Old 08-30-2020, 09:28 PM #1
TheHolyCannoli TheHolyCannoli is offline
TheHolyCannoli is on a distinguished road
Is my transfer case leaking???? Pic inside...
2017 TRD Pro, 31k miles, I am the second owner and just purchased the vehicle in June.
I got under the truck to grease the propeller shaft and I noticed this area of rust. It was wet with some kind of oil. I wiped it clean, drove for a couple days and went back under. There was a drop of some oil/fluid just about to drip off. FYI, was not raining at all leading up to me finding it or after I wiped it clean. Doesn't appear to be leaking from any other place besides that circled area.
Is this a transfer case leak? A leak from somewhere else? Normal?
Is my transfer case leaking???? Pic inside...-transfer-case-resize-jpg
TheHolyCannoli is offline   Reply With QuoteReply With Quote
Old 08-30-2020, 10:16 PM #2
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
It does appear to the output shaft seal on the tcase, looks like it dripped down onto the case bolt just beneath it
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 08-30-2020, 11:08 PM #3
Islabellefisher Islabellefisher is offline
Islabellefisher is on a distinguished road
Rear drive shaft output seal. Just had it replaced on my 2018. (warranty)
I could wipe it clean then next time I checked there would be a bubble of oil in the exact same spot as in your picture. Never did drip on the garage floor.
Islabellefisher is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 12:28 AM #4
Jeremy556's Avatar
Jeremy556's Avatar
Way worse than leaking, its covered in rust.
Probably the rear seal, I replaced mine a while back, very easy. My leak was actually the unused speedo sensor
Old 08-31-2020, 07:10 AM #5
Does this fall under the 60mo/60k powertrain warranty?
Old 08-31-2020, 02:19 PM #6
What's the possibility of the rust preventing a tight seal when the seal/gasket gets replaced? I'll probably bring this to the dealer (especially if it falls under powertrain warranty), but I like to know what needs to be done rather than hope they get it right.
Old 08-31-2020, 04:43 PM #7
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
Yes it absolutely would
Arnezie is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 05:01 PM #8
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Oil prevents rust - it doesn't cause it.....
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 07:07 PM #9
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
The part with rust on it in the pic is just a shield. It would not effect the seal.
The seal should absolutely be covered under the 5 year 60k powertrain warranty. It's a simple job, so it shouldn't take long for them to do.
02SE is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 07:57 PM #10
I don't quite understand this either. I thought maybe it was rusting from exposure to road water, but there was a drip right at that location after wiping it all clean.
I also thought it was interesting that 2 of the 4 bolts look like they've been replaced, and the other 2 look fairly rusted. I'm hoping there isn't some lingering issue that couldn't be resolved by the previous owner.
Old 08-31-2020, 09:27 PM #11
Most likely it was driven on salt covered roads in winter, and/or on the beach. That salt water gets splashed up on the undercarriage and drivetrain components. If it's not washed off with fresh water, where it accumulates will eventually rust or corrode, depending on whether we're talking Steel or Aluminum. The flange dust shield is steel, so it rusted.
At some later time, the T-case output seal developed a leak, so now that rusty dust shield has gear oil dripping off it.
Old 08-31-2020, 09:32 PM #12
Original owner was from Canada, so I think that all but rules out driving on the beach lol
Old 08-31-2020, 10:01 PM #13
Who knows. It could have been driven lots of places. People from Canada take trips too.
Old 09-04-2020, 12:14 PM #14
Mike Beyers Mike Beyers is offline
Mike Beyers is on a distinguished road
But absolutely confirms the salt issue!
Mike Beyers is offline   Reply With QuoteReply With Quote
area , case , clean , transfer , wiped
Transfer case leaking oil WallyWest 3rd gen T4Rs 16 12-27-2019 02:18 PM
Transfer case leaking EEEliminator 5th gen T4Rs 7 03-31-2019 10:35 AM
Transfer case leaking, but not sure from where WallyWest 3rd gen T4Rs 7 07-06-2015 10:15 PM
transfer case leaking yotababs86 Problems & Warranty Issues 0 03-25-2012 06:20 PM
Transfer Case Leaking DesertDune4x4 3rd gen T4Rs 7 11-30-2009 02:46 PM
