Originally Posted by dangitzin
I used my multimeter. But before that I ran wires from the dash to my amp’s location(under driver seat). I wired the wires at the dash to a harness that connects to the stock harness and measured at the other end. You can also measure at the stock harness itself as long as you know which wires they are.
I’m not too sure this will work, at least with the stock speakers. There is a capacitor in series with the dash speaker to protect it from lower frequencies. As the multimeter applies voltage to take a resistance reading, it will charge that capacitor which will cause the capacitor’s resistance to approach infinity - this effectively removes that speaker from the circuit. Since the door speaker does not have a capacitor, I believe you may have been just reading the 4 ohms through that. Once the circuit is running under AC from the amp, it behaves much differently though and should be closer to 2ohms impedance.
