10-01-2019, 11:59 PM
#46
Originally Posted by btcsxj
Unfortunately it's not as simple as you are.
This age of 'whoever can land the sickest burn wins the argument' is disgusting. Missing the days when we still respected science, intelligence and general competence.
And another person who doesn't grasp the simple concept of science as it pertains to the combustion engine.
Less efficient engines will end up producing more emissions.
You must burn MORE fuel that is mixed with ethanol to get the same mileage as gas without it. Therefore you increase the amount of pollution over the life of the vehicle.
It's a simple concept.
Once again, for those who cannot grasp the fact that ethanol, especially corn based ethanol, is a net loser for transportation: If ethanol was a viable alternative fuel source that made actual sense, both from an environmental aspect, and a financial one, the federal government wouldn't have to mandate it's use. But because it's a complete net loser, it must be propped up by government mandate. It negatively affects the efficiency of vehicles,
increases pollution by requiring more fuel to do the same task, it artificially increases the price of corn, which in turn increases the price of products that we get from livestock (beef, chicken, pork, dairy, eggs).
The best source we currently could harvest to make ethanol is sugarcane, as it's not used in much agriculture, and it's not used to feed livestock.
But because it's a net energy loser, it still would require government subsidies, and it would still result in overall higher emission over the lifetime of vehicles burning ethanol blended gas dues to the loss of efficiency.
There is a reason that E-85, and flex fuel vehicles that can burn it, are not found everywhere.
Sorry you can't figure out why.
As for you lamenting about "Missing the days when we still respected science, intelligence and general competence", you seem to be missing all 3.
2018 4Runner TRDORP MGM MODS: TRD Intake, full set of ARCLight Icraus Premium lights,Precision LED interior door/exterior lights, Rago MOLLE panels, Ellis Precision shift knobs w/Custom engraving, N-Fab nerf bars, 3-1 LED DRL/Fog lights.
10-02-2019, 08:34 AM
#48
Originally Posted by El Dusty
Soot (PAHs) ...The Cat adds weight to your vehicle making it less efficient but it cleans your emissions. Now would you cut off your cat just to get more MPGs? This is the same scenario as removing ethanol from your fuel...
You can't be serious, even remotely. Just admit that this was bad analogy.
10-02-2019, 10:05 AM
#49
How about using your word to defend your argument instead of just pointing fingers.
Both items in my analogy clean emissions, Both items also reduce your efficiency when used / installed....
10-02-2019, 10:49 AM
#50
After repeating the same argument three times in a row, I think its safe to say you are oversimplifying the chemistry here.
10-02-2019, 11:22 AM
#51
Not sure if it’s worth diving into this dumpster fire of posturing and misinformation since several people have already attempted to clarify this point without success, but here’s one more try:
The purpose of oxygenated fuels (such as gasoline with ethanol) is to promote more complete burning of a fuel/air mixture that is richer than stoichiometric. The pollutants these oxygenated fuels were designed to reduce have nothing to do with carbon dioxide (CO2), or engine efficiency, or the engine’s specific fuel consumption and thus its lifetime output of CO2. In the context of air quality, CO2 is not considered a “pollutant.”
Rather, oxygenated fuels reduce emission of actual threats to air quality such as unburned hydrocarbons (HC) and carbon monoxide (CO). These components of pollution result from the partial burning of fuel when the air/fuel ratio is richer than stoichiometric. Oxygenated fuels encourage more complete combustion of richer mixtures. In older cars with less precise control over air/fuel mixture, oxygenated fuels could help reduce emissions of smog-forming HC and CO over the life of the engine.
In modern EFI closed-loop engines, the air/fuel mixture is more precisely controlled, resulting in fewer circumstances under which the oxygenated fuels would provide any benefit. Thus, because of the lower energy density of the oxygenated fuel, the net result of its use over the lifetime of a modern engine is often simply greater emissions of CO2, as one poster keeps emphatically pointing out. The confusion arises in conflating CO2 with actual pollutants such as CO and HC.
Hope that sheds a little light on the distinction and defuses the need for any more insulting arrogant posturing.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
10-02-2019, 12:39 PM
#52
"The energy content of ethanol is about 33% less than pure gasoline. The impact of fuel ethanol on vehicle fuel economy varies depending on the amount of denaturant that is added to the ethanol." U.S. Energy Information
( U.S. Energy Information Administration (EIA)
Check out this article while you there: August 8, 2019. Rising corn prices and oversupply push ethanol operating margins to multiyear lows.
Rising corn prices and oversupply push ethanol operating margins to multiyear lows - Today in Energy - U.S. Energy Information Administration (EIA)
It's simple economics in the fact that there is more supply than demand for E10, E15 and E85 fuel. I'm going to take a wild guess that non blended gas is hugely popular where it is available and that is why Quick Trip, Casey's, Phillips 66 and many other chains carry it in multiple grades on all pumps. Again, this is just a crazy wild guess and personal opinion.
10-02-2019, 01:14 PM
#53
Real Name: Ken
Real Name: Ken
Here in Canada, most gas is 10% ethanol including Premium. Unless your going to get Shell Premium 91. Which is ethanol free. Haven't seen enough gas milage increase to spend the extra .30cents/litre to fill up using Shell 91.
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
10-02-2019, 03:34 PM
#54
I've got a Casey's just a few miles from the house and they have a pump that's all non-ethanol in 87, 90, 91...priced $2.44 - 2.97 today. I just filled up with the 91...pushed the button before I realized the 90 was $2.44! Anyway, I can't tell a difference but if it's available, I'll use it.
10-02-2019, 04:51 PM
#55
This thread is a mess, too many "internet engineers"
2016 4Runner Limited
10-02-2019, 05:02 PM
#56
Hilarious you think you're making a scientific argument that starts and ends with Burn More = Bad, Burn Less = Good.
As several have pointed out, it's FAR more complicated than that. The actual CONTENTS of the emissions are the crux of the issue. While your theories about economics and lobbyists are certainly founded, your argument about ethanol mixed fuels being bad, period... is just wrong.
Super White 2016 4Runner Trail Edition
10-02-2019, 05:08 PM
#57
You make an interesting point about AFR of modern engines, and in steady-state, you are correct. However, forced induction engines (which have become incredibly popular to meet EPA emissions guidelines), become extremely rich in the moments just off-throttle. Which, if not for ethanol content in modern fuels and catalytic converters, would result in horrendous emissions. As it is, we know that small turbo-charged engines are in many cases worse polluters because of this, yet they pass the EPA tests because the testing includes lots of steady-state operation.
10-02-2019, 06:34 PM
#58
LOL!! Yea, burns more = more emissions long term.
My 4Runner is lucky to get 19.8 running e10 87 on stock dunlop HTs. Running e10 93 with an ethanol removing enzyme I get about 20.6 Running non-ethanol 93, I got 21.2 with 265 GY Duratracks. Probably would be over 21.5 with the Dunlop HTs, which is almost 2 MPG, which is 40 more miles per tank than the crap gas. 40 miles every fill up of 'lower' emissions is still MORE emissions, and it only grows exponentially from there.
You cannot change the FACT that using more fuel=more pollution. yes, the contents will be somewhat different, but the overall amount of pollution will be increased, including the contaminates that ethanol reduces, which means that you will cause more pollution running ethanol blends.
You still cannot refute the fact that if ethanol was actually a good thing, it wouldn't require a federal mandate to be put into gas.
And as I said earlier, if the end goal is JUST pollution reduction, why are you driving a vehicle like a 4Runner? There are other vehicles in the midsized SUV class that get better mileage, and larger ones that get BETTER gas mileage (GM with cylinder deactivation for instance).
And methanol burns cleaner than ethanol, but I don't see you spouting off about it. And I'm not advocating it's use either.
And yes. running ethanol blended gas IS bad for the internal combustion engine. The fuel systems don't last as long running ethanol. There is more water introduced into the fuel system because ethanol attracts water, which further reduces fuel system longevity, and can damage your engine.
The list of reasons, including the minor pollution gains in the short run, to use ethanol are far outweighed by the negatives.
10-03-2019, 07:56 AM
#59
Third tank of 87 E-free 17.8 MPG all city driving compared to 16.7 MPG on 87 Regular (with E). I'd say it's pretty good for 2013 running 33 inch tires with added weight of steel skid plates and heavy rock sliders. Funny thing is that it doesn't matter to me it is just a parameter I can measure. What matters the most is the way this truck drives now: that under powered feeling we all got driving off dealers lot-gone, passing on the highway-engine doesn't rev up to 5K RPM without notable increase in velocity but just smoothly picks up and accelerate at lower RPM (about 3.5K), cruising in traffic is just above idle while need to pass achieved by little gas input. What I'm saying is that you got immediate response where there wasn't with regular E-10 before. Non believers can call it placebo effect or whatever but the difference is notable and it is not subtle. Try it if you have access to Non-E and you will not ever want to burn corn again. Let them eat it:
10-03-2019, 08:29 AM
#60
A 10% gain in fuel efficiency over E10 is impressive but unlikely. 2-3% would be more believable.
I agree that corn ethanol is a debacle and has done little to reduce pollution over alternatives. . If you want to avoid ethanol for that reason fine but don’t fool yourself that it’s not costing you.
