Old 09-25-2019, 05:04 PM #1
PoopSmith PoopSmith is offline
PoopSmith is on a distinguished road
CB Radio Install - Writeup
Recently my wife and I took the 4R and my 92 Pickup up to Silver Lake,
and I wanted a way to talk to her while on the dunes. I looked at different CB mounts people had done and they all looked too aftermarket. I like more of an OEM look, so this is what I came up with;
I spent too much time deciding on a radio. Ended up going with the AnyTone Apollo 1. The reviews were meh, but the price was fair and I liked how the display was on the handset.
Amazon.com: AnyTone APOLLO I 10 Meter Amateur Radio for truck, LCD display and function key in microphone, AM PEP power over 17W: Sports & Outdoors
Another perk of this was that the headset plugs into an RJ45 jack, which allowed me to keep the radio remote, and plug the handset into my dash.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I didn't want to do any exterior drilling so I decided on the Lip mount Comet RS-720 (if I was to do it again I'd probably go with the RS-840 so it holds position better. It seems to move a lot when bumped on things). Also decided on the firestick FL3-B for no reason other than it was the only 3ft on 2 day prime at the time
I purchased an 18ft pre-terminated coax cable and inorder to get it ran through the loom on the hatch, I had to cut off one of the connectors and use a fishtape to pull it through. A couple of cable tie mounts I stole from work, and it turned out pretty well.
I decided on the center console for the radio's location. Ran the anteanna cable along the headliner, down the B-Piller, and into the bottom of the center console (power is soldered in line to the supply for the cigarette lighters in the back).
Since the handset is just an RJ45 plug, I ran some CAT6 and terminated it at the switch blank where I wanted it. The cable just plugs into the back of adapter (Be aware that it's not a perfect fit. I had to dremel off some of the top to get it to fit in).
Crimped a PL-259 connector back onto the coax and done!!
Pretty happy with the results! I havent tuned it in an open field yet (just quickly in my back yard) but the reception seemed great on the dunes! Only thing I would change is that antenna mount. It's great for DD, but any tree branch, or catching it on the carwash sprayer hose moves it out of position.
PoopSmith is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 05:19 PM #2
Signal Signal is offline
Signal will become famous soon enough Signal will become famous soon enough
The real question is where did you get the 4 Runner key chain?
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 05:26 PM #3
Haha was wondering if anyone would comment on that. I got it from this eBay seller last year. He had all sorts of vehicles at the time, but doesn't look to be selling anything currently
https://www.ebay.com/usr/steels2015?...72.m2749.l2754
Old 09-25-2019, 05:49 PM #4
Pure4Runner's Avatar
Pure4Runner Pure4Runner is offline
Pure4Runner is on a distinguished road
That's a nice setup! Super clean. Does that radio do CB and HAM???
Got Mods?
Ask Us about our Team Discounts. 512.234.7873
Pure4Runner is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 05:55 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
CB = AM
HAM = FM
I have yet to come across a radio that can transmit on both. That said, many HAM radios can receive on AM.
Its also worth mentioning that your antenna requirements for both bands would also be competently different.
Old 09-25-2019, 08:53 PM #6
Surgical Precision Surgical Precision is offline
Surgical Precision is on a distinguished road
Warning
I installed mine nearly identical with it mounted in the center console, running the coax cable up from underneath like that. If anyone else wants to do this my biggest warning is that when drilling through the bottom of the center console make sure to drill the hole towards the passenger side of the vehicle. The duct that runs A/C and Heat to the back of the center console for the rear passengers runs right under that. You will know if you are drilling too close as you will get a lot of insulation caught in your drill bit before drilling into the duct..... ask me how I know. But if you drill towards the passenger side it won't be an issue.
2018 4Runner TRD off-road premium - Magnetic Grey / SCS SR8 Wheels with 285/70r/17 BFG KO2s / C4 Sliders / CBI front bumper / CBI rear bumper with swing away tire carrier and camp table / Gobi stealth roof rack/ Icon 2.5 VS 3" Lift / TJM Snorkel
Surgical Precision is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 08:58 PM #7
Bumbo's Avatar
Bumbo's Avatar
So that’s one way of making the center console cooler box the Land Cruiser has.
I guess its safe to say you drilling work was not done with @Surgical Precision ?
Old 09-25-2019, 10:15 PM #8
Yup! I said ****it and pulled the whole console out to ensure I cleared everything when running cables and drilling
Old 09-26-2019, 09:58 AM #9
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Originally Posted by Bumbo View Post
CB = AM
HAM = FM
You really should have clicked the link to the radio before answering!
This funny little radio is a 10-meter ham that can be converted to 11m for CB operations. It will modulate both AM and FM. It's only 4 W though and has no provisions for running digital QSO modes....so I'm not sure what good it's supposed to be as a ham radio. There are some really oddball radio products coming out of China.
10m would be an unusual band for trail communications anyway though....normal for that is 2 meter and 70 centimeter.
Seems like an odd choice for a CB - odd choice for a radio in general - but to each his own.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 10:03 AM #10
jhguth jhguth is online now
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
This funny little radio is a 10-meter ham that can be converted to 11m for CB operations. It will modulate both AM and FM. 10m would be an unusual band for trail communications, however.
Seems like an odd choice for a CB, but to each his own.
you can't legally use that radio on CB
jhguth is online now   Reply With QuoteReply With Quote
Old 09-26-2019, 10:46 AM #11
MossJenks's Avatar
Real Name: KE0OIC
MossJenks's Avatar
Real Name: KE0OIC
That doesn't really surprise me - seems par for the course for these odd Chinese radios - but why? I read the specs to say it's 4 watt max unless you modify it. Other than the 4W limit isn't CB pretty much a free-for-all?
Past:
Old 09-26-2019, 10:56 AM #12
Yeah I followed the below guide to switch it to CB. I agree it's a little odd but it met my desire for a handset LCD and RJ45. Plus it seems to do well. Did a range check on the highway and a trucker reported I was coming in good at just under 5miles (and I still haven't done a final antenna tune). Which I agree is well below what a good system gets, but I'm okay with it. Plus it covered the entire dunes with no issues
This Internet thing will never catch on.: Anytone Apollo 1 "10 Meter" CB mod
Old 09-26-2019, 11:39 AM #13
Bumbo's Avatar
Bumbo's Avatar
When I made that comment it was primarily in reference to 2-meter/7cm or other VHF bands like MURS.
Even if it did work, probably won't be type accepted. I also agree that 10 meter is an odd choice for trail coms.
While I am a HAM, too many people I wheel with are not. I have a case full of MURS loaners for people who don't have their $hit together... so I generally end up being labeled as the "COMs guy", which I don't mind at all.
Old 09-26-2019, 01:22 PM #14
CB is license by rule which basically means that you kind of have an assume license as long as you are operating within the rules and use a radio that is type accepted (a legal CB radio will have an FCC number for it's type certification, in that sense the license is kind of attached to the radio instead of the operator)
Since this radio exceeds the power limits and isn't type certified for CB, you aren't operating within your license by rule and you could technically get a steep fine for this as well as using unauthorized equipment and exceeding the power limit
people will use these or get linear amplifiers to blast on the CB frequencies, if you're dead set on using an 10m ham on CB at the very least set the power to low and don't use CH19
Old 09-26-2019, 02:14 PM #15
After doing the mod to get the CB frequencies, it is locked in at 4W. No way to go higher. So I'm good there. But you are correct. It does not have an FCC certification, so it isn't technically legal...
back , cable , decided , handset , ran
CB install writeup Laubage 5th gen T4Rs 36 04-08-2020 02:53 PM
UCA install writeup? MadeInMaine 5th gen T4Rs 4 08-10-2016 09:07 PM
Rear speaker install writeup Mgyver1 3rd gen T4Rs 13 06-11-2015 11:52 PM
Writeup on tranny cooler install??? hockeyrunner 3rd gen T4Rs 79 01-14-2015 02:38 PM
Differential / seals install writeup? Mr. Leary 3rd gen T4Rs 0 10-11-2011 08:48 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
