Old 10-03-2019, 09:37 PM #1
amnt amnt is offline
amnt is on a distinguished road
ARB Dual Compressor will not run
I just installed a new ARB dual compressor but the compressors will not run. They start and then shut off. The fan runs and all fuses seem to be good.
Anyone experience this issue?
amnt is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 09:55 PM #2
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
start with the basics. if it starts and turns off, you probably have everything connected right. Check your grounds first, and then every wiring connection. If everything is tight, then it sounds like either your compressor is pressurized or you have a bad pressure sensor.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 10:23 PM #3
ARB Compressor wont run
Thanks, I will check the pressure switch.
I am running it without a tank. Don't know if that makes any difference.
Old 10-04-2019, 12:21 PM #4
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
If you have a pressure switch and you're running without a tank and no outlet for the compressed air, the compressor would do exactly as you describe. It will start then immediately build up enough pressure to trigger the shutoff.
nglayton is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 08:36 AM #5
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
That sounds normal. Begin inflating tires and it will kick on again. I've small aluminum air tank that prevents it from shutting down immediately and also ARB twin runs cooler with reservoir tank.
<<<< is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 09:35 AM #6
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Like others have stated, if you aren’t using it, it is totally normal behavior.
Ain’t that the truth! Releasing the coupler straight from or even close to the compressor after filling four tires is enough to burn you. I had a three foot pigtail to the front of the truck, before I added a 1gal tank and popping that coupler right after a fill required gloves.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 11:28 AM #7
ARB dual compressor will not work
Thanks everyone.
I understand that the unit will cut off but it was not coming back on when i started airing up. I did check all connections and fuses. Once I checked the relays and put the unit back together it started working. May have been a poor connection.
Thanks for all the input.
Happy Trails
Old 10-05-2019, 03:04 PM #8
<<<<'s Avatar
<<<<'s Avatar
Check your wiring and the fuse. I hope your switch is also wired trough the fuse. G.L.
Old 10-05-2019, 08:10 PM #9
Draggin Draggin is offline
Real Name: Ken
Draggin is on a distinguished road
Real Name: Ken
Originally Posted by jrandom View Post
Ain’t that the truth! Releasing the coupler straight from or even close to the compressor after filling four tires is enough to burn you. .
Can confirm, gloves required. esp in Arizona
Draggin is offline   Reply With QuoteReply With Quote
arb , compressor , dual , fan , run
ARB dual compressor mounting location options? Road Bull 3rd gen T4Rs 32 03-15-2022 10:22 AM
HELP Wiring Guide for ARB Dual Compressor Michael M 5th gen T4Rs 28 11-17-2020 09:44 PM
Rear air access from dual ARB compressor in engine bay mechIFR 5th gen T4Rs 5 02-21-2018 08:31 AM
**Dual ARB Compressor GB** ramonortiz55 Group Buys 21 08-15-2016 09:38 AM
