Old 04-17-2019, 08:43 PM #1
jahdai42's Avatar
jahdai42 jahdai42 is offline
jahdai42 is on a distinguished road
jahdai42's Avatar
Just checked my oil catch can..
So I put this sucker on 22 days ago and it already has an ounce of oil in there. It is also pitch black. I should have got one of these when it was new.
2016 Trail,
jahdai42 is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 09:32 PM #2
Volke Volke is offline
Volke will become famous soon enough
The oil in your catch can isn't necessarily an accurate representation of what's in your engine unless you have let it sit for a long time. It gets black and gunky from the moisture, but the oil in your engine burns most of that off when it gets hot enough. The oil in the catch can stays at roughly ambient temperature under the hood.
Volke is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 11:31 PM #3
57buick's Avatar
57buick 57buick is offline
57buick is just really nice 57buick is just really nice 57buick is just really nice 57buick is just really nice
57buick's Avatar
I installed one a couple weeks ago, looking forward to seeing what mine catches.
Just checked my oil catch can..-can-mounting1-jpg  Just checked my oil catch can..-can1-jpg
2018 TRD Premium, KING suspension, 285/70/17 Duratracs, 4.88 gears, Addicted offroad front Bumper, C4 FAB rear bumper, My build thread https://www.toyota-4runner.org/5th-g...ld-thread.html
57buick is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 11:58 PM #4
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
I could see a benefit if the vehicle was subject to long term steep incline/decline. Not sure what the benefit would be for normal daily driving. It's designed to go without the catch can.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 07:23 AM #5
jahdai42's Avatar
jahdai42's Avatar
It really is just to keep that gunk out of the intake plenum. Nothing more.
2016 Trail,
Old 04-18-2019, 09:14 AM #6
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Because that oil vapor condenses in the in the intake system and coats it. It can build up in the intake runners and on the back of the valves, more so on direct injection engines. It can coat and cause issues with the throttle body if it’s plumed in before it. The vaporized oil mixture is also probably not great for the combustion process, because it’s messing with the air/fuel ratios
The system is there for emissions/EPA.
Mantilgh is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 11:37 AM #7
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Any write up or detail of the install for this?
Old 04-18-2019, 06:59 PM #8
57buick's Avatar
57buick's Avatar
Easy install. First I bought the catch can below on Amazon. After doing research on catch cans and decided what kind of internal construction was best for catching contaminates.
Second, I removed that factory bolt on front of engine in picture, it had a small lip sticking out on factory bracket that kept my bracket from sitting flush so i ground that tab off, drilled a hole in my catch can bracket and bolted it back on.
Third, replace the pcv hose with your own hose going from the pcv to the catch can, then run a second hose from catch can to where the PCV valve originally went back into engine.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Just checked my oil catch can..-can-mounting1-jpg  Just checked my oil catch can..-can1-jpg  Just checked my oil catch can..-pcv-valve-location-jpg
Old 04-19-2019, 01:35 AM #9
After saying what I said earlier. It really isn’t all that harmful in general, possibly depending on the condition of the engine.
But if you’re a person that buys vehicle and keeps it, it is a preventative measure. I think it’s something that should help keep the intake track cleaner, possibly helping reduce problems later.
I just pulled the intercooler off my 02 WRX thinking it would help me get to a hose I need to replace.
Stock PCV set up, which is routed in just before the turbo. 280,000 miles
Turbo outlet
Throttle body
Could be worse, but could be better. I imagine there’s decent amount in the intercooler too because of the lack of it on the TB.
Old 04-19-2019, 02:41 AM #10
Wrexeter Wrexeter is offline
Wrexeter is on a distinguished road
Turbo outlet
Throttle body
A turbo with a lot of miles on it will leak oil past its seals. At 280k miles, that shaft probably has a lot of play in it, and likely lets a lot of oil past its seals.
Every turbo car will burn oil, which means it is also putting it into the intake system as well.
So yes, if you look in your intercooler, it will have oil in it. Its also why those rubber intake hoses feel oily... the pressure eventually makes them leech oil.
Wrexeter is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 09:28 AM #11
WAT4R's Avatar
WAT4R WAT4R is offline
WAT4R will become famous soon enough
WAT4R's Avatar
What size / type hose did you use?
2018 CSM TRD OR, 5100 leveled, RSG sliders.
WAT4R is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 10:30 PM #12
57buick's Avatar
57buick's Avatar
cant remember think it was 3/8
Old 04-21-2019, 10:51 AM #13
Texas_Ranger's Avatar
Texas_Ranger Texas_Ranger is offline
Texas_Ranger will become famous soon enough
Its a 3/8 OD vacuum line but the fitting from the crankcase is slightly smaller then the one going into the upper manifold. For the smaller one you might want to use a ring gear to tighten it down. I used the spring that was one it and a zip tie to tighten it down even more so. I put mine in yesterday.
Just checked my oil catch can..-catchcan2-jpeg
Texas_Ranger is offline   Reply With QuoteReply With Quote
Old 05-24-2019, 02:24 PM #14
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Installed mine today. I have too much other crap mounted in various places around my engine bay, so I had to come up with an alternative and secure spot. The drivers side intake bracket works quite well and the whole assembly is easily removed when I need room to work. @wfo9 thanks for the Moroso recommendation.
Just checked my oil catch can..-img_4423-jpg  Just checked my oil catch can..-img_4422-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 12:30 PM #15
SparkySparks83 SparkySparks83 is offline
SparkySparks83 is on a distinguished road
Coming from a high boost direct injection platform where it was common to us an oil catch can to keep thing clean and running smooth. The occ should be mounted so it is the lowest point in the system so any oil vapors in the hose run back into the catch can.
SparkySparks83 is offline   Reply With QuoteReply With Quote
black , checked , oil , ounce , pitch
PSA: So, have you ever checked your spare? philsey 5th gen T4Rs 31 01-30-2018 06:42 PM
Checked the FAQ's but can't find anything usaf_fire 5th gen T4Rs 1 09-05-2015 12:36 AM
Looking a 3rd gen and need a VIN checked? T4R_Finally 3rd gen T4Rs 6 12-23-2011 07:24 PM
Checked out a 2012 My 4R 5th gen T4Rs 20 11-16-2011 05:52 PM
Have you checked your trade in value lately? dwulffusa 4th Gen T4Rs 8 03-11-2007 08:51 PM
