Old 02-23-2021, 03:39 PM #76
letsgoooo letsgoooo is offline
letsgoooo is on a distinguished road
Originally Posted by Jshen View Post
Please report back!
I have the eibach pro lift coils installed on my trd pro fox shocks, on my kdss 4runner. I have not ridden in a stock trd pro, so I don't really have a comparison base. It is a lot stiffer than stock TRDOR suspension. But i like it...feels more active/planted to the ground. Ride height is pretty much right where I want it, and my 285's look great. I do have KDSS lean, and will be installing a 1/4" dobinsons front spacer to level it out. Also getting camburg UCAs installed, as they were not able to get the caster where I wanted with the stock UCAs.
Check out my ig @letsgooooplaces for pics!
letsgoooo is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 10:00 PM #77
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
Originally Posted by Jtorral View Post
A little late to the discussion. But since you have a 2020, it probably has the pre collision warning system and lane departure warning.
Did the addition of the fox pro suspension require recalibration of those safety features ?
Thanks !
Zero negative impact on the PCS. Works just fine and zero malfunction of any kind.
niadh0 is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 02:21 PM #78
mnelson71ss mnelson71ss is offline
mnelson71ss is on a distinguished road
Just finished the dealer install of a 2021 Fox TRD Pro Suspension Kit on my '21 TRD OR with KDSS. I have a 1" lean left to right, driver's side high, after recalibrating the KDSS and am convinced it is due to the different perch heights on the front springs. I just ordered another front left to install on the right side, same as you, niadh0. This should hopefully get me back to 100% level side to side with about a 1-1.25" rake front to rear.
Having said that, I'll have a single right side Fox shock, part no. PTR61-89210-RF, for sale if anyone wants to build a kit.
I decided to go this route after speaking to a Fox tech person a couple days ago. He said the TRD Pro shocks were "special" and nothing else they sell at this time has that combination of on road and off-road performance.
We'll see. I'll report back after the right side install.
AZ Mike - 2021 4Runner TRD Off Road - KDSS
mnelson71ss is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 11:03 PM #79
now that's great to hear. my decision to go with two identical fronts (I think i was the first one ever to do this) was based on other users sharing their lean issue. I I didn't want take any chance so combined the two kits - one set on mine (two LF) and there remaining set on my wife's 4R limited (two LR).
Now with your experience, now its a full tested fact that the OR with KDSS needs identical shocks in the front. since you had the KDSS calibrated, you may have to do it again once you put the identical shock. Let know how it goes.
after a year, my 4R has maintained the level and the height. No drop of any kind or lost level or exhibited any lean.
Old 03-06-2021, 11:16 PM #80
timesinfinity timesinfinity is offline
timesinfinity is on a distinguished road
Did you buy the single left strut through the dealer?
timesinfinity is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 11:15 AM #81
4REast 4REast is offline
4REast is on a distinguished road
Was the part number for the additional 2021 LF Fox strut (to use on the passenger side) PTR61-89210-LF?
4REast is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 10:20 AM #82
FYI- PTR61-89210 4RUN Suskit Se (2021 version) front coil overs have 2 different perch heights. If you want identical perch heights, you have to order an additional one. I went with the LF variety bc I wanted to eliminate some rake bc of the mildly higher perch height.
PRO Fox suspension install on 2020 TRD-Off-Road /w KDSS-c471a4d6-9c7c-41b0-875f-ba7e91bd1704-jpeg
Old 05-10-2021, 10:05 PM #83
Did you install these yet?
Old 05-11-2021, 06:58 AM #84
Rainier42's Avatar
Rainier42 Rainier42 is offline
Rainier42 is on a distinguished road
Rainier42's Avatar
To eliminate the lean, couldn't one just swap the two front struts - i.e., use LF strut on right side and RF strut on left side?
Also, how is the ride with the Pro Fox upgrade and KDSS?
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
Rainier42 is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 04:20 PM #85
Just got them installed yesterday evening. Have only put about 16 miles on them. So far so good. Better than stock kdss shocks...softer and fewer detectable bumps. Haven’t done any measurements but I can tell I still have a slight rake. Maybe around inch. Before I was center hub to bottom fender at 20 front & 22.5 Rear. Same on both sides. I’ll measure pro setup later. I did measure stock kdss takeoff coil overs and the perch height was identical for both sides. Guess kdss handles any lean from weight (gas/battery/me) by design? Looks just like a pro from a stance standpoint. If they sold the pro w kdss and in silver, it would be much easier.
As far as swapping locations to handle potential lean (LF on R and RF on L), your guess is a good as mine. I knew the 6112 kdss setup called for identical perch heights, and a previous poster successfully completed the LF,LF,LR,RR setup with the 2020 kit, so I convinced the important thing is same perch height. Even more convinced after stock coil over takeoffs came in at same perch height.
Old 05-17-2021, 11:07 AM #86
Remembered to measure after install this weekend. Both LF and RF are now 21.5 hub to fender...increase of roughly 1.5” and difference of 1 inch between front and back. Thanks to previous the posters that helped me save time by posting their results and setups. It works great.
Old 05-18-2021, 06:13 PM #87
Originally Posted by timesinfinity View Post
curious how this setup has held up longer term for the folks that did this.
any regrets or thoughts otherwise? anyone doing it with the 2021 shocks?
I was the first one who did it and absolutely zeros issues of any kind. no lean or dropped levels anywhere. No need for Pre sollisison sensor calibration
Old 05-18-2021, 06:27 PM #88
you are welcome. glad to see others are following the same route as i did. i started the thought based on the OffRoad stock coming with identical shocks. and being owned 2019 pro i knew that the front two Pro shocks had different pirch settings. no brainer to use two identical ones. before i went this route, some other users on a FB forum told me about the lean issue and also mentioned that he tried swapping L to R and R to L but the issue wouldn't go away even after recalibrating KDSS. Enjoy the ride. we have best of the both worlds.... KDSS + FOX. Perhaps not a good combo for the rock crawlers but the City driving and trail rides are amazing in this combination.
you results are consistent with mine
Old 05-30-2021, 04:03 PM #89
This is great info. Thanks for reporting back - I think I’m gonna go for it.
I wonder if one could take two of the right side shorter struts and add taller springs or the Westcott spacers to make them work. Could create and after market for the folks that are selling the extra unused strut.
Old 06-09-2021, 10:49 AM #90
If you go that route, let me know. I’ve got a brand new RF sitting in my basement.
feedback , front , pro , side , suspension
2019 TRD Pro Fox Suspension on 2020 TRD-Off-Road niadh0 5th gen T4Rs 11 09-12-2019 05:41 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
Install time for OME BP-51 on T4R Off Road w/ KDSS shustr32 5th gen T4Rs 12 05-24-2019 10:46 AM
TRD Pro with Bilstein suspension or TRD Off Road with KDSS? Saluki 5th gen T4Rs 54 08-16-2018 11:25 AM
TRD Off Road with kdss or upgrade suspension later voland 5th gen T4Rs 19 02-05-2017 07:06 PM
