Old 02-01-2022, 11:19 AM #1
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Cracked radiator and radiator core support
Scratched a tree with my radiator in the forest off roading. I cracked it badly at the bottom in the middle of the forest solo! Drove it off the trail to the nearest dirt road about a mile or two away. Hoping someone would drive by me and get me some assistance. No phone signal. Anyways I drove it until the temp gauge got to hot and shut it down to preserve my mint engine. Two days later I finally got found and home. I filled the radiator with water and it pours out the bottom immediately. I wanted to see if the engine would start before pulling the radiator out but it would only crank and not start. The engine oil is clear and new so I really hope I didn't do any damage to the engine. I'm pretty sure the truck won't start with a busted radiator???? Is this right? I wanted to hear my engine run ugh just to make me feel better. My poor girl! Anyone have experience or knowledge on this subject?
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 02-01-2022, 06:46 PM #2
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Compression test ✔️ faster than this ferry forum can respond with some knowledge. That's what was worrying me the most, the head gasket. Not sure what is preventing it from starting maybe a sensor or limp mode? Y'all don't know, maybe a rare few can reply! Onward with repair.
Old 02-02-2022, 11:09 AM #3
John in NC John in NC is offline
Real Name: John
John in NC will become famous soon enough John in NC will become famous soon enough
Real Name: John
I don't know, maybe 'we' here don't know, it's such a specific situation I personally would hate to give some advice like, "Oh it'll be fine replace the broken parts, add fluids and go for it!" and you end up messing your engine up.
John in NC is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 11:46 AM #4
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
The truck (engine\ECM) doesn’t know that radiator is busted… ECM knows the temperature of engine\coolant but that is all… so no starting is related to some other problem your 4Runner now has…
Without doing basic troubleshooting including pulling the codes there is no way to suggest what has happened…
Wild guesses here, but since you mentioned that radiator core support is also broken, is it possible that there are other damage(s) -broken wires, ripped sensors, etc.… and if the truck spend couple days in the forest, maybe some critters got in the engine bay and chewed some wires...?
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 08:14 PM #5
Jakeepoo3's Avatar
Jakeepoo3's Avatar
The thing is I want to make sure my engine isn't messed up before I do the repairs. Thanks for your input sir!
Old 02-02-2022, 08:23 PM #6
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
\the engine cranks and you stated the engine does not run ?
put a scan tool on the OBDII turn the key on not cranking .. look up codes .. reset codes then crank the engine ...post codes on the forum..
now if your starting the engine when it is hot,,, probably the timing chain will snap off or break ..
catrains is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 08:26 PM #7
Jakeepoo3's Avatar
Jakeepoo3's Avatar
That is the same thing I'm thinking. The head gasket/compression is fine and the whole inside of the truck got wet and fogs up from the busted coolant system. There are sensors mounted on the radiator support. I believe they are airbag or crash sensors?? I don't have af_ucking $400 repair manual to find what should be easy to access to the vehicle you own. No critters, I was trapped in the truck until I was found 😆 I'm dirty south old school! Walked five miles to the highest elevation just to get a 911 signal and be found whilst burning a fire to keep from freezing to death 👽
Old 02-02-2022, 08:29 PM #8
Jakeepoo3's Avatar
Jakeepoo3's Avatar
I ran it until it hit H on the temp gauge. The ECM Is what I hope is preventing it from starting via sensor\sensors..
Old 02-02-2022, 09:13 PM #9
Land Cruiser Land Cruiser is offline
Land Cruiser is on a distinguished road
PM sent
Land Cruiser is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 10:23 PM #10
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Pull codes manually via DLC tomorrow didn't think of that but it may shed some light on the no start. Thanks! This b!tch better not f_ck me after 12 years of love. Never overheated until this incident and oil is completely clear with no milky residue. No condensation on oil fill cap. No moisture upon inspection of spark plugs, beautifully clean. Compression 100✓ indicating head gasket is fine. She better not f_ck me after I replace the radiator and check the sensors up there, I love her. 😩
Old 02-03-2022, 12:08 AM #11
Jeremy556's Avatar
Jeremy556's Avatar
Are you saying your compression test got 100psi? That is quite low, depending on how you did it, but more importantly, how close were they to each other?
Can you not flat tow it out? Any members in the area with Techstream and a cable you could borrow?
Old 02-03-2022, 12:21 AM #12
Jeremy556's Avatar
Jeremy556's Avatar
This forum tends to be mostly about putting the same overland decorations as every 4runner they see on Instagram. A lot of knowledgeable people rarely visit the forum any more, if at all.
Old 02-03-2022, 09:39 AM #13
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
How big of tires can I fit and what lift should I get?
Forgetful is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 12:11 PM #14
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Seems odd the inside would have an issue if it was just the radiator.
Yellow sensors/ yellow wire wrap are the airbag sensors.
nglayton is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 12:50 PM #15
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Yeah, this ferry forum...
Anyway, 100 psi during a properly performed compression test, is low as already mentioned. A leakdown test would be appropriate.
One clue that was briefly mentioned was that the interior got wet. If the interior was under water, that means electrical components and ECU's likely got wet. Pulling out the interior and drying and checking all electrical connections, and all ECU's/ BCM's, would be a good place to start.
If all the coolant leaked out, the engine can get much hotter before the ECT sensor senses a too hot condition. This is bad for the deck and heads that need to be flat within a small tolerance, to seal with the headgasket(s).
02SE is offline   Reply With QuoteReply With Quote
cracked , drove , engine , radiator , start
Has anyone replaced their radiator core / tank(s)? eurasiaoverland 3rd gen T4Rs 1 05-04-2016 01:43 PM
1st gen radiator support Justin_W Classic T4Rs 1 08-11-2014 07:43 AM
radiator core support mounts Kenjan 3rd gen T4Rs 2 06-18-2012 06:00 PM
Core radiator value......... 77'911 Classic T4Rs 7 05-07-2012 11:55 PM
1995 4runner core support/radiator support bolted vs. welded into frame jlfindley74 Classic T4Rs 3 12-28-2010 05:59 PM
