Old 09-19-2019, 07:32 PM #31
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Originally Posted by Salvo Jimmy View Post
Interesting. My 2016 SR5 (not premium) has key lock in driver door and hatchback. Don’t recall ever using them, but gonna do it periodically after seeing this.
BTW had to use AAA a few years ago with the air bag approach to get into the wife’s 2008 Lexus ES 350 when the batt died and the fob did not have the removable key thingy on it.
the hatch is still an electric latch though
jhguth is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 07:32 PM #32
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Originally Posted by rwh963 View Post
i guess i live in Mayberry! I have definitely seen local police using slim jim to unlock cars for people.
either do it yourself, or call a tow service and pay them to do it. or move to a small town!
Moving actually sounds like a great idea.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 07:46 PM #33
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
Problem is probably solved by now, and what I post may not apply to the original person posting. But ...
My ‘18 SR5 has key locks on the driver’s door and rear liftgate. It don’t hurt to occasionally use it, or lube it with graphite, to keep things working in case this situation occurs. Turning the key to roll down the rear window also unlocks all four doors (locking them when you roll up the window), though in a dead battery situation this won’t work to get you inside.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 11:39 PM #34
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Why would the "Limited" not have a rear door that can be unlocked with a key?
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 06:02 AM #35
philipn126 philipn126 is offline
philipn126 is on a distinguished road
Not sure. My limited has a key lock on the drivers side door...
Sent from my SM-G965U using Tapatalk
philipn126 is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 06:55 AM #36
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
Well Crap😳😆
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 12:16 PM #37
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Originally Posted by the_fornicator View Post
You might be forced to flex a door from the top corner closest to the rear and get a long, stiff object to slip into the crack while the door is flexed to press the unlock button. Use a wedge of some sort to hold the door while it's flexed.Can't say for sure whether this will permanently flex your door or not.
That's the only way I can think to help you out. You need about 2 people to pull and hold the door (AMA will insert an inflatable device to achieve this goal) while one person inserts the rod or coat hanger or whatever to press the unlock button. Wait.. no battery, no power locks. umm, coat hanger and try to get the flipy locky thing? haha man, that's a tough spot to be in.
I agree, because I said the exact same thing EXCEPT you can grab and pull the hood latch with a long enough tool
https://www.toyota-4runner.org/3358290-post10.html
Some good out of the box thinking going on in this thread, like
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 12:28 PM #38
IrieRider's Avatar
IrieRider IrieRider is offline
IrieRider is on a distinguished road
IrieRider's Avatar
Originally Posted by AlexJet View Post
Driver door only, but it's the only one which has the Lock cylinder
No company uses slim jims or lock picks for door entry, its an inflatable wedge and a massive long metal bendy stick haha...
IG 4runner.gunner
IrieRider is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 01:18 PM #39
jrandom's Avatar
jrandom's Avatar
YouTube
2013 TE w/ KDSS Nav
Old 09-20-2019, 05:42 PM #40
DAW89446's Avatar
Real Name: Dave
DAW89446's Avatar
Real Name: Dave
Might be his has the optional “Smart Key”, or proximity key so you don’t have to use the fob to enter the locked vehicle as long as the fob is in your pocket. The driver door handle senses the fob and your hand near the handle.
Dave
2018 4Runner SR5
Old 09-20-2019, 05:56 PM #41
No models have a rear door that can be unlocked without power
Old 09-21-2019, 11:56 AM #42
Nope...my bad.
The 4R is my wifes. I've been under the hood many times for maint, but never bothered to notice the rear door has no key slot.
Bad idea Toyota, along with the missing transmission fluid dipstick.
Old 09-21-2019, 11:35 PM #43
DAW89446's Avatar
Real Name: Dave
DAW89446's Avatar
Real Name: Dave
My 2006 Honda CR-V I traded in on my Outback had no dipstick either. I guess it’s a trend. I don’t mind. I hated checking auto transmission levels. Mile long, bendy dipsticks and inconsistant readings on most of my cars ...
Dave
2018 4Runner SR5
Old 09-22-2019, 01:59 PM #44
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I seem to remember, that a few years back, there was a thread dealing with a broken hood release cable. Owner was in the same boat being unable to open hood. The fix was a tool made to trip the hood latch from the front. I bet the dealers have one.
Old 09-22-2019, 05:03 PM #45
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
What rock have you been living under? How did you miss the fact that not having a key is the greatest upgrade in the history of the automobile?!?! It's so awesome.....you don't have to...or maybe it's that you do get to.....well, I don't really know but they tell me it's the greatest.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
battery , cylinder , dead , door , gen
What to do if your battery's dead? Ray Dunakin Maintenance/Detailing 5 02-19-2016 12:15 PM
dead battery wshiverick Classic T4Rs 6 08-20-2014 02:43 AM
Dead battery? or something else? tcatl Problems & Warranty Issues 4 09-03-2012 12:23 AM
Help dead battery and can't open doors... Nealf2002 4th Gen T4Rs 17 04-28-2012 07:26 AM
Dead Battery westwind77 5th gen T4Rs 16 01-05-2011 09:36 AM
