Old 09-19-2019, 11:02 AM #1
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
iphone windshield mount above mirror
I am searching for a suitable mount for an iphone XS Max that would put it above the rear view mirror. Planning to use it as a display for an OBDLink MX+ and potentially just a phone holder as well. I find that the phone is too big for the lowest dash compartment and other than throwing it in the console I dont see many great alternatives (excluding the dash mounted options). Anyone tried this location?
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 11:43 AM #2
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Put the phone in the cup holder and watch the road ahead, not the display.
There are a lot of news reports about distracted driving and people crossing over the line and crashing, usually head on into another vehicle.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 12:17 PM #3
Thanks coach, ill keep that in mind. I hope you don't look at your navigation in the dash while driving either.
2019 SW TRDORP
Old 09-19-2019, 12:36 PM #4
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough BadTrainDriver will become famous soon enough
ProClip mount works excellent, FYI. Not as high up as you're looking for, but works great for line of site for a quick glance.
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 01:06 PM #5
I am trying to keep it up out of the way, but easily viewable when off road for tire pressures /trans temps. If I wasn't OCD I would just mount it to the dash lol.
2019 SW TRDORP
Old 09-19-2019, 01:13 PM #6
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
proclip makes three different mounts for the 4R, One that goes on the driver side pillar, either center dash vents or passenger side console. 2017 Toyota 4Runner Dashboard Mounts | ProClip USA
use the one you would like and get a ram mount ball base, ram arm length of your choice and x-grip (large) to hold your phone.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 01:39 PM #7
BobsTrail's Avatar
Real Name: BobH
BobsTrail's Avatar
Real Name: BobH
Toyota navigation, not worth looking at.
Old 09-19-2019, 01:41 PM #8
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
i mounted a magnetic mount just to the left of that vent that places the phone in a similar position without blocking any air
tm965 is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 02:01 PM #9
That pillar mount is a real possibility, thanks!
2019 SW TRDORP
Old 09-19-2019, 02:13 PM #10
this is what i use. 3m tapes to the dash besides the vent securely. Phone stays put with the magnet
https://www.amazon.com/gp/product/B00I608BJ8/
Old 09-25-2019, 03:29 PM #11
trying this as a solution
I was hoping to have the phone up high, but this may work. I might have spent 30 minutes on this easily removable mod. If someone posted this here before, I failed to find it.
Ground down a wing nut
[IMG][/IMG]
Used a hot knife to make it fit in a switch hole cover
Screwed in the Ram mount ball fitting
Snapped into left side, it doesn't block the vent at all.
Although the weight makes it lean forward, I cant get it to pop out of the dash cover when pulling on it
2019 SW TRDORP
Old 09-25-2019, 03:36 PM #12
samwhich's Avatar
samwhich samwhich is offline
samwhich has a spectacular aura about samwhich has a spectacular aura about
samwhich's Avatar
[IMG][/IMG]
Nice! very clever way for a non-invasive mount solution!
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
samwhich is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 03:40 PM #13
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
sorry to derail this thread, but what app is that? i would like to know the PSI of all 4 tires too
tjnptel1 is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 03:49 PM #14
They are customizable via obdlink app, I use an OBDLINK MX+
2019 SW TRDORP
Old 09-25-2019, 04:35 PM #15
4Regrets 4Regrets is offline
Real Name: Ben
4Regrets will become famous soon enough
Real Name: Ben
Thumbs down
Turn your damn phone OFF and put it in the center console if you're operating a vehicle. I turn the nav screen off the vast majority of the time I'm behind the wheel too. And I have my settings so the in-dash screen is blank too. I focus on the road ahead, behind and to my sides only while I'm driving, and that's the only thing you should be paying attention to too.
2019 Midnight Black Limited with Beige Interior
275/70R17 Nokian Hakkapeliitta LT3 on FN FX Pro -- Winter
275/70r17 BFG KO2 on stock Trail wheels for summer/shoulder seasons
H11 to H9 low beam conversion
4Regrets is offline   Reply With QuoteReply With Quote
dash , iphone , mirror , mount , phone
sloppy rear mirror repair, no post show simple windshield mirror Seasparrow 4th Gen T4Rs 1 04-29-2019 09:39 AM
iPhone Mount kittyhawksurf 5th gen T4Rs 45 08-10-2016 11:24 PM
Iphone 5 mount omaguz 5th gen T4Rs 21 05-27-2016 02:20 PM
iPhone 4S Mount for 5th Gen Calpchen 5th gen T4Rs 12 11-08-2011 11:02 AM
Best iPhone 4 car mount for T4R? 4wordSOUL General Discussions 12 10-26-2011 01:26 AM
