Old 10-04-2019, 12:04 PM #1
leered leered is offline
leered is on a distinguished road
2012 T4R LTD - JBL E7028 Navigation Unit - digitizer replacement
My touch control stopped working on my navigation unit (JBL E7028) and finally got the issue fixed. While looking for parts and instructions , I've noticed there wasn't anything on the JBL unit . However, using info on Prius non-JBL and other Toyota units, I was able to ID the part needed (part # LQ070T5GC01) and also take the unit apart and do the repair.
Found the part on AliExpress by searching for "LQ070T5GC01". Note: the new parts will have a longer connector but still have 8 pins ( like the OEM part). Price will range from $13 to $100+.
This forum is where I always turn when looking for answers and I thought it is my chance to give back. I've created a step-by-step PDF (2.2MB) from all the pics (along with URL-s for the sources of "inspiration", just in case someone else has the same problem) . See attached.
Attention: while this is not a difficult project, things might not turn out as expected ( items/parts break, additional issues are discovered...). If not confident, turn to professionals for repair assistance. There is always some risk involved with DIY projects.
Thanks!
File Type: pdf 2012_T4R_LTD_JBL_NavUnit_Digitizer_replacement.pdf (2.08 MB, 680 views)
leered is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 02:14 PM #2
PJ2zero9 PJ2zero9 is offline
Real Name: Pj
PJ2zero9 is on a distinguished road
Real Name: Pj
This is great, Thanks!
PJ2zero9 is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 03:23 PM #3
houben houben is offline
houben is on a distinguished road
Nice write up. Thank you.
houben is offline   Reply With QuoteReply With Quote
Old 09-12-2021, 05:33 PM #4
Rogue_woman Rogue_woman is offline
Rogue_woman is on a distinguished road
I know this post is a few years old, but I thought it might be helpful for some to have a video of how to replace the touchscreen. I couldn’t find one for the JBL 4Runner radio, so I made a video when I replaced mine. Hope it helps!
https://youtu.be/WCikOMyeu2A
Rogue_woman is offline   Reply With QuoteReply With Quote
Old 02-04-2023, 05:41 PM #5
jaetheo jaetheo is offline
Real Name: Jae
jaetheo is on a distinguished road
Real Name: Jae
2010 T4R Trail digitizer gone bad
I also had the digitizer for my 2010 Trail edition go bad. The top half of the display would register touches, but the bottom half would not. After getting into the *maintenance mode to view the touchpoints, it looked as if the touches on the bottom half of the screen were all registering on the very bottom of the display.
The stereo is a JBL E2029 printed on the lower part of the face. I ordered the standard 8" digitizer screen for the E2022 Prius since the seller said it would work on the 4Runner. I paid $25 for it on eBay. I looked at a few videos and installed it without any issues. Note: all of the ribbon cables have locking mechanisms that need to opened prior to removing the ribbon cables. The one on the main unit pulls out towards you. The one that separates the metal back piece has a metal back that lifts up. The one for the digitizer is another one that slides out toward the ribbon cable.
Unfortunately, when I tested it the new digitizer, the touchpoints appeared random. They would not appear where my finger was touching. I uninstalled it, checked all of the ribbon cables and put it back in. Same thing. Inaccurate random touchpoints. I also didn't love that the new screen was shiny glass and would show fingerprints easily.
I removed everything for a 3rd time and just decided to clean up my old digitizer and put it back in so that at least the stereo would work while I wait for a replacement. To my surprise, the old digitizer is working again perfectly! All touchpoints are accurate and work even with the lightest touch.
Diagnostic Mode from BlackWorksInc
https://www.toyota-4runner.org/2170887-post2.html
-Ignition "Key On," not Accessory (Engine Running or Not, it does not matter)
-Press and Hold the "Info" (on some head units it will be the "Apps" button)
-While Holding the "Info" (or "Apps" if equipped) button, cycle the headlight switch from "Off" to "On" 3 Times (Off -> On -> Off -> On -> Off -> On -> Off)
The head unit should enter a very simple looking interface with some options (if not repeat the process again), select "Function Check/Setting" from the menu. Once you've entered that sub-menu you should see "TouchScreen Switch," select that and it will bring you to a testing screen. Press anywhere on the touchscreen, there should be a " + " symbol where the touchscreen registered your touch (this symbol will stay in place until you touch the screen again); this will give you an idea of where the touch screen thinks you're pressing and/or if it is even registering your touches properly (this is not a calibration, it is merely diagnostic.)
To exit "Diagnostic Mode," just cycle the ignition.
2010 Trail KDSS w/ Bilstein 5100's and Wheelers T1/T13 springs and K02s
1999 SR5 with Bilstein 5100's front OME rear and BFG MTs
Last edited by jaetheo; 02-04-2023 at 05:56 PM. Reason: Updating how to get to diagnostic mode
jaetheo is offline   Reply With QuoteReply With Quote
Old 02-05-2023, 08:14 PM #6
jhebert9 jhebert9 is offline
jhebert9 is on a distinguished road
digitizer
Nice write up. I wish I would have had this writeup when my screen went out on my 2010 Trail. I have since replaced the 2010 with a 2022 model.Be careful when you clean the screen. Cleaning is what caused the problem to my screen.
jhebert9 is offline   Reply With QuoteReply With Quote
Old 02-05-2023, 08:18 PM #7
Had the same problem with the screen on my 2010 model. It would show my location as far away as 100 miles. Never could get it to work properly. Fortunately I no longer have the 2010 model.
jbl , part , parts , pdf , unit
Cracked screen/digitizer on head unit 9lb taco 5th gen T4Rs 28 07-06-2020 07:09 PM
2012 toyota navigation tantoon New Members 1 02-12-2015 10:44 PM
I'm trying to get my 2012 navigation updated, but doaburnout General Discussions 11 05-27-2014 09:45 PM
Question about OEM Navigation Head Unit in 2012 Limited ebcoit 5th gen T4Rs 6 08-13-2012 09:29 PM
