Old 09-16-2019, 01:33 PM #1
theCROM theCROM is offline
theCROM is on a distinguished road
Torque Converter or Transmission issue?
I took my 4runner in today to get the 60k works and also to have them check an issue I've been having. Around 40mph+ i feel a little wobble in the accelerator like its hesitating. Asked them to check it out and after an hour of diagnostics they say its either the Torque Converter or a Transmission issue one or both would have to be replaced. Does this sound reasonable? Im already planning on taking it to a local mechanic to have them check it out to see if they can determine anything as well. Seems like for a vehicle I've only have 1.5 years to already be having transmission problems is kind of a big deal.
theCROM is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 02:03 PM #2
samwhich's Avatar
samwhich samwhich is offline
samwhich has a spectacular aura about samwhich has a spectacular aura about
samwhich's Avatar
60k you're still within powertrain warranty, see what the dealership says and have them fix it.
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
samwhich is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 02:10 PM #3
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
What model year is it? Do you have the option to go to another dealer and get their opinion?
Is is weird to have a transmission issue at 60K
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 02:11 PM #4
I wish! I'm actually at 70k miles. I did a regular oil change at 60k cause we were in the middle of moving across country and just didnt have time to go in for the full service. That would have saved me so many headaches cause I've been feeling it for the last 10k miles atleast.
Old 09-16-2019, 02:13 PM #5
Its a 2016. We bought it mid 2017 though cause the dealership was trying to get rid of it so got a decent deal on it. Yea I might try another dealership and a few work folks recommended a local mechanic shop as well that apparently does pretty solid work.
Old 09-16-2019, 02:27 PM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Mine does that around 40mph with a light foot on the pedal. Been doing it since new. Dealer told me it was normal, just hunting at the in between gear stage.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 02:29 PM #7
Yea I'm going to get a second mechanic to look at it. If they say the same thing I'll probably just ignore it since its a very slight stutter. If it gets worse I'll bring it back for work.
Old 09-16-2019, 02:46 PM #8
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
I have seen threads regarding this, here one of latest:
'18 SR5 with intermittent driveline shudder
To clarify by “this” I am referring to “wobble” exactly as you described it… some people call it “shudder” or “rumble strip” (which in most cases does mean TC replacement or tranny rebuild- I think it was occurring in 4th gen a lot more than 5th gen), but I believe what you describing is not “rumble strip”… maybe “wobble” eventually turns in to “rumble strip”, however I have not seeing anyone confirming that and I hope that is not the case as I also can occasionally feel what you describe … it is very very minor and I have to “work” on the speed and throttle to make it happen…
What I have noticed with mine, if I shift to “S” mode and then up-shift into 5th gear then “wobble” disappears completely and I cannot make it happen again in “S” mode regardless I am in 4th or 5th gear… so it leads me to believe that it could be “Flex Lock-up” behavior in “D” mode and hopefully nothing wrong mechanically…
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 03:10 PM #9
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
The thread above is one I started to document the problem I've been having.My 4R has less than 10K and I only really started noticing it within the last 3 or 4 months. Light acceleration 40 - 45 MPH feels like a shudder that you can feel in the seat. Curious what diagnostics they did to determine it was the TC or tranny.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 03:18 PM #10
progress4m's Avatar
progress4m's Avatar
I am not sure… I also have seeing reports when TQ (tranny) was replaced (by the dealer) and this issue have reappeared soon after…. Can you try to switch into “S” mode, then up-shift to 5th gear and see if you still have that shudder?
Old 09-16-2019, 03:23 PM #11
Jivewalker's Avatar
Jivewalker's Avatar
Hey man, for shits and giggles, try disconnecting your battery for a couple of hours and then drive and see if it go's away. I swear every time I do work where I have the battery disconnected long enough mine gos away, but then comes back over time. I was starting to think it was something in learned driving habits and gear hunting based on my light foot driving style at 40-45mph. I gave up on it since I have so many miles on it now and it never caused me any issues, but it does do it, I don't call it a wobble but a hesitation / hunting, like it can't catch the gear.
I am fragile.
Not like a flower.
But like a bomb.
Old 09-16-2019, 03:23 PM #12
I'll have to test this myself this evening when I pick it up after work. The fact that they wanted to charge me almost $300 for brake pads makes me feel a little skeptical of the dealership.
Old 09-16-2019, 03:27 PM #13
Jivewalker's Avatar
Jivewalker's Avatar
One other thing, I had a gummed up OCV that caused the same, but more pronounced, hesitations at around 40mph. It eventually caused a code and that's how I figured out it was the OCV. Cleaned the OCV filter screen and OCV and it's been 40k miles since with no issues. Just another thought.
I am fragile.
Not like a flower.
But like a bomb.
Old 09-16-2019, 03:33 PM #14
Old 09-16-2019, 03:33 PM #15
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
I've tried "S" mode no real change. The worst part about it is the intermittent nature of the shudder.
check , converter , issue , torque , transmission
Transmission torque converter seal mforce 3rd gen T4Rs 7 05-30-2019 02:47 PM
Transmission Torque Converter Installation 954RUNDEN 3rd gen T4Rs 13 05-18-2019 12:32 PM
Transmission Overheating - Torque Converter Issue? 96TrailSurfer 3rd gen T4Rs 15 08-03-2018 11:52 AM
1995 2wd auto Transmission w/ torque converter 4running1990 Classifieds - buy & sell (no commercial ads please) 0 01-17-2011 02:29 AM
4th Gen - torque converter/cruise control issue riverwolf Problems & Warranty Issues 4 09-30-2008 11:17 PM
