Old 09-24-2019, 11:56 AM #1
alext72888's Avatar
alext72888 alext72888 is offline
alext72888 is on a distinguished road
alext72888's Avatar
Cargo Power Outlet Usage Question
What do you guys use that rear cargo outlet for? I know the power is a bit on the low side.
I was hoping to run some kind of vacuum cleaner from it but I don't think it will have enough power.
Is there a vacuum cleaner that would work? Maybe even some type of small shop vac?
The Water Bear - Instagram (photos of mods & progress)
2015 Attitude Black 4runner Trail Premium w/ KDSS. 2.5f/1.5r Spacer Leveling Kit. 285/70/17 Firestone Destination AT Load rating P
alext72888 is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 12:04 PM #2
DavidR1's Avatar
DavidR1 DavidR1 is offline
DavidR1 will become famous soon enough
DavidR1's Avatar
Better yet, who has upgraded the voltage on this unit?
I've run several things from mine, a computer, breast pump (came in handy fairly often for this), air compressor, etc. It's nice to have it back there but would be more useful for camping if it had enough power to supply a small burner for cooking.
DavidR1 is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 12:19 PM #3
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
I use it to power my Dometic fridge.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 04:06 PM #4
Ionyx Ionyx is offline
Ionyx is on a distinguished road
I used it for my soldering iron and my Dremel.
I think you should be ok to vacuum for a little bit probably not for a detail job!
Ionyx is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 04:15 PM #5
TCLLC TCLLC is offline
TCLLC will become famous soon enough
I did this, its constant 12 volt from the battery when its on, I have my fridge and a 12 volt outlet, right now with usb plugs in it
Cargo Power Outlet Usage Question-img_0817-jpg
TCLLC is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 04:38 PM #6
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
i just checked a small 1 gallon shop vac and even that was over 700 watts, so i bet you'll have a tough time finding one under 400 watts
they make 12v automotive vacuums though and also battery powered shop vacs
more... voltage? (lol, jk)
for more wattage run wires from the battery and install a larger inverter (a burner will probably pull more than your alternator, so you'll need a battery bank or something to cook)
jhguth is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 05:34 PM #7
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I've run a Dremel from mine, charged some 2-way radios, ran a compressor for an air mattress and ran some christmas lights.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 05:53 PM #8
4Regrets 4Regrets is offline
Real Name: Ben
4Regrets will become famous soon enough
Real Name: Ben
Portable battery banks are more practical than idling your vehicle to run a small piece of electronics. I've wanted to use mine for some tailgating related shenanigans, but I can't bring myself to hang out with the car idling for what is truly the definition of "no good reason."
2019 Midnight Black Limited with Beige Interior
275/70R17 Nokian Hakkapeliitta LT3 on FN FX Pro -- Winter
275/70r17 BFG KO2 on stock Trail wheels for summer/shoulder seasons
H11 to H9 low beam conversion
4Regrets is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 06:44 PM #9
WokkerK's Avatar
WokkerK WokkerK is offline
Real Name: Wokker
WokkerK is on a distinguished road
WokkerK's Avatar
Real Name: Wokker
I ran the inflation blower on my queen air mattress from it this weekend.
2016 Super White SR5 Premium - "WOKKERABOUT"
IronMan 3" Stage 3 / Camburg Racing UCA's / Nitto Trail Grapplers (285/75/17)/ Method 701 Wheels / Prinsu Full Length Roof Rack / NFab Ladder / Baja Design Squadron Sport Fogs and ditch lights / Lasfit Pro LED Headlights / ARB Awning / RSG Angled Sliders / Custom Built Storage Drawers / Dobinson's Diff Drop / Expedition Essentials T4RPAM / iKamper Skycamp Mini / Switch Pro 9100 / C4 LoPro Bumper / Warn VR EVO 10S Winch /
WokkerK is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 10:08 PM #10
Backwood's Avatar
Backwood Backwood is offline
Backwood will become famous soon enough
Backwood's Avatar
I keep one of those Plug-In air fresheners in mine... Only turn it on occasionally, and it is almost always while im driving but i only leave it on for 10 minutes or so at a time... By that point the entire 4runner smells great so i turn it off.
Backwood is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 11:34 PM #11
alext72888's Avatar
alext72888's Avatar
That's actually a really good idea!
Old 09-25-2019, 09:39 AM #12
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
I've used it to charge my drone batteries while driving, and have had people plug in laptops to charge while driving/working in the back plenty of times.
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 11:53 AM #13
bobdacat bobdacat is offline
bobdacat is on a distinguished road
I use a crock pot for tailgating, power tool battery charger, and a electric pole saw. Just got to remember to turn it back on, shuts off everytime you turn off engine.
bobdacat is offline   Reply With QuoteReply With Quote
cargo , cleaner , outlet , power , vacuum
Questions about the inverter/power outlet in the cargo space... acolle 5th gen T4Rs 9 01-02-2017 01:47 PM
120v Outlet Usage Ruthven13 4th Gen T4Rs 6 09-26-2016 09:50 PM
4lo usage question shaftymcgee7 5th gen T4Rs 16 12-29-2012 06:53 PM
Rear power outlet (cigarette) constant power? Sloan694 5th gen T4Rs 3 06-27-2012 08:41 AM
4WD Usage Question aeroneer1 3rd gen T4Rs 14 02-11-2012 05:15 PM
