Old 09-16-2019, 03:58 PM #16
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Originally Posted by Jivewalker View Post
Hey man, for shits and giggles, try disconnecting your battery for a couple of hours and then drive and see if it go's away. I swear every time I do work where I have the battery disconnected long enough mine gos away, but then comes back over time. I was starting to think it was something in learned driving habits and gear hunting based on my light foot driving style at 40-45mph. I gave up on it since I have so many miles on it now and it never caused me any issues, but it does do it, I don't call it a wobble but a hesitation / hunting, like it can't catch the gear.
when I took it to the dealership (couldn't replicate the shudder that day) the tech reset the learning parameters for the tranny or something like that. It didn't do a thing.
This seems to be a common theme with people experiencing this problem..
40 - 45 mph, light accelerator, shudder/hesitation occurs. not so much an issue if you're heavy on the throttle all the time..I expect it's more of a nuisance for people like me with short commutes..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 04:51 PM #17
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
One other thing, I had a gummed up OCV that caused the same, but more pronounced, hesitations at around 40mph. It eventually caused a code and that's how I figured out it was the OCV. Cleaned the OCV filter screen and OCV and it's been 40k miles since with no issues. Just another thought.
Interesting… by OCV, are you referring to Oil Control Valve for VVT? If yes, what filter screen did you clean..?
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 07:41 AM #18
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Yes, oil control valve. There is a filter screen at the top of the oil pipe where it enters the valve cover at the OCV.
Torque Converter or Transmission issue?-capture-jpg  Torque Converter or Transmission issue?-capture2-jpg
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 11:21 AM #19
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
Can you give a bit more info on this? Any parts required to do the cleaning, steps etc?
Thanks,
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 11:15 AM #20
Jivewalker's Avatar
Jivewalker's Avatar
Thanks,
X
It's pretty simple. Unscrew the bolt at the top of the oil tube, there should be a conical screen loosely fitted on the end of the bolt and it should come out with the bolt (mine both did). Pull the bolt out slowly and carefully. I used pb blaster to clean the screens. Put it back together and torque as specified. There are two washers which I re-used each time without issue, though the drawing says to replace each time. So be careful you don't let one fall out.
You will see right away if they are gummed up and restricting oil flow to the OCV. In my case, I knew they were because I had a cam shaft retard code after the hesitation started. I had some sludge build up, which I think was caused by a bad PCV valve and some long periods of idling in hot weather, but who knows. I cleaned the screens, gently cleaned the OCV's, and also cleaned each cam position sensor. My problem went away and I've been doing 5k oil changes ever since along with checking the PCV valve and also the OCV screens occasionally.
I am fragile.
Not like a flower.
But like a bomb.
Old 09-18-2019, 08:32 PM #21
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
Originally Posted by theCROM View Post
I took my 4runner in today to get the 60k works and also to have them check an issue I've been having. Around 40mph+ i feel a little wobble in the accelerator like its hesitating. Asked them to check it out and after an hour of diagnostics they say its either the Torque Converter or a Transmission issue one or both would have to be replaced. Does this sound reasonable? Im already planning on taking it to a local mechanic to have them check it out to see if they can determine anything as well. Seems like for a vehicle I've only have 1.5 years to already be having transmission problems is kind of a big deal.
I believe all Toyota truck with the 5 speed transmission can have this issue. I owned a 08 FJ since new and had almost 200k miles on it before I sold it in 4 days! It did it once on me until I started doing a transmission pan drain and fill every 15k miles. I believe the transmission fluid is the issue. I just did it on my 18 4runner at 18k miles on it and it was almost brown in color instead of red. I only use Toyota WS transmission fluid. A transmission fluid pan drain and fill takes exactly 3.25 quarts.
2018 4Runner SR5
2002 4Runner Limited (low mileage, my dad purchased new)
2008 FJ with Off-Road Package (191k miles) Sold 6-19
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 05:55 PM #22
Hungryhawk Hungryhawk is offline
Hungryhawk is on a distinguished road
Shuddering on light acceleration
I know this is a 3 year old post, but I am in the middle of a similar issue with my 2017 SR5 at 48,000 miles.
With light acceleration at 30 to 38 mph on local city streets the truck would start acting up with a judder or shutter. It felt like I was driving on a washboard Road.
Dealer diagnosed problem as faulty torque converter. After this diagnoses, I noticed this Issue would not show up when driving the transmission in “S”. It only showed up when driving in “D”.
Dealer is replacing torque converter under platinum warranty. I will post again after getting the vehicle back and driving it for a few weeks.
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 10:16 PM #23
Stabbi Stabbi is offline
Stabbi is on a distinguished road
Mine does that around 40mph with a light foot on the pedal. Been doing it since new. Dealer told me it was normal, just hunting at the in between gear stage.
I would second the above. Mine does the same, 2017 w/57K and has always done a little funky shifting around 40MPH when light on the peddle as described. From the reviews I have read on the 4R, the shifting at 40mph logic could use some improvement.
Stabbi is offline   Reply With QuoteReply With Quote
check , converter , issue , torque , transmission
Transmission torque converter seal mforce 3rd gen T4Rs 7 05-30-2019 02:47 PM
Transmission Torque Converter Installation 954RUNDEN 3rd gen T4Rs 13 05-18-2019 12:32 PM
Transmission Overheating - Torque Converter Issue? 96TrailSurfer 3rd gen T4Rs 15 08-03-2018 11:52 AM
1995 2wd auto Transmission w/ torque converter 4running1990 Classifieds - buy & sell (no commercial ads please) 0 01-17-2011 02:29 AM
4th Gen - torque converter/cruise control issue riverwolf Problems & Warranty Issues 4 09-30-2008 11:17 PM
