Old 12-07-2019, 10:27 PM #1
JMFP!'s Avatar
JMFP! JMFP! is offline
Real Name: James.
JMFP! is on a distinguished road
JMFP!'s Avatar
Real Name: James.
replacing starter on a 2010
I am working tonight on trying to replace the starter on my 2010 SR5.
I have everything off except the top bolt on the back of the starter and the front bolt on the black plastic cap but I think I can solve this by trying more wrench combinations until I can reach it (or at least getting the starter bolt off then rotating it so I can reach the plastic cap bolt). I am working from the side and below with my skid plates removed (I have the RCI package).
I just want to make sure I can bring this out in the space above the frame and around the steering column (behind drivers side tire). I have the brake line bracket bolts removed, so it can be pushed as far forward as possible. I have found a couple of 4th gen videos on Youtube and there seems to a little more room in that space vs. the 5th gen. I am thinking the 2010 is pretty close to the later 4th gens that this will work the same.
Has anyone tackled this?? I searched the forum but only found 3rd/4th gen write-ups.
JMFP! is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 11:06 PM #2
obxbird obxbird is offline
obxbird is on a distinguished road
I had to replace the starter on my old 2007 4Runner and it was a PITA. Good luck!
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
obxbird is offline   Reply With QuoteReply With Quote
bolt , gen , plastic , removed , starter
Starter, CV's need replacing... farmerjon 3rd gen T4Rs 21 09-13-2012 11:58 PM
Replacing starter Ilovemy97Limited 3rd gen T4Rs 10 08-31-2012 05:45 PM
Replacing the starter on a 99 4runner 4 cylander, Deacon22 Maintenance/Detailing 1 03-05-2012 11:41 AM
Replacing starter contacts and need help pls Volley 3rd gen T4Rs 4 01-11-2012 02:35 PM
replacing starter contacts ! kennyb3030 3rd gen T4Rs 6 04-02-2011 01:23 PM
