Old 09-27-2019, 05:38 PM #1
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
Aftermarket fogs on factory switch?
I searched around but didn't find anything. Does anyone know if you can run aftermarket fog lights (morimoto, BD squadron sport, rigid D-series, etc) off the factory wiring and switch on the blinker stalk?
I know there are lots of cool switches available but keeping clutter down inside would be far better to me.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 05:43 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Yes, it's super easy.
Even if you wanted to run a ton of lighting which far exceeds the power handling capability of the factory wiring, you can use the existing factory wiring to control larger relays.
I do this regularly because I like to keep the insides clean and factory looking when I can.
A good starting point is to look at the max current rating on the new lights and see if the factory wiring can handle it. If not, add a relay to the mix and tap the power for relay control at the point of connection for the fogs.
Old 09-27-2019, 05:47 PM #3
Ripper238's Avatar
Ripper238's Avatar
When I installed my remote start I was very impressed with the heavy gauge wiring they used throughout the 4R. I really think they planned and design this truck around people customizing it.
Sent from my SM-N960U using Tapatalk
Old 09-27-2019, 05:57 PM #4
Bumbo's Avatar
Bumbo's Avatar
I don’t know about all that… I do a ton of aftermarket vehicle wiring and I have never considered wiring to be generous or oversized for the application. If anything in most areas I think it’s pretty thin but always sized within an acceptable voltage drop, that said I think the voltage drop is on the high side of what is typically acceptable IMO for most aftermarket wiring. Most of us tend of oversize too much in custom installs as well.
These OEMs never make circuit wiring larger than they need to for their factory loads. All it does is increase cost on their end which is something they almost always value engineer.
Old 09-28-2019, 12:53 PM #5
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
Baja Designs has a kit to install their squadrons in the stock location and use the stock turn signal switch. Its just a quick harness and plug and play.
I myself am running it with zero issues. The BD lights pull less amps then the factory since they are LED. I then did the always available fog light mod and still have zero issues.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
aftermarket , blinker , factory , switch , switches
Installed Factory (Auer) LED DRL/Fogs without extra switch. q451990 5th gen T4Rs 4 07-29-2019 08:54 PM
Can I wire some aftermarket fogs up this switch by splicing into the existing wiring? blairracd 3rd gen T4Rs 7 02-11-2019 02:01 PM
Aftermarket fog lights, factory switch? billpete 4th Gen T4Rs 14 04-10-2017 04:19 PM
01 4Runner SR5 with factory fogs, switch on dash wdhendrick 3rd gen T4Rs 12 08-08-2014 12:46 PM
Hooking up OEM fogs to an aftermarket switch maulihiwa 4th Gen T4Rs 5 11-04-2013 07:19 PM
