Old 01-08-2019, 06:16 PM #1
dkyleb's Avatar
dkyleb dkyleb is offline
Real Name: Kyle
dkyleb is on a distinguished road
dkyleb's Avatar
Real Name: Kyle
17x9 -38mm + 285s on 2.5" of lift...
Welp, I'm about to pull the trigger on some very wide wheels. I've been doing tons of research on the forums, trying to see how much work one has to do to clear such a setup.
This wide of wheel with that much offset is effectively moving the wheel out 3 inches! I understand that I will be in body mount chop territory, and also moving the fender liners around. I also plan on running stock UCAs, stock front bumper...
What do you think? Doable?
2015 SR5 T4R :: ordering parts.
2004 V8 T4R :: just a bunch of crap off ebay bolted on to a rusty toyota. (build thread.)
dkyleb is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 10:01 PM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
you are going to rub a lot. I had to do a BMC, push the front fender liner forward, and push my caster forward and raise my vehicle up 3 inches, and then I still rubbed on the lower fender cap (behind the mudflaps), which hides the pinch seams, so I chopped that. I had to push my front fender liner as far as I could to the front, and it still rubbed a hole, so I ended up getting rid of a portion of the front fender liner, and since I did that, I chopped half of my front bumper off. So now I don't rub on road.....Offroad, I rub a little at the pinch seam when I stuff a tire into the fender. IT doesn't happen often but when it does, I feel like
The irony is that once u do all this, you can fit 295s or 285/75's....lol.
Anyways, I would do all this over again, but I would jump straight to 295s or 285/75s...(not 285/70)
P.S. You don't have to chop your bumper...i Just did it b/c I literally was at the point that I might as well.
Old 01-09-2019, 02:15 AM #3
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
Just chop it, cut the fender and possibly trim the pinch welds/valence caps. Everyone is so nervous about trimming off a litte worthless steel in here...but once you do it, it’s liberating.
YellowSnow is offline   Reply With QuoteReply With Quote
Old 01-09-2019, 12:12 PM #4
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
like this guy said...
i was hesitant to do a BMC... its like ripping off a band aid (stings for a couple seconds and your fine).
"wide wheels" jk i ran 11.5 on my BMW where I had millis to split between ruining fenders. Never got one
going scs huh? im trimming my weld tabs to fit F5s and 295s.
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 01-09-2019, 04:24 PM #5
Banned
Banned
F5s on 295s will look amazing! Are you running stock gears? People seem to have issues going bigger than 285s
Old 01-09-2019, 04:56 PM #6
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
SCS is -10 unless some other wheel they make is more. My Ray10s are -10. Didn't have to chop the steel, just push the fender liner forward and remove the mud flaps.
If I were you, I would replace the UCA's.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 01-09-2019, 05:09 PM #7
mrblah's Avatar
mrblah's Avatar
They make a f5 in -38mm now
Old 01-09-2019, 05:12 PM #8
KEVIN C.'s Avatar
KEVIN C. KEVIN C. is offline
KEVIN C. will become famous soon enough
KEVIN C.'s Avatar
SCS F5s are available in 17x9 w/ -38mm offset
F5 – Stealth Custom Series™
KEVIN C. is offline   Reply With QuoteReply With Quote
Old 01-10-2019, 05:04 PM #9
dkyleb's Avatar
Real Name: Kyle
dkyleb's Avatar
Real Name: Kyle
Thanks everyone. I'm not scared to chop the body mount at all. Was just seeing what everyone's input would be on fitment. I'm ordering them right now.
Old 01-10-2019, 05:32 PM #10
Right now I plan to.... although every time someone asks me i get more and more nervous...
The RG @ 295 are 64lbs...
If I didnt run these I would run the TG MT's in 285 E which are 66lbs.. People run those without gearing if its a weight thing....
Im guessing it has to do more with the circumference thing
Old 04-11-2019, 08:33 AM #11
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
The ray10 is available in this size now also. I just bought a set. Yes it was a project to make the things fit. Yes the stance was worth it.
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 10:47 AM #12
az1441 az1441 is offline
az1441 is on a distinguished road
I hate to revive this - but I must ask the experts
For these wheels - is a 33x12.5 out of the question?
I have an Icon stage 2 and I dont mind chopping and trimming (within reason)
az1441 is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 02:30 PM #13
aceee aceee is offline
aceee is on a distinguished road
Youll be fine. Thats pretty standard fitment now days.
aceee is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 06:59 PM #14
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
38 is just under an inch and a half......I am running 17x9 and -12 plus a 1.25'' spacer which is an inch and a half! BMC, minor pinch adjustment and trimmed the mudflap backer in the wheelwell and kept my flaps! SPC arm at 4 caster though.
83Mule is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 08:19 PM #15
Sick now I just need to decide on which 17x9 -38s
Either SCS Ray 10 17x9 -38
OR
Method MR105 17x9 -38
Either will be on Toyo MT 33 12.50
anyone have opinions on either wheel?
moving , stock , understand , wheel , wide
17x9 0 offset 5" backspace with 285s HokieRunner 4th Gen T4Rs 4 02-03-2014 04:41 PM
Could I run 30-31" 285s with out a lift? 7B Snow 3rd gen T4Rs 13 05-08-2013 11:19 PM
Anyone else running 17x9 on 285s? adio3x 5th gen T4Rs 11 04-26-2013 07:28 PM
285s With Stock Suspension and a 1" Body Lift spectre6000 3rd gen T4Rs 15 08-05-2012 06:01 PM
Anyone in the Seattle area with a 3" lift and 285s? Noynumal 3rd gen T4Rs 10 11-07-2011 09:58 PM
