Old 10-06-2019, 02:05 PM #31
4FL 4FL is offline
4FL will become famous soon enough 4FL will become famous soon enough
4FL 4FL is offline
I run the basic lead-acid one, and carry a portable jumper. I do not see the cost of the other batteries worth it unless you have a special need.
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 02:42 PM #32
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Originally Posted by BigCountryT4R View Post
Can you provide more details on this and why?
The odyssey warranty says:
Alternators that do not have a regulated charge between 14.0V and 14.7V (no lower than 14.0V and no higher than 14.7V) will cause early failure of the Battery. Use of such alternators with the Battery will also void the Battery’s warranty.
The 4runner doesnt have regulated charge between 14.0V and 14.7V, you need a voltage booster (which are inexpensive and take about 30 seconds to install)
All that being said, unless someone has a specific need for an AGM battery just stick with normal lead acid
jhguth is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 03:31 PM #33
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
Originally Posted by MossJenks View Post
From the Oddysey warranty:
"For applications where an alternator is present, the alternator must deliver between 14.0V and 14.7V when measured at the Battery’s
terminals. Consult the ODYSSEY battery technical manual or owner’s manual for any necessary temperature compensation.
early failure of the Battery. Use of such alternators with the Battery will also void the Battery’s warranty."
Toyota specs for the stock alternator is 13.2V to 14.8V. They typically run right around 13.8V which is the industry standard.
Maybe they don't really care but if what you're buying is a warranty then you might think twice. Personally when I buy a battery I'm looking to buy a battery, not a warranty so I just buy a good quality conventional battery and don't worry about it. Only battery I've ever had fail prematurely in over 30 years of driving was an Optima AGM.
I am not going to fight this battle again. It has been done enough in the past. I will continue to run my Odyssey battery and you run what you want. I never use conventional batteries in anything anymore because once they start to fail they start leaking acid at the post and corrode them. As I stated I talked to Odyssey about this application and they said it is fine.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 03:38 PM #34
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
Even hard off roading wouldn't warrant a agm battery unless you were going remote for a few days and would need a deep cycle.
i use agms on my boat cuz they are maintenance free sealed that wont spill acid as they can be mounted upside down if need be and vibration resistant.
regular lead acid for the win.. and save some coin for mods
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 06:40 PM #35
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
That's great they gave you a verbal assurance and if you trust them to back it up that's great. I wonder why they don't put it in writing?
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 08:55 PM #36
stephan07 stephan07 is offline
stephan07 will become famous soon enough
All this lead acid, AGM deep cycle, Lithium battery stuff. I've been on the Flux Capacitor since 1985 and never looked back.........
2017 TRD PRO Barcelona Red,RCI Sliders,RCI Alum Skids +C4 Fuel Skid, 285 Nitto Ridge Grapplers, Icon Rebound 17x8, HID, SSO Slimline Front Bumper/Warn Zeon 10s Plat, SSO High Clearance Mod, ..King 2.5 Res, Total Chaos UCA & LCAs, ARB Fridge, Battle Born Second battery with RedArc& Solar, ARB Drawers..Frontrunner Full Rack and CVT Mt Ranier RTT, C4 Ladder, Sprint Booster
2021 Audi RS6-Tuned 820hp
2017 F12 Berlinetta
stephan07 is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 10:22 PM #37
Rapid_Amble Rapid_Amble is offline
Rapid_Amble has a spectacular aura about Rapid_Amble has a spectacular aura about Rapid_Amble has a spectacular aura about
Why would Odyssey show batteries that fit the 4Runner on their web page?
Rapid_Amble is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 10:46 PM #38
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
I had to upgrade mine to the flux capacitor that was powered by compost since I live in kaliforniastan.
I could only travel to 1999.... juice not with the squeeze
Old 10-06-2019, 11:34 PM #39
Call them and ask them.
Old 10-07-2019, 10:47 AM #40
KP Texan KP Texan is offline
KP Texan has a spectacular aura about KP Texan has a spectacular aura about
This is a timely thread for me... went to start the 4Runner yesterday and it didn't have enough juice to turn the starter unless I switched the headlights off. Hooked my charger up to the Interstate MT-24F that's in there, and it gives an error which indicates the battery wont even take a charge. Would've liked for it to have lasted longer, but I guess I can't complain being that its nearly 4 years old (the kids also left the interior lights on once or twice and completely discharged it).
Wife is making a Costco run this morning anyway, so I bagged it up for her to just grab a new one there. I don't think you can beat $90, given the return policy! The current battery was still under the Interstate "performance warranty" which would get me 10% off, but that still isn't enough to make it the same price as a Costco Interstate.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 11:11 AM #41
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
Originally Posted by ROLAND1955 View Post
That is more than likely what I'm going to do.. like i said earlier, if it aint broke, don't fix it. Yes, 5 years old and still cranking like she was brand new, which is pretty good down here in this louisiana heat.
I have a factory battery from my 2017 that I replaced last year with an agm. You can have it if you want. Its currently stored at my fishing camp near Baton Rouge. PM me if you want it. I live in Gonzales so could pick it up next weekend and get it to Gonzales if thats easier.
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 01:38 AM #42
4FL 4FL is offline
4FL 4FL is offline
It suppose to automatically shut off the lights after a certain time, so the battery not get drained.
Old 10-08-2019, 05:52 AM #43
Spielightdude Spielightdude is offline
Spielightdude is on a distinguished road
battery recommendation for vol. first responders
Hi everyone,
This is an interesting thread.
I am a vol. Fire police in the town live in and as such I use my pov to respond.
I have to block roads and direct traffic as well as othet tasks.
I am going to be picking up my 4runner next year as looking at 2019-2020 model year.
For long sitting at time for 4+ hours running led warnig lights fromt back and sides looking at options for batteries that may let me not have to let the car sit and idle for hours.
Should i go lead acid or look at other options?
I do plan on putting on a batter minder that will shut off anything thats pulling juice if it detects its getting close to not being able to start so as to not be 100% stuck or stranded.
Thank you all for your time.
Joe Z
Spielightdude is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 08:29 AM #44
It's just looking up the battery size and showing you batteries in that size (in this case it shows the group 24 which is the stock battery size and group 34 which fits with an adapter).
They know the charging specs for the battery, they know that improper charging reduces the life, and that's why charging with voltage out of spec voids the warranty
Old 10-08-2019, 08:49 AM #45
Ronin61945 Ronin61945 is offline
Ronin61945 is on a distinguished road
Very good thread.
It seems that the consensus on forum searches recommends Northstar or Odyssey AGM batteries but if I want to stick to a lead acid battery for my 2017 limited, is there any suggestions for which brand would be "best" for cold weather in the stock 24F size? Cost is not a major worry, but reliability is.
Ronin61945 is offline   Reply With QuoteReply With Quote
agm , battery , considered , interstate , replace
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
Thoughts on a Battery... Ol'Blue 3rd gen T4Rs 29 04-15-2013 03:33 PM
SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information CBR_GUY_IA TSB 0 07-12-2009 09:30 PM
