Old 09-22-2019, 02:59 PM #1
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Proper way to engage 4wd
Soon to be 2020 SR5 premium 4wd owner.
Correct me if i am wrong and add tips.
From regular 2wd to 4hi coast straight line off the gas off the brakes around 35mph engine running squeeze plastic lock thing and rotate to 4hi and wait for dash to indicate engagement and then OK to accelerate and drive on off road conditions to prevent bind.
This right?
From 4hi to 4lo or from 4lo to 4hi - engine running idling shift tranny to neutral and step on brake squeeze lock thing push down on knob and rotate to 4lo and pray no grinding. Is this right?
Can one go from 4lo straight to 2hi with tranny in neutral or first go to 4hi coast a little and then to 2wd?
Best to shift in and out of 4lo with engine off?
LAST QUESTION - FRIEKEN caps lock.... If for whatever dumb reason rear gets stuck on 2wd your only option is to go to 4lo since front wheels will not be rolling to be able to go into 4hi?
Will be my first 4wd vehicle. Tips ALWAYS APPRECIATED FROM THE KNOW GUYS.
If you gonna laught at me go ahead and get it outa your system to move on.
  Reply With QuoteReply With Quote
Old 09-22-2019, 03:03 PM #2
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Ok to leave parked in 4wd 4lo or 4hi?
Old 09-22-2019, 03:19 PM #3
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
Owner's manual says it all.
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 03:26 PM #4
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
10 4 boss... "Costco dealer rep" from today said 4 weeks.
Other "costco rep" said 2 to 3 weeks.
Old 09-22-2019, 03:27 PM #5
LimeLED's Avatar
LimeLED LimeLED is offline
LimeLED will become famous soon enough LimeLED will become famous soon enough
LimeLED's Avatar
This right?
In SR5, you can shift from H2 to H4 at under 62 MPH (50 MPH with TRD Off-Road or Pro). Just don't do it with the wheels spinning (losing traction).
Correct.
Should be able to go directly.
No, do it with the engine running.
No, you can go to either.
Yes.
See above in bold. slprciv is correct--this is all in the owner's manual. You can download the 2020 manual here: https://www.toyota.com/t3Portal/docu...f/OM35B54U.pdf Skip to page 293.
2023 4Runner TRD Pro, Midnight Black
2022 4Runner TRD Pro, Lime Rush
2022 4Runner TRD Off-Road Premium, Magnetic Gray (SOLD)
2018 4Runner TRD Off-Road Premium, Super White (SOLD)
LimeLED is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 03:55 PM #6
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Dont worry about memorizing it^ its printed on the visor!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 04:23 PM #7
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
4Hi is not any speed. It's 55mph and under. But frankly you shouldn't be going that fast if you realize you need 4Hi. Shifting into and out of 4Hi is "on the fly" but I typically let off the gas when I'm going either way
4Lo is completely stopped and in neutral, then engage 4Lo, then back into drive once it engages
llDemonll is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 05:07 PM #8
slanger91 slanger91 is offline
slanger91 is on a distinguished road
Big help, thank you!
slanger91 is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 06:31 PM #9
Shmeado Shmeado is offline
Shmeado is on a distinguished road
Also worth noting that sometimes the gears won't be aligned when trying to get into 4lo, you can tell as the dash light blinks whilst beeping at you. You just need to roll forward and try it again.
All of this is explained on the back of the drivers sun visor (at least in a '13 Limited)
Shmeado is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 08:37 PM #10
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Flip down the drivers side sun visor for instructions. No need to find the manual.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 09:16 PM #11
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
I am not a believer in on the fly engagement unless it is totally necessary. I always stop, put in neutral, make your selection and see on the dash light 4x4 turns on then go. I been doing this on my 08 FJ and now with my 18 4runner.
2018 4Runner SR5
2002 4Runner Limited (low mileage, my dad purchased new)
2008 FJ with Off-Road Package (191k miles) Sold 6-19
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 09-23-2019, 09:36 AM #12
Whippersnapper02's Avatar
As mentioned before, it won't always go right i to low range from 2wd and sometimes it won't even shift into 4wd high from a stop. I always shift into 4wd high while driving forward then stop for low range.
Old 09-23-2019, 10:56 AM #13
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I don't think the computer will let you screw it up. Someone can probably confirm, but I think if you're over 55, it won't shift into 4hi until your speed drops. I have a trail edition with the lever. I engage at any speed - I've done it at 70mph with no issues. Lots of times. There's an internal clutch that brings the rotating assembly up to speed. So when the dog clutch teeth engage internally they're already synchronized in speed before they engage. The same is true for the front axle disconnect.
The 4Lo - that one you need to be stopped for. And in neutral. I'm sure the electronics won't let you engage at speed. That would cause a catastrophic failure. But there's no way Toyota would setup the electronics to allow that to happen if you just moved the dial to the wrong spot.
Old 09-25-2019, 12:08 AM #14
Maingear Maingear is offline
Maingear is on a distinguished road
Correct, i switch in and out at high speeds when I drive in and out of rain and the computer makes the truck beep and flashing light when drivetrain request is denied. It was a fustrating process to get into low 4 until after 150,000 mi, finally broke in.
Also turning in parking lots or into driveways in 4hi the tires grab making the turn radius larger.
2013 T4R SR5 stock 200,000 mile club
Maingear is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 12:40 AM #15
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
A little confused when u said axle disconnect. I know on the ford broncos one had to get out and rotate to lock.
The front axle disconnect is that an additional step BESIDES the rotational knob or the 4wd system and electronics take care of this.
2wd , 4hi , 4lo , 4wd , lock
4th gen, the proper way to engage center diff lock button? neowig 4th Gen T4Rs 9 01-10-2016 01:48 PM
Looking for the proper wireless fob PDX98Limited 3rd gen T4Rs 11 03-15-2015 02:57 PM
Why you should use the proper plugs mphudak 3rd gen T4Rs 3 01-17-2015 02:03 PM
Proper lug torque WindomEarles 5th gen T4Rs 5 06-13-2012 11:14 PM
Proper RPMS for MPH hittnrunn 4th Gen T4Rs 7 01-24-2006 12:44 PM
