10-04-2019, 05:37 AM
Battery thoughts
Hello everyone, wanted to pick your brain about something. It is about time for me to replace the battery in my 2010 4 runner. It currently has an Interstate MTP-24f. Battery is now 5 years old.. Of course I'll test it before replacing it but I wanted to get your opinions just in case I do need to replace it. I have considered getting an AGM battery but two things have made me wonder if it's the right move.. one is I've read that agm batteries don't always get along well with the vehicles charging system.. Can any of you tell me if this is true or not. And the second thing is the price.. With the agm I could get a 4 year free replacement battery, but for the cost of the agm, I could almost buy two interstate mtp 24F batteries. But I've also read that AGM batteries handle the heat ( I live in Louisiana ) much better than wet cell batteries. Anyone know if that's true? Also, one other battery I've considered is the Deka 724 fmf.. Made in america, but not quite as strong as the Interstate.. My thinking is if it aint broke don't fix it - get another interstate.. but since it's something you only replace every 4 or 5 years I like to hear what others think since battery technology is changing all the time. appreciate your input.. Thanks in advance.
Roland
Reason: additional info
10-04-2019, 08:40 AM
Real Name: Chris
Real Name: Chris
Get an Odyssey AGM, they handle our charging system just fine, those rumors have been debunked by Odyssey. I was an optima guy for 15 years, but after putting the Odyssey in my 4Runner I'll never go back
10-04-2019, 09:50 AM
they haven't been debunked by oddyssey, oddysey's warranty is voided because the 4runner doesn't provide the voltage required explicitly in the warranty
10-04-2019, 09:54 AM
If your Interstate battery lasted 5 years, that is excellent, why not get another one?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
10-04-2019, 10:26 AM
If you are not using the battery outside of normal parameters then stick with a lead-acid battery. If you need deep cycle purposes then get a agm battery and pair it with a voltage diode.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
10-05-2019, 04:09 AM
That is more than likely what I'm going to do.. like i said earlier, if it aint broke, don't fix it. Yes, 5 years old and still cranking like she was brand new, which is pretty good down here in this louisiana heat.
10-05-2019, 04:14 AM
That is probably what I'm going to do.. I was kind of torn between the interstate and the deka.. Deka batteries are american made, and supposed to be top of the line.. however I bought a marine battery from them two years ago and the damn thing wouldn't crank after one season, and this even though I had it on a battery tender in my shop all winter... The ISB MTP-24f has been good for me so far.. 5 years old and cranks like it was brand new... I can get a new one for less than 130 bucks out the door... Even if it tests okay I may still go ahead and get a new one... 60 months on the old battery in this terrible heat in Louisiana takes it's toll on a battery.. thanks guys for the comments. I appreciate it.
10-05-2019, 05:49 AM
Deep deep thoughts indeed...
10-05-2019, 08:30 AM
If you do any off-road driving then AGM is far superior battery. I'm using Northstar but any brand AGM should do fine.
10-05-2019, 09:47 AM
Real Name: KE0OIC
Real Name: KE0OIC
Theoretically this is true, but I've been off-roading for over 30 years and have never actually had a problem with a conventional battery. Never had someone in my group have a problem either though I've certainly heard a couple of stories.
Not a bad idea at all to replace batteries as a matter of routine. 5 years is a good long life - you got your $120 out of it.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
10-05-2019, 10:02 AM
Many batteries
I've had dozens of 12 volt batteries - mostly in my boat with three F225 Yamahas (12 years old). I replace all 4 (boat) batteries every 4 years regardless of anything else, as that is about the life expectancy of a good battery IMO.
For the boat the battery has to say "Marine" on it - or don't buy it for that application.
I use a good deka or interstate (or anything the battery people recommend) in my car . doesn't have to be big brand names any more. I have 2005 4runner purchased new. Can't recall what type battery came with 4runner.
Battery&Tyre here in Nassau sell most batteries.
A battery lasts 4 years - then throw away.
10-05-2019, 10:14 AM
Real Name: Kirk
Real Name: Kirk
just to muddy the water...
I use a combination of the regular lead acid (Duralast Gold 750cca) as the main battery. It will have NO issues dealing with the Toyota smart (ass) alternator. In addition to it being the power battery for the winch.
I also run an AMG (X2 930cca/195ah) marine as my auxiliary battery.
I get that not everyone wants/needs to do this and without a switch or a DCDC charge unit the AGM, pared with a Lead Acid will not ever reach full charge, thanks to Toyota's better ideas. The auxiliary powers pretty much all other accessories, LED lights, fridge (future) etc.
Long story short, nothing wrong with a quality lead acid battery.
Good luck!
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
10-05-2019, 11:52 AM
If you drain your conventional lead acid battery in the middle of nowhere u r screwed. I’ll take any agm battery any day of the week for peace of mind, at least it’s jumpable when u need to.
10-05-2019, 12:26 PM
Real Name: KE0OIC
Real Name: KE0OIC
Had to think about this for a little while before I realized it was a joke - drier than James Bond's martini, sir! Well played. AGM marketing comes up with some real whoppers, that's for sure!
Past:
10-05-2019, 01:17 PM
just buy a lithium jump pack to carry
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
