Originally Posted by Jetboy
Why were they doing anything with brake cleaner?
Also - 83 lb/ft on the lug nuts should not cause any damage to anything on the vehicle. You'd need something like 100 times the force to get into the range of damaging anything. The failure strength is probably in the range of 7,500 ft/lb. In short - it's pretty unlikely that they damaged your axle by torquing the lug nuts. If they somehow damaged your axle - it wasn't related to torquing the lug nuts on.
costco idiot torqued the nuts with the wheels OFF THE GROUND !!! the wheels were wacking back and forth ... drove home and had vibration .
I did the U joint repair bearings looked good not rusted but had damage on the needle bearings.. you torque wheels on the ground they are not professionals. brake cleaner is acetone spray it on your paint then you will see how the idiots did the damage.
my hubs had small amount of anti seize on it paint like amount very little so they sprayed the steel hub and then the painted aluminum wheels ..did not use rag just sprayed the sh*t of it ..
