Old 10-04-2019, 03:39 PM #1
TOTAL CHAOS's Avatar
TOTAL CHAOS TOTAL CHAOS is offline
Official Vendor
TOTAL CHAOS will become famous soon enough TOTAL CHAOS will become famous soon enough
Official Vendor
TOTAL CHAOS | Expedition Series +2" Long Travel
TOTAL CHAOS is excited to announce the release of the all-new 2” Expedition Series long travel kit. With the success of the stock length Expedition Series lower control arms it was only natural to incorporate the upgraded features into one of our long travel systems.
Enthusiasts and racers alike can now benefit from the increased strength of a billet CNC machined uniball end piece and integrated steering stop tabs which retain the factory turning angle.
Increasing a vehicle’s track width improves performance in a few different ways. With a wider stance comes improved cornering stability and increased wheel travel. Do you want more articulation when crawling over obstacles on the trail? Want to carry more speed through rough terrain? Long travel is what you’re looking for.
Going with a 2” kit vs. something wider has its up-sides as well. When paired with certain wheel and tire combinations, a 2” kit may not require aftermarket fiberglass fenders like other wider long travel kits. Trail width limitations are also something to consider. A 3.5” or wider prerunner suspension system may be perfect for the desert but too wide for tight trails littered with trees, rocks and other obstacles.
Extended 4130 chromoly upper and lower control arms increase the vehicle's track width 2" per side and bolt to factory control arm mounting locations yielding 11.5" of travel. Upper and lower control arms utilize urethane bushings and steel inner sleeves which greatly reduce bushing deflection compared to stock rubber bushings.
Both the upper and lower ball joints are upgraded to 1" uniballs for maximum wheel travel. Custom TC 1" I.D. uniballs feature a heat treated stainless steel ball & race for superior corrosion resistance and component strength. A military grade PTFE woven fabric liner surrounds the uniball which helps prevent noise and debris buildup.
The Expedition Series 2" kit lower control arms come pre-tabbed for secondary external bypass shocks which can be installed to increase dampening and offer more tunability. Secondary shocks are not required when installing this kit, however it makes for a significant improvement in ride quality and furthers your vehicle's off road capability.
As the control arms extend outward, the brake lines need to be extended to reach the brakes. TC has you covered and includes DOT approved stainless steel braided brake lines. For vehicles with 4WD, custom 4340 extended axles are available, although not included with the kit. These axles reuse factory Toyota inner and outer CV's for ease of maintenance and install. Adjustable limit strap clevises are included to properly limit suspension droop wheel travel and allow necessary adjustments during the life of the limit strap.
A great upgrade to compliment the 2" Expedition Series long travel kit is the custom TC extended swaybar. With a lighter rate than the OEM piece, this sway bar improves cornering stability at high speeds without compromising wheel travel or articulation. The sway bar is an upgrade and is not included with the kit.
SHOP NOW
TOTAL CHAOS! Specializing in TOYOTA suspension for over 20 years!
www.chaosfab.com - 951.737.9682 - info@chaosfab.com
TOTAL CHAOS is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 11:46 AM #2
Official Vendor
Official Vendor
Old 11-30-2019, 06:43 PM #3
Official Vendor
Official Vendor
Who wants to see some +2" LT under the tree this year?
December is just about to start! Get on the nice list
Old 12-11-2019, 04:39 PM #4
Official Vendor
Official Vendor
#midweekmotivation ... get out and explore with tacorunner
photos: imjoshuawalker
Old 12-11-2019, 04:42 PM #5
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is just really nice Ryan at Eibach is just really nice Ryan at Eibach is just really nice Ryan at Eibach is just really nice
official vendor
Looks really good!
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 05:33 PM #6
Official Vendor
Official Vendor
2019 is coming to an end and 2020 will be here tomorrow
Happy New Year! Let's see your LT setups
Old 01-01-2020, 03:41 PM #7
nimby's Avatar
nimby nimby is offline
nimby will become famous soon enough nimby will become famous soon enough
nimby's Avatar
Will this tuck under the stock fenders or would I need fiberglass front fenders?
nimby is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 09:20 PM #8
honda250xtitan is a jewel in the rough honda250xtitan is a jewel in the rough honda250xtitan is a jewel in the rough honda250xtitan is a jewel in the rough
with stock wheels it tucks, from what other members have said.
2016 TE : Grocery Getter, 285/70R17 K02's, Prinsu Rack, 6112, T13, Fox 2.0, DirtKing Fabrication
2017 F250 6.7: ICON, BajaDesigns, DIY Retrofit headlights
control , kit , long , travel , wheel
NEW Expedition Series Lower Control Arms from TOTAL CHAOS TOTAL CHAOS 5th gen T4Rs 49 12-31-2019 12:13 PM
New from TOTAL CHAOS | Long Travel Sway Bar TOTAL CHAOS 5th gen T4Rs 23 07-11-2019 07:31 PM
Total Chaos 2" Long Travel Kit - 4th Gen 4Runner TotalAutomotiveLV 4th Gen T4Rs 0 03-04-2019 03:56 PM
Total Chaos 2" Long Travel Kit - 5th Gen 4Runner TotalAutomotiveLV 5th gen T4Rs 0 03-04-2019 03:49 PM
GA-BNIB 2" Total Chaos "Race" Long Travel -Cam/Bucket/Spindle Gussets -Axles/HD Boots av8ter For Sale: Suspension/Wheels/Tires 24 02-26-2017 05:07 PM
Copyright © 2019
