Old 09-26-2019, 04:04 PM #16
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by Crikeymike View Post
Wow!! That's pretty incredible.
I've thought about RTT security a lot in the past, but then just gave up. You can cut the cross bars off, or unbolt them. You can undo the bolts that clamp the tent rails to the cross bars. You can use bolt cutters to cut one bolt from each of the 4 mounts, and slide the other part out of the way....
One way or another, if someone wants it, they'll figure out how to get it off pretty quick, and they won't have any regard for your paint, or scratching the car, while they do it either...
I've seen some hard shells that have the cross bars of the tent embedded into the base, so those would be harder to get to, but then there's till the actual cross bars of the rack that could be taken off.
Moral of the story is: Whatever can be bolted-on can be bolted-off just as easily.
Pretty wild right… It’s amazing how crappy a lot of consumer security products are. I can pick, bypass, or decode just about every Master Lock product I ever bought.
Don’t watch too many of those videos because it will cost you once you realize what good locks are and where to get them. Most all my personal stuff is now from high security brands like Mul-T-Lock, Assa Abloy, and Medeco. Pretty much impossible to pick or bypass… stainless steel anti-drill pins and bearings. Plus I could give you my house key and just about guarantee you won’t be able to copy it.
But I agree with you, if they want it, they will find a way while showing absolute disregard for your property… This is why I always revert back to the insurance argument. I look at insurance as a type of security tool.
Old 09-26-2019, 04:14 PM #17
Crikeymike
Guest
Posts: n/a
Crikeymike
Guest
Posts: n/a
I still surprise people with my ability to pick the lock on the paper towel holder in the bathroom, so I'll stick with this level of burglary at this point. hahahahha
Old 09-26-2019, 04:41 PM #18
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
It seems silly to worry about special nuts to prevent removal of the crossbars when the whole rack is just held on by 8 bolts.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 03:15 PM #19
mochacho mochacho is offline
mochacho is on a distinguished road
Originally Posted by ProfessorP View Post
I replaced all of my Victory 4x4 roof rack button head screws with powder coated stainless steel spanner security screws from route66mods.com They don’t stock them regularly, but they ordered them directly from McMaster Carr and powder coated for about the same cost as the rest of their screws.
The driver bit for those screws is almost impossible to find locally, so most people won’t have one available. Not perfect, but at least it’s a deterrent. My goal is to make it a little bit of a pain in the a$$.
The most expensive thing I stand to lose is a rotopax gas can or a high lift jack if the thief just happens to have a #14 bit and wants to go through the trouble.
Ultimately, if a serious thief wants it, no lock or security measure will stop them.
I did the exact same. But on each cross bar I only changed one screw per side.
mochacho is offline   Reply With QuoteReply With Quote
bolts , easy , rack , rtt , theft
Theft devices? FoozGrind 5th gen T4Rs 26 01-05-2017 01:41 PM
5th Gen Theft GzTEP 5th gen T4Rs 24 09-21-2016 11:33 PM
A little help if possible - theft Matt fe2o3 5th gen T4Rs 11 01-28-2015 10:51 AM
MOD theft? Vegas 5th gen T4Rs 18 12-17-2012 11:24 AM
Disabling vehicle for storage and anti-theft protection michael90630 4th Gen T4Rs 7 11-12-2010 09:50 AM
