, and a paint shop will warranty their work as well.
llDemonll is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 02:51 PM #12
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
I used to loose sleep over these kind of things when my vehicle was new. Mine still looks very good but my hood does have some small chips after 5 years of driving. No mater how good they fix it you will eventually get chips again. Let the dealer do their repair and hope it looks good enough to you. I just use touch up paint on my chips. Yes it is slightly noticeable but I realize that there are going to be many more chips in the future.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 04:21 PM #13
gainman gainman is offline
gainman will become famous soon enough
I don't understand the question? Let them fix it. Seems pretty easy to me
Sent from my SM-N975U1 using Tapatalk
gainman is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 04:35 PM #14
CavPro's Avatar
CavPro's Avatar
The upper painted grille piece?
yeah, if you look down the leading edge of the hood where it meets this piece it is noticeable, but again it may be more pronounced in certain colors/light.
Old 09-15-2019, 06:08 PM #15
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
This 100%. Have them fix it but don't lose sleep over it. Any car you daily drive and actually use will show wear and tear. Just touch up chips as they happen and accept it.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
grille , hood , red , trd , truck
Toyota hood protector caused paint damage underneath Deaone123 5th gen T4Rs 11 02-28-2019 02:30 AM
Paint Chips Damage in front of Rear Wheel SteadFAST 4Runner 5th gen T4Rs 6 10-12-2016 04:42 PM
Could I have caused damage to my drivetrain? Maximillian 4th Gen T4Rs 11 08-20-2010 08:49 PM
paint damage caused by SEAFOAM! 99yota4 Maintenance/Detailing 15 07-03-2010 10:19 AM
Question about front bug deflector paint damage hybridamp 4th Gen T4Rs 17 04-28-2010 08:41 PM
