Old 02-13-2020, 09:17 AM #61
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
Originally Posted by corerolla View Post
thank you for the valuable information here. i have a kdss 5th gen and have a full set of pro fox suspension (have not installed yet). do you see any difference with 2 passenger sides in front or 2 driver sides in front? do you think there is zero lean with either 2 passenger or 2 driver side sets? are there height differences between both?
so there is 3/4 inch difference between my 2020 OffRoad and 2010 Limited. Limited with two passenger side TRF Fox and the OffRoad with two Driver side TRD Fox. what is more bothersome is that the limited is 1 inch shorter in all sides than the OffRoad.
niadh0 is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 09:21 AM #62
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
Wait for your suspension to settle on the off-road. Mine looked really high too. It's lowered about half inch since install.
osideplayer is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 11:59 AM #63
corerolla corerolla is offline
corerolla is on a distinguished road
Anyone have plans for the Eibach spring lift on their KDSS setup?
corerolla is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 04:01 PM #64
Anyone here would like to buy a full set of TRD Pro Fox REARS (L+R) and TWO driver fronts (L+L) PTR61-89190-LF? $900
Old 03-12-2020, 08:50 PM #65
Anyone here would like to buy a full set of TRD Pro Fox REARS (L+R) and TWO passenger fronts (R+R)? $900
did you do the same as what i did? how did you end up with front R+R and rear L+R?
Old 03-13-2020, 02:29 AM #66
I picked up two sets but have not installed anything yet. Will most likely go with the Eibach springs as the fronts and rears are the same in that kit.
Old 04-18-2020, 02:26 AM #67
sanquintin sanquintin is offline
sanquintin is on a distinguished road
Can't PM yet but I'm interested in the set. Are you in the bay area? Did you buy them used or new? If used, how many miles on them? Pics?
sanquintin is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 03:24 PM #68
Jtorral Jtorral is offline
Jtorral is on a distinguished road
A little late to the discussion. But since you have a 2020, it probably has the pre collision warning system and lane departure warning.
Did the addition of the fox pro suspension require recalibration of those safety features ?
Thanks !
Jtorral is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 06:21 PM #69
mark52cents mark52cents is offline
mark52cents is on a distinguished road
Can you buy and use driver pirtches on a driver shock or are there other differences?
mark52cents is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 02:49 AM #70
Jshen Jshen is offline
Jshen is on a distinguished road
Anyone given this a try?
Jshen is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 05:58 PM #71
letsgoooo letsgoooo is offline
letsgoooo is on a distinguished road
i just picked up a set of trd pro fox shocks...I will be adding eibach coils then installing to my kdss 4runner
letsgoooo is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 02:54 AM #72
Please report back!
Old 02-15-2021, 02:25 PM #73
timesinfinity timesinfinity is offline
timesinfinity is on a distinguished road
curious how this setup has held up longer term for the folks that did this.
any regrets or thoughts otherwise? anyone doing it with the 2021 shocks?
timesinfinity is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 11:25 PM #74
mnelson71ss mnelson71ss is offline
mnelson71ss is on a distinguished road
I have the 2021 TRD Pro suspension kit on order for installation on my new 2021 TRD Off Road. From the pics, the two front shocks now appear to be identical with no difference in lower perch height. The was a TSB issued on the 19 and 20 Pros for a front suspension clunk. The fix is to replace the fronts with the 2021 part numbers. The lower perch has been redesigned. I also used the parts configurator to confirm that the 2021 TRD Pro front shocks are approved for installation on my 2021 OR.
I’ll update once I have my hands on the parts. I’m especially interested to see if the perch heights are the same or if the dealer just copied the pic to show a complete shock kit front and rear.
AZ Mike - 2021 4Runner TRD Off Road - KDSS
mnelson71ss is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 11:47 PM #75
I just bought a 2021 Venture and I'm interested in the same thing! I'd put an order in if I knew a bit more. Please keep us updated! It looks like the new spring is a lopped off one at the base rather than a ground to flat one?
feedback , front , pro , side , suspension
2019 TRD Pro Fox Suspension on 2020 TRD-Off-Road niadh0 5th gen T4Rs 11 09-12-2019 05:41 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
Install time for OME BP-51 on T4R Off Road w/ KDSS shustr32 5th gen T4Rs 12 05-24-2019 10:46 AM
TRD Pro with Bilstein suspension or TRD Off Road with KDSS? Saluki 5th gen T4Rs 54 08-16-2018 11:25 AM
TRD Off Road with kdss or upgrade suspension later voland 5th gen T4Rs 19 02-05-2017 07:06 PM
