Old 09-18-2019, 07:03 PM #16
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
Last time I went to Costco they install a completely different tire than I had ordered. Had to wait another hr for them to fix their mistake. Atleast they have free road hazard warranty.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 07:25 PM #17
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Originally Posted by 83Mule View Post
I think He is saying they torqued the lugs with the BF airgun and the wheels sent the shock through the rear end to the driveshaft yoke and broke the bolts with the rapid shock loading....probably not good for the ring and pinion either!
I just don't think that's possible. Even with an air impact. The drive shaft would have a natural gear reduction in torque of 4:1. So you'd have to have an extremely high amount of torque on a wheel to damage something upstream of the diff. It takes a LOT of effort to break the driveline components on these. The engine in 4Lo will apply as much as 10,000 ft/lb of torque on the axle shafts. And they won't break. I don't see how anything related to lug nuts could possibly get close to that. The lug nuts will break off at less than 200 ft/lb. It's multiple orders of magnitude off of the realm that it would need to be in to cause damage.
The hub nut that holds the CV shaft in the hub assembly takes more torque than the lug nuts can withstand before breaking. IIRC it's something like 250 ft'lb. If it were possible to break or damage the driveline - every time someone re-installs a front CV they'd be damaging parts or risking damage. You never have the wheel on for that process. You can't. The dust cover still needs to be installed before you put the wheel on.
Old 09-18-2019, 08:29 PM #18
PittRunner PittRunner is offline
PittRunner is on a distinguished road
I had 275/70/R17 Ko2 put on at Costco,I have been buying tires and having them balanced and rotated for free for years, they allways Torque to spec.and recommend re Torque after 40 Km.which I do myself.They also fix punctures free.Good service in my opinion..
PittRunner is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 08:50 PM #19
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
They would have no concern with that tire as it is an E with a load rating in excess of the stock 113, just as they would have had no issue with the 265 in an E load.
I'll say again that all of the above have a safety margin as Toyota ships the same vehicle in Limited trim with a 107.
5thToy is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 09:03 PM #20
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
And that has implications for what the actual needed safety margins are per tire when running LT. There is a whole thread about LT tire pressures but it is based entirely on the notion that 113 needs to be met. Once 107 is taken as the baseline, things change quite dramatically when it comes to the needed LT pressures to meet the safety margin.
Old 09-18-2019, 09:07 PM #21
Exactly. Nobody seemed interested in considering that when I made your point in another related thread on LT pressures.
Old 09-18-2019, 09:08 PM #22
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
My guess is the op is confused on what he was told
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 07:06 PM #23
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Originally Posted by Jetboy View Post
Why were they doing anything with brake cleaner?
Also - 83 lb/ft on the lug nuts should not cause any damage to anything on the vehicle. You'd need something like 100 times the force to get into the range of damaging anything. The failure strength is probably in the range of 7,500 ft/lb. In short - it's pretty unlikely that they damaged your axle by torquing the lug nuts. If they somehow damaged your axle - it wasn't related to torquing the lug nuts on.
costco idiot torqued the nuts with the wheels OFF THE GROUND !!! the wheels were wacking back and forth ... drove home and had vibration .
I did the U joint repair bearings looked good not rusted but had damage on the needle bearings.. you torque wheels on the ground they are not professionals. brake cleaner is acetone spray it on your paint then you will see how the idiots did the damage.
my hubs had small amount of anti seize on it paint like amount very little so they sprayed the steel hub and then the painted aluminum wheels ..did not use rag just sprayed the sh*t of it ..
catrains is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 11:44 PM #24
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Costco did a pretty good job when they got started in tires, but have been going down hill for the past few yrs.
Thank God for the 35 yr. old mom-n-pop tire shop in the small town I live in.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 09:35 AM #25
Jetboy's Avatar
Jetboy's Avatar
Your junk wasn't damaged by the tire install. There's no possible way a u joint is damaged by lug nut install. not to mention that the tires all free wheel off the ground unless you have diff locks. This didn't happen. It's not possible. There's lots of ways to screw up a tire install, but this isn't one of them.
Old 09-20-2019, 11:27 AM #26
Crikeymike
Guest
Posts: n/a
Crikeymike
Guest
Posts: n/a
But at the end of the day, what did you end up going with?
The hot dog?
The chicken bake burrito roll thing?
Or the very berry sundae?
There's no way OP went to Costco and didn't at least get one of those things, even if their tire shop wasn't very helpful!!
Old 09-20-2019, 12:42 PM #27
IrieRider's Avatar
IrieRider IrieRider is offline
IrieRider is on a distinguished road
IrieRider's Avatar
We have a chain called les schuab... theyll throw anything on cheap and always offer to help out with flat repairs
IG 4runner.gunner
IrieRider is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 02:03 PM #28
SteveOreno's Avatar
SteveOreno SteveOreno is offline
SteveOreno is on a distinguished road
SteveOreno's Avatar
Originally Posted by nimby View Post
They are doing you a favor. Go elsewhere.
Buying tires at Costco sucks because there is a 3 hour wait every time you go to get your tires rotated.
They have like 3 stalls for every 20 tire customers.
When's the last time you saw an empty Costco during business hours?
So they have more tire guys then check out staf......
SteveOreno is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 09:35 AM #29
westsideriderz15 westsideriderz15 is offline
westsideriderz15 is on a distinguished road
Had the same thoughts myself about load and speed rating, til i checked out the oem spec. Total garbo OEM Tires
westsideriderz15 is offline   Reply With QuoteReply With Quote
advice , minimum , rating , speed , tires
Advice on Purchasing 2000 SR5 5-speed leftcoastsurf 3rd gen T4Rs 11 10-06-2015 01:19 AM
Speed rating and load rating Gecko123 4th Gen T4Rs 4 11-01-2012 04:54 PM
Tire Load and Speed Rating LodeRunner 3rd gen T4Rs 6 02-19-2011 09:56 AM
New BFG AT KO speed rating JB. 4th Gen T4Rs 34 01-24-2008 10:18 PM
Costco trying to install Revo's frankvh 4th Gen T4Rs 15 11-01-2005 10:36 AM
