Old 10-03-2019, 03:05 PM #1
DavidR1's Avatar
DavidR1 DavidR1 is offline
DavidR1 will become famous soon enough
DavidR1's Avatar
Stock Tires Rubbing??
I had a lift installed on my '14 Limited, 3' in the front and 2' in the rear. I didn't install my Total Chaos UCAs because I had a seized cam bolt. Tires are 265/70 17 KO2's.
I went off roading a few weekends ago, nothing crazy. Now my front driver tire is rubbing the fender well. Any thoughts on what may be causing this? Will the installation of my UCA's help this rubbing?
None of the body panels or fender well appear to have moved. They are still aligned and the fender well bolts all line up.
DavidR1 is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 04:00 PM #2
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Did you have an alignment after the lift? And do you have wheel spacers or aftermarket wheels?
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 04:05 PM #3
DavidR1's Avatar
DavidR1's Avatar
Yes, I had an alignment after the lift with no issues. I'm using TRD OR wheels with no spacers.
Old 10-03-2019, 04:28 PM #4
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
what is your caster? with that sort of lift you'd want to be in the 4 degree range. if you started rubbing after offroading you prob knocked it out of alignment again, likely decreasing caster even further
tm965 is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 04:35 PM #5
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Alignment probably didn't take into account wheel placement. They can move the wheels forward (which is what they should do on a lifted 4runner) or back if they're not paying attention, and just looking at the computer they use.
You should add your UCA's, then get it aligned properly with as much caster that they can get out of it (wheels moved as far forward as possible).
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 12:29 AM #6
JSparky's Avatar
JSparky's Avatar
Is it rubbing in the front or rear of the wheel arch?
I'm assuming you got your cam bolt un-siezed? Or did they align it around the cam's frozen position?
Old 10-04-2019, 07:27 AM #7
DavidR1's Avatar
DavidR1's Avatar
It is rubbing in the front. They aligned around the seized cam bolt.
fender , front , installation , rubbing , ucas
Stock tires rubbing Brown2mu 5th gen T4Rs 5 02-27-2019 03:36 AM
Rubbing on stock tires? simple 4th Gen T4Rs 9 02-08-2017 09:25 AM
275/70-17 Tires and 1.25 spacers....Any rubbing on stock suspension? cmilviper 5th gen T4Rs 7 10-15-2015 11:07 AM
Biggest tires without rubbing on stock '03 SR5 Ohcrymore 4th Gen T4Rs 19 11-19-2014 03:48 PM
rubbing on stock size tires. SkylineGTRracer 4th Gen T4Rs 2 11-19-2010 06:08 PM
