Old 10-05-2019, 02:59 PM #16
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I had 3 y/old lead acid (DieHard) working perfectly in the morning and then Sudden death in afternoon. Bent or melted plates likely. I've no idea why it had no signs of weakness or going bad instead it just died. Old tech and bad brand I guess.
<<<< is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 03:51 PM #17
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
Originally Posted by jhguth View Post
they haven't been debunked by oddyssey, oddysey's warranty is voided because the 4runner doesn't provide the voltage required explicitly in the warranty
Here we go again. This subject has been beat to death on this forum. I asked Oddysey about these discussions on the forum and they told me not to overthink the voltage. They said they have no warranty issues with our 4runners and the slightly lower voltage is not a warranty issue with them. Mine has been in 2.5 years with zero issue and no voltage modifications.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 04:50 PM #18
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Read your warranty
jhguth is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 05:36 PM #19
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
From the Oddysey warranty:
"For applications where an alternator is present, the alternator must deliver between 14.0V and 14.7V when measured at the Battery’s
terminals. Consult the ODYSSEY battery technical manual or owner’s manual for any necessary temperature compensation.
Alternators that do not have a regulated charge between 14.0V and 14.7V (no lower than 14.0V and no higher than 14.7V) will cause
early failure of the Battery. Use of such alternators with the Battery will also void the Battery’s warranty."
Toyota specs for the stock alternator is 13.2V to 14.8V. They typically run right around 13.8V which is the industry standard.
Maybe they don't really care but if what you're buying is a warranty then you might think twice. Personally when I buy a battery I'm looking to buy a battery, not a warranty so I just buy a good quality conventional battery and don't worry about it. Only battery I've ever had fail prematurely in over 30 years of driving was an Optima AGM.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 06:12 PM #20
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by MossJenks View Post
Had to think about this for a little while before I realized it was a joke - drier than James Bond's martini, sir! Well played. AGM marketing comes up with some real whoppers, that's for sure!
Believe what u want
Old 10-05-2019, 06:14 PM #21
mrblah's Avatar
mrblah's Avatar
just buy a lithium jump pack to carry
I do
Old 10-05-2019, 06:20 PM #22
MossJenks's Avatar
Real Name: KE0OIC
MossJenks's Avatar
Real Name: KE0OIC
You weren't joking about lead-acid batteries being non-jumpable?? Dude - people jump start cars all the time....
Past:
Old 10-05-2019, 06:31 PM #23
mrblah's Avatar
mrblah's Avatar
Reread my original post in its entirely, but since u like to argue do us all a favor and don’t bother.
Old 10-05-2019, 06:44 PM #24
MossJenks's Avatar
Real Name: KE0OIC
MossJenks's Avatar
Real Name: KE0OIC
WTF are you talking about? LOL
Originally Posted by mrblah View Post
If you drain your conventional lead acid battery in the middle of nowhere u r screwed. I’ll take any agm battery any day of the week for peace of mind, at least it’s jumpable when u need to.
Past:
Old 10-05-2019, 07:26 PM #25
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
I’m as confused as you are. not seeing the forest through the trees or well even any trees. I guess, I too need a better explanation.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 10:07 PM #26
mrblah's Avatar
mrblah's Avatar
Ignored
Old 10-05-2019, 10:14 PM #27
mrblah's Avatar
mrblah's Avatar
From my experience if u keep draining a lead acid battery there is a point where it won’t retain a charge. Sure you can keep jumping it but There is a point where the battery needs to be replaced.
Agm batteries are way more forgiving in this regard.
To misses Jenkins: believe what u want to believe.
Old 10-05-2019, 10:26 PM #28
jrandom's Avatar
jrandom's Avatar
Ahhhh, okay, yes that is true. But it will survive and be recoverable (not fully) at least a hundred cycles or more (obviously less depending on its age) more than I think the average Joe/Joanie would do.
I would say that your post made it sound like a single event would cause catastrophic failure. Sometimes I miss the clarity.
2013 TE w/ KDSS Nav
Old 10-05-2019, 10:36 PM #29
MossJenks's Avatar
Real Name: KE0OIC
MossJenks's Avatar
Real Name: KE0OIC
Ah yes. When you can't express yourself coherently and your self confidence is so low.you can't take people misunderstanding you or asking for clarification run on home to grammar school playground insults. And here I thought you'd made a sophisticated and quite dry joke and complimented you for it! LOL.
Past:
Old 10-06-2019, 01:20 PM #30
BigCountryT4R's Avatar
BigCountryT4R BigCountryT4R is offline
BigCountryT4R will become famous soon enough
Can you provide more details on this and why?
2019 4Runner Limited in Magnetic Gray Metallic, w/Redwood Interior, and 3rd row. Mods: Lastfit 7440/7443 Led Blinkers | JDM ASTAR LEDs throughout the interior and backup/license plate bulbs | OEM Tundra LED Fog Lights | Morimoto Elite HID 5500k 35w | Xenon Depot Led Pro 9005 w/LED Driver for DRL / XPLORE OFFROAD USA Flag rear windows | Adams Polishes UV Ceramic Paint coating
BigCountryT4R is offline   Reply With QuoteReply With Quote
agm , battery , considered , interstate , replace
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
Thoughts on a Battery... Ol'Blue 3rd gen T4Rs 29 04-15-2013 03:33 PM
SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information CBR_GUY_IA TSB 0 07-12-2009 09:30 PM
