09-19-2019, 07:32 PM
#31
Originally Posted by Salvo Jimmy
Interesting. My 2016 SR5 (not premium) has key lock in driver door and hatchback. Don’t recall ever using them, but gonna do it periodically after seeing this.
BTW had to use AAA a few years ago with the air bag approach to get into the wife’s 2008 Lexus ES 350 when the batt died and the fob did not have the removable key thingy on it.
the hatch is still an electric latch though
#32
Originally Posted by rwh963
i guess i live in Mayberry! I have definitely seen local police using slim jim to unlock cars for people.
either do it yourself, or call a tow service and pay them to do it. or move to a small town!
Moving actually sounds like a great idea.
When in trouble - obfuscate
09-19-2019, 07:46 PM
#33
Real Name: Dave
Real Name: Dave
Problem is probably solved by now, and what I post may not apply to the original person posting. But ...
My ‘18 SR5 has key locks on the driver’s door and rear liftgate. It don’t hurt to occasionally use it, or lube it with graphite, to keep things working in case this situation occurs. Turning the key to roll down the rear window also unlocks all four doors (locking them when you roll up the window), though in a dead battery situation this won’t work to get you inside.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
09-19-2019, 11:39 PM
#34
Why would the "Limited" not have a rear door that can be unlocked with a key?
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
09-20-2019, 06:02 AM
#35
Not sure. My limited has a key lock on the drivers side door...
Sent from my SM-G965U using Tapatalk
09-20-2019, 06:55 AM
#36
Real Name: Ted A Hamilton
Well Crap😳😆
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
09-20-2019, 12:16 PM
#37
Originally Posted by the_fornicator
You might be forced to flex a door from the top corner closest to the rear and get a long, stiff object to slip into the crack while the door is flexed to press the unlock button. Use a wedge of some sort to hold the door while it's flexed.Can't say for sure whether this will permanently flex your door or not.
That's the only way I can think to help you out. You need about 2 people to pull and hold the door (AMA will insert an inflatable device to achieve this goal) while one person inserts the rod or coat hanger or whatever to press the unlock button. Wait.. no battery, no power locks. umm, coat hanger and try to get the flipy locky thing? haha man, that's a tough spot to be in.
I agree, because I said the exact same thing EXCEPT you can grab and pull the hood latch with a long enough tool
https://www.toyota-4runner.org/3358290-post10.html
Some good out of the box thinking going on in this thread, like
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
09-20-2019, 12:28 PM
#38
Originally Posted by AlexJet
Driver door only, but it's the only one which has the Lock cylinder
No company uses slim jims or lock picks for door entry, its an inflatable wedge and a massive long metal bendy stick haha...
IG 4runner.gunner
09-20-2019, 05:42 PM
#40
Real Name: Dave
Real Name: Dave
Might be his has the optional “Smart Key”, or proximity key so you don’t have to use the fob to enter the locked vehicle as long as the fob is in your pocket. The driver door handle senses the fob and your hand near the handle.
Dave
2018 4Runner SR5
09-20-2019, 05:56 PM
#41
No models have a rear door that can be unlocked without power
09-21-2019, 11:56 AM
#42
Nope...my bad.
The 4R is my wifes. I've been under the hood many times for maint, but never bothered to notice the rear door has no key slot.
Bad idea Toyota, along with the missing transmission fluid dipstick.
09-21-2019, 11:35 PM
#43
Real Name: Dave
Real Name: Dave
My 2006 Honda CR-V I traded in on my Outback had no dipstick either. I guess it’s a trend. I don’t mind. I hated checking auto transmission levels. Mile long, bendy dipsticks and inconsistant readings on most of my cars ...
Dave
2018 4Runner SR5
09-22-2019, 01:59 PM
#44
I seem to remember, that a few years back, there was a thread dealing with a broken hood release cable. Owner was in the same boat being unable to open hood. The fix was a tool made to trip the hood latch from the front. I bet the dealers have one.
09-22-2019, 05:03 PM
#45
Real Name: KE0OIC
Real Name: KE0OIC
What rock have you been living under? How did you miss the fact that not having a key is the greatest upgrade in the history of the automobile?!?! It's so awesome.....you don't have to...or maybe it's that you do get to.....well, I don't really know but they tell me it's the greatest.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
