Old 10-02-2019, 07:35 PM #1
Okusputokus's Avatar
Okusputokus Okusputokus is offline
Okusputokus will become famous soon enough
Has anyone had to adjust steering lash?
I've had this mild clunking over quick bumps, very minor when aired up but very evident when aired down. I've replaced just about everything and so the only thing I can think is that the rack is a little "loose" and when aired down it's causing more resistance on the rack internally. Just wondering if anyone has adjusted their lash and what that process was like. Looking under there it looks to be a pain to get to the adjustment bolt and I hear the engine has to be lifted a bit to get the rack out.
The only thing on the front suspension that hasn't been replaced is the lower CA's and steering rack. Everything else has been swapped out in the last few months, not just due to this but another cluck I was experiencing which was seized lower alignment bolts.
Any other suggestions as to what it could be?
2014 T4R Trail👉*LOTS of MODS
Okusputokus is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 09:46 AM #2
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
I have the same exact problem and have been chasing it for years. The clunk pretty much only happens off-road when hitting rocks squarely.
I’ve also replaced pretty much everything in the front suspension with the same result: UCA, LCA, Swaybar bushings and endlinks, coilovers etc. One thing I’m going to check when I do my next oil change is the mounting bolts for the front diff. If that doesn’t work I think it will most likely be our steering rack. Which is going to be an epic adventure to get out and replace.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 11:55 AM #3
Bummer, well if it's the mounting bolts certainly let me know! Otherwise, we'll have to see who's gets so bad first that it reveals it's exact location! ;)
Old 10-03-2019, 12:25 PM #4
BLACK-FL4RUNNER BLACK-FL4RUNNER is offline
BLACK-FL4RUNNER will become famous soon enough
It could be the inner tie rods making noise, but you should feel the play.
I chased an intermittent clunking noise for a little on mine.
I have no front sway bar.
I checked to make sure all bolts/nuts were tight on the suspension.
Turns out, it was my skid plate making the noise.
Take your skids off and drive around and see if it goes away. Cheap and easy diagnosis.
2014 Black SR5 4x4 - 285/70/17 Falken M/T, C4Fab Gas Tank Skid, RCI Steel Engine/Trans Skid, Shrockworks Sliders
https://www.youtube.com/user/Locked32114
BLACK-FL4RUNNER is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 12:31 PM #5
Elitepass010 Elitepass010 is offline
Real Name: Daniel
Elitepass010 is on a distinguished road
Real Name: Daniel
Check your control arm joints first, if you do try to adjust ur steering lash... be care full if u tighten or loosen the worm gear to much you can destroy the rack. Best bet if it is your rack to just replace. How much play do you have in steering wheel and check joints on steering shaft also check all suspension bushings, very common problem for a pushing to "clunk" when it contact just right
Elitepass010 is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 06:05 PM #6
Xtremluck's Avatar
Xtremluck's Avatar
Yup, just hope it doesnt give up the ghost while on the trail.
Old 10-04-2019, 06:06 PM #7
Xtremluck's Avatar
Xtremluck's Avatar
I replace both my inner tie rods as well as outer tie rods. Same thing.
aired , lower , rack , steering , thing
setting diff back lash, confusing manual statement. gtgt_bangbang Classic T4Rs 1 01-18-2015 03:50 PM
Valve Lash LedFloyd900 Classic T4Rs 2 05-22-2014 03:26 PM
Valve lash again KidVermicious Classic T4Rs 65 05-17-2013 08:05 AM
Valve Lash? Diverse4runner Classic T4Rs 3 01-02-2011 02:00 AM
Rear Diff Lash CBR man 3rd gen T4Rs 0 07-19-2008 06:01 PM
