09-24-2022, 06:05 AM
High clearance tubular rear bumper without cutting cross member
Looking at Nguyen and outgear solutions fabrication they do have the option however I can’t find anyone with the setup without deleting cross member, anyone?!
09-24-2022, 11:09 AM
Real Name: Matt
Real Name: Matt
check out the Nguyen Works Instagram... nguyen_works - it has quite a few pics of 5th gen rear bumpers with crossmember still in place. they look really clean with the delete, but IMO still look great with the cm still intact.
2007 SR5 V6 4x4 / Front Suspension: OME 884/90021 + SPC UCA's / Rear Suspension: OME 895/60004 / Tires: 285/70r17 BFG K02's (C Load) / TRD Pro Wheels / Apex Overland Front Recovery Points / Desert Armor Ninja RTT / Outgear Solutions Low-Pro Crossbars
2017 TRD ORP / Watch this space....
09-24-2022, 10:10 PM
do the deleteeeeeeeeee. it looks better IMO.
09-25-2022, 01:42 AM
Joe (Outgear Solutions) posted a reel of one on IG the other. Looks clean IMO
09-25-2022, 02:14 AM
Can’t find any on their IG
09-25-2022, 02:19 AM
Found on Nguyens, want to see what outgears look like
09-25-2022, 11:07 AM
So you only want high clearance at the rear most corners of the truck?
09-25-2022, 03:05 PM
Was going to buy dirtcom tire carrier for $1700 until I found out about this guys.
09-26-2022, 12:45 PM
trd_grey_mamba on IG has the outgear solutions bumper. I don't think he still has the crossmember though, but it's hard to tell. best to just go to the outgearsolutions IG page as see
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
09-26-2022, 02:05 PM
Technically you would not loose any real clearance by leaving the crossmember, except down the center of the bumper....as the frame rails are still present. The lowest point is your limiting factor.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
09-26-2022, 04:18 PM
official vendor
official vendor
I have their bumper with the crossmember, and below are a couple of pictures for reference. The last two show a crossmember cover that I designed, and it really cleans up the look.
IMO, I would ask around about other issues and not worry so much about the crossmember. Start asking people that have about 8-10k miles on the bumper what their thoughts are. This would be my concern in the bumper decision, and not the crossmember.
Mike
09-27-2022, 10:45 AM
Mike
Any chance you weighed your bumper before mounting it? I’d be curious to see how much weight this adds in the rear. My CBI is pushing near 250-275 lbs. I could see this being at least 100 lbs less
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
09-27-2022, 02:21 PM
official vendor
official vendor
Just the bumper without the swingout, my guess is 120lbs or less since there isn't much material to it.
Mike
09-28-2022, 02:41 PM
Look at that same thing from the side. Its not a straight down rectangle as your photo portrays it to be.
The crossmember would extend beyond the rear bumper and sit under it 3-4”
