01-26-2020, 05:53 PM
Toyota rear cargo slide deck - what's your set-up?
I bought my 2019 TRD-Pro used and it came w/ the rear cargo slide deck. My previous T4R did not have this and I can say up to this point I dislike it very much. I see there are two rear tie downs but otherwise it seems I have to use the tie-downs that are part of the car - this rendering the slide useless.
What's your system for using it effectively or did you just pull it out all together? I'm on the fence and have been eyeing trekbox's rear cargo management system (bravo).
Post pics if you're enjoying the rear cargo slide and using it to its full potential.
Thanks,
-Chris
'19 Pro in Voodoo Blue -- Xenondepot HIDS
285/70/17 KO2s -- ToyTec Boss Aluma 2.5 Performance Lift -- FR roof rack
SSO sliders/Low-Pro bumper/high angle clearance & Exp-One rear bumper
instagram: @adventureswith6
01-26-2020, 08:33 PM
Been wondering the same thing. I've searched and couldn't find much specific to the OEM cargo tray.
01-26-2020, 08:41 PM
Real Name: BobH
Real Name: BobH
I use mine on occasion to make it easier when loading or unloading heavy objects.
I have the little vertical panel behind it to keep stuff from falling in the opening when it is slid out.
I keep a small tarp, two plywood squares and a tire patch kit under the tray.
01-26-2020, 09:16 PM
I just bought my 2020 TRD Pro with the sliding cargo deck so I could have a flat floor to sleep on. Otherwise it serves no other purpose for me. I traded on my Jeep Rubicon and there was a huge gap and seats didn’t fold flat. I’m headed to Moab on Friday from Dallas which i built my Rubicon specifically for this trip over the last two years. One week before I leave and i get death wobble 3 times. That was it for me.
I’m planning on getting an Xprite mattress so I can camp a couple nights. I like the safety of sleeping inside away from predators. Also like the quiet without a tent flapping.
2022 4 Runner SR5 Premium--For Sale:ConsoleVault safe, HikeIt throttle controller
01-26-2020, 10:28 PM
Real Name: Eric
Real Name: Eric
Here's my low buck setup. D-rings, some Perfect Bungees, and a couple of 27 gallon storage totes from Costco. It works well, and is easy to take out when I need to.
01-26-2020, 11:07 PM
^^ This.
I bough it primarily because the 3rd row seat gap doesn't really easily allow for a flat area to sleep on.
The fact that the tie downs are outside the slider is just awful .... that and the fact that 4runners have no factory recovery points just shows that Toyota engineers don't use their own products when designing them.
01-27-2020, 12:03 AM
Add a Saris rack and fork mounts and easily move bikes in and out, flat floor for sleeping, easier loading and unloading of heavy objects. You can add tie downs easily enough, just need parts and a drill and you can make it useful for whatever you need.
01-27-2020, 02:14 AM
Real Name: BobH
Real Name: BobH
There are 2 in front and one in the rear where the 2 inch square hole is.
01-27-2020, 04:57 AM
I haven't found the sliding deck to be an impedance yet and is quite useful especially on Costco or grocery shopping trips where the flexibility to slide the tray out saves my back loading heavier things at the deeper end. Can also recall it helped on a furniture shopping trip where the store employee commented the ability to slide the tray out was a life saver compared to other SUVs that don't have it. Other than that I have a portable fridge sitting on there most of the time and does help with loading/unloading that when necessary.
On a semi related side note, the OEM cargo tray cover in its out of the box form sucks a big one. It doesn't fit quite right and doesn't really stay in place by itself. Had to add some Velcro underneath to help it stay put. It's now a non-issue but you'd figure Toyota would have done something to make it better than it is unmodified.
2021 Lexus GX460 Premium Plus + Sport Design Pkg
2019 VooDoo Blue 4Runner TRD Pro
2016 Nissan GT-R Black Edition
01-27-2020, 08:13 AM
@ DallasTRDPro
What do you mean by death wobble?
I'm in the market for a 2021 4R
Preference: 4x4 Limited in Magnetic Gray Metallic
Options: Sliding rear cargo deck
Accessories: All weather Floor Liners & Cargo Tray Package, Exhaust Tip Chrome and Mudguards.
01-27-2020, 08:15 AM
I saw this previously posted and found it helpful on at least deciding whether or not to get it as an option.
YouTube
01-27-2020, 08:26 AM
Originally Posted by t0y0ta4R
Jeeps because of their solid axles can get death wobble when parts are worn or things not being aligned. I didn’t have the energy to figure out what the problem was. Death wobble is a violent shaking that is not only sketchy, but dangerous. It will only stop when you the Jeep comes to a complete stop. I’ve always wanted a 4R. This was the perfect excuse to get one. Unfortunately I got killed on the trade.
01-27-2020, 09:25 AM
I specifically sought out a 4Runner with a tray to have a level surface for loading gear and for sleeping on. I love it.
01-27-2020, 10:10 AM
I use a couple of storage containers as in post #6 but without the bungee support.
Great for bringing home lots of groceries or other goods and easy to remove as needed.
Otherwise I don't use the cargo tray for much of anything at all.
2016 Trail Edition Premium (Classic Silver Metallic) - KDSS - Toyo "Open Country" AT3s - Crushed Oval Step Boards - Sliding Rear Cargo Deck - All Weather Mats, Cargo Tray & Cover - Mud River Two Barrel Seat Cover - Lock'er Down Console Safe - Toyota Extra Care Platinum VSA
(Formerly known as blues)
01-27-2020, 10:49 AM
Got it and appreciate the explanation. This is the first time I've heard of it but of course have no experience with Jeeps other than my father-in-laws Grand Cherokee. As for the trade-in, I've sold my last 2 vehicles outright (made more that way too) and didn't even bother asking for a price on my current vehicle when buying new. I find the simpler you can make the transaction the better as it's less variables for them to balance and then allowing you to focus solely on the new car price negotiations. Either way, welcome to the 4R club!
