Old 10-04-2019, 01:40 PM #1
KP Texan KP Texan is offline
KP Texan will become famous soon enough
5th Gen Speaker Selection
I know this topic has been beaten to death, but I can't seem to find the necessary info following numerous Google and forum searches.
Why does Crutchfield claim that almost no 6.5" coaxials will fit in the rear doors of the 4Runner? I even called them to ask, and they said its because of speaker protrusion and interference with the door panel. They said the only option was to cut a round hole in my door panel!
That being said, I know that cannot be the case based on the numerous speakers I see people have installed here without problems. Only issue is I can't find an install of the particular speaker I'm looking at.
I want Infinity Reference to match my fronts, so I was looking at these (buying from Amazon):
Standard: Infinity Reference REF-6522ix 6-1/2" 2-way car speakers at Crutchfield
Shallow: Infinity Reference REF-6522EX 6-1/2" 2-way car speakers at Crutchfield
I'd rather go with regular, but I'll do shallow if I need to. I also have no problem fabbing up some adapters, but no way I'd cut a hole in my door panel!
Thanks for the input!
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 04:07 PM #2
keyser_soze's Avatar
keyser_soze keyser_soze is offline
keyser_soze is on a distinguished road
TacoTunes makes adapter plates for the rear doors. They make adapters for all the doors, and wiring adapters as well.
From what other have installed I don not think you need shallow mount speakers. If anything you might need to trim a little plastic on the inside of the door panel, but that shouldnt be a big deal.
You had another thread about upgrading your front speakers and head unit right?
I would consider what you want to do with your system. If you dont have rear passengers or need music coming from the cargo area I would consider leaving the rear speakers alone and invest in better front speakers/amp, then fade the sound to the front. 99% of music is recorded in 2 channel stereo, so there is no need to have lesser speakers putting out the same signal from behind you, it can mess with the sound and staging. I only have front components and I assure you that my rear passengers can hear them just fine. It also simplifies your amp setup and wiring.
2015 SR5 Premium MGM Bilstein 5100 | SCS SR8 | 285 Terra Grappler G2 | TRD Grill | Trail Rack | TRD Intake | Borla Side Exit Exhaust | TRS HIDs | Total Chaos UCAs | JBL MS8 | Pioneer 9605 AMP | Scanspeak tweeters, Kicker 6x9s, Alumipro 12"
keyser_soze is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 04:43 PM #3
Yep, I had another thread strictly about the 2-ohm speaker impedance across the front speaker set, but I've just solved that problem by buying a 4 channel amp rated for 2-ohms... not to mention it will be superior to headunit power anyway.
I've already bought the front set of speakers which are Infinity Reference 3.5" in the dash and Infinity Reference 6x9 in the front doors.
Although I plan on leaving the back hatch speakers stock, I decided that it might be good to replace the rear door speakers since they are still in the passenger area and also right behind my seat. That's where my dilemma is. Will either on of those Infinity 6.5" speakers work despite what Crutchfield says? I already plan on fabricating an adapter out of HDPE or something (have plenty of MDF, but I don't want to use that on a door due to moisture.
2018 TRD ORP - Sold
Old 10-04-2019, 05:55 PM #4
4Rums 4Rums is offline
4Rums is on a distinguished road
I have the JBL GX602 (sister speakers, JBL and Infinity are from the same parent company) on the rear doors using these adapters from amazon. Based on the depth dimensions I could read (they are tiny and not zooming well in my phone), they should work. But compare yourself and look for the cut out size and tweeter protrusion required as well. Also have in mind that not all speaker adapters allow the same mounting depth or cutout diameter. So make sure when you get recommendations that you know which adapter is being used.
You can find my rear door speaker dimensions here: https://pdf.crutchfieldonline.com/Im...9/109GX962.PDF
Rear door adapters: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
*For $10 not sure if it is worth it to make your own. With some foam tape these don't rattle).
4Rums is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 06:54 PM #5
Since you bought an amp it depends how you run your wiring. If you make a patch harness and reuse the factory wiring then yes, but if you run new wire you can wire the speakers yourself in whatever configuration you like.
The stock speakers are garbage, any decent aftermarket speaker will be a nice upgrade. Infinity makes quality stuff, and their coaxial speakers sound great. But have you considered a component setup? They are typically better sounding than coaxial and they have better crossovers. With a coaxial in the door and the dash you will have 4 tweeters in the front. 2 of those will be by your leg which is not ideal IMO (reflecting off the windshield isnt ideal either but better than down low)
If you are capable of fabricating your own adapters then making the speakers fit wont be an issue.
As for the hatch and rear door speakers you should not hear them over your front speakers. In a proper system they would be used as rear fill and the volume would be faded forward. A passengers might hear them over your front speakers, but not you. Even for a passenger the front speakers are only about 5ft from their ears, they will just sound a few decibels quieter than they do to you.
Either way you go you will have a large improvement over stock.
Old 10-04-2019, 08:32 PM #6
Narat_524 Narat_524 is offline
Narat_524 is on a distinguished road
Yes, 6.5" will fit with the top mount speaker adapter ring. I put 5 1/4" for mid range, but considered the speakers you listed.
You will probably need to remove the baffle ring on the door panel. I just used a set of end-cutting pliers to remove mine and then used a foam ring to take up any clearance between the panel and speaker.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 12:51 AM #7
Thank you for the replies everyone! This is all incredibly helpful. The GX602 is pretty near identical and the basket design even looks the same.
2018 TRD ORP - Sold
Old 10-05-2019, 11:33 AM #8
Superjet Superjet is offline
Superjet will become famous soon enough Superjet will become famous soon enough
Front door
https://www.bestbuy.com/site/metra-t...?skuId=5228067
rear
https://www.bestbuy.com/site/metra-m...&skuId=5228145
or expensive option
Focal IS 690TOY 6"x9" component speaker system designed to fit select Toyotas at Crutchfield
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 04:28 PM #9
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 is on a distinguished road
In my 2011 I did the reference series 6x9 component setup in the front and bought 2 pairs of 6.5" 6522ix reference speakers for the rear doors and hatch. I just used regular generic I think metra install adapters. No door panel trimming required. along with a small powered sub and party mode all the time mod it sounds pretty good.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 09:21 PM #10
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton has a spectacular aura about nglayton has a spectacular aura about
MY GARAGE
nglayton's Avatar
Real Name: Neal
MY GARAGE
5TH GEN 4RUNNER SPEAKER ONLY UPGRADE FROM OEM AUDIO PLUS
nglayton is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 09:40 PM #11
CMTAZ CMTAZ is offline
CMTAZ is on a distinguished road
FWIW
The new speakers are in
it's been almost 1 year, and i'm still impressed with the powerbass drop ins and the 5 channel pioneer amp...
2018 SR5 Premium - TRD Wheels - Tyger Armor Step Bars - Clear Bra - PowerBass 6.5" coaxial & 6x9" component speakers - Pioneer 5 Channel Amplifier - Pioneer 12" Shallow Mount Subwoofer - RAV4 Convex Mirrors - LED Headlights - Lexus LED Fog Lights (clones) - Falken Wildpeak AT/3
CMTAZ is offline   Reply With QuoteReply With Quote
cut , door , panel , shallow , speaker
Help regarding 4th Gen selection? Bye bye to 5th? tacobill 4th Gen T4Rs 14 03-13-2013 03:02 AM
Destroy stock speaker, or build/buy speaker haeness? gmoff26 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-12-2012 09:41 AM
Winch selection 2000runr 3rd gen T4Rs 2 05-11-2010 11:19 AM
Speaker Selection mountainman_gz Classic T4Rs 3 01-26-2008 12:27 PM
GPS Selection - PLEASE HELP!!! frankhead Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-13-2007 07:55 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
