09-19-2019, 11:09 AM
#16
you have a trailer plug? you could find the correct pins and slow charge the battery through there. it will be a bit tricky to wire in, but would be possible.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
09-19-2019, 11:16 AM
#17
Interesting idea... I just need the power for remote to open electric door Lock, then I can open the hood and charge the battery.
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
09-19-2019, 11:35 AM
#18
I don't think this works. Looks like trailer blush got a relayed power which only activates when vehicle is started. All pins are 0.
09-19-2019, 11:46 AM
#19
Originally Posted by AlexJet
Unfortunately no
Is AAA something you WANT? I had a car problem once and had no AAA. They let me sign up for a year over the phone, and then came out to help. Not sure if they still do this.
09-19-2019, 11:54 AM
#20
Originally Posted by rwh963
call local police dept.? they do this service.
Not in Canada
Not in most places in the states either. Maybe if you live in Mayberry...
When in trouble - obfuscate
09-19-2019, 11:55 AM
#21
can you access the starter from underneath? That may be a place to hook the charger up to? Just a guess...
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
09-19-2019, 01:23 PM
#22
This tool:
09-19-2019, 01:48 PM
#23
im not sure how these are wired. but im sure I read where someone else did exactly that, and was able to put some charge into the battery via the trailer plug.
how about the starter posts? can you get to the starter?
09-19-2019, 03:46 PM
#24
Pay $100 to the tow guy or lock smith to use slim jim to open it. It beats destroying your truck using creative methods.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
09-19-2019, 04:04 PM
#25
i guess i live in Mayberry! I have definitely seen local police using slim jim to unlock cars for people.
either do it yourself, or call a tow service and pay them to do it. or move to a small town!
09-19-2019, 04:12 PM
#26
Easy,
Pull back drivers side fender liner. You will see the cable to pop the hood. Follow the line and look for a section of exposed cable, grab the metal cable part with a pair of pliers. If you don't care about the bushings you can just yank the whole cable+cable cover but you might bust plastic clips holding the cable and cable cover in place.
09-19-2019, 04:50 PM
#27
I was on vacation and when I come back the battery is dead on my 5th Gen. Not even lights flash when I push the button on remote.
Does anyone knows how to open the hood from outside, so the battery can be recharged? Door lock cylinder is broken and 5th Gen for some reason now has only driver door lock cylinder, my 4th Gen has one on the driver door and another on the hatch door, but for some reason Toyota stop making this.
I thought my 5th gen lock cylinder was broken as well, I ended up quickly putting the key in and out while lightly turning and it eventually went and now work fine, its like it got gummed up from not being ever used. Have you tried just messing around with it a bunch to see if it goes?
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
09-19-2019, 05:28 PM
#28
You might be forced to flex a door from the top corner closest to the rear and get a long, stiff object to slip into the crack while the door is flexed to press the unlock button. Use a wedge of some sort to hold the door while it's flexed.Can't say for sure whether this will permanently flex your door or not.
That's the only way I can think to help you out. You need about 2 people to pull and hold the door (AMA will insert an inflatable device to achieve this goal) while one person inserts the rod or coat hanger or whatever to press the unlock button. Wait.. no battery, no power locks. umm, coat hanger and try to get the flipy locky thing? haha man, that's a tough spot to be in.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
09-19-2019, 06:31 PM
#29
So after this I bet you will be looking into getting your lock fixed
09-19-2019, 07:26 PM
#30
Real Name: Ted A Hamilton
Interesting. My 2016 SR5 (not premium) has key lock in driver door and hatchback. Don’t recall ever using them, but gonna do it periodically after seeing this.
BTW had to use AAA a few years ago with the air bag approach to get into the wife’s 2008 Lexus ES 350 when the batt died and the fob did not have the removable key thingy on it.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
