Old 10-04-2019, 08:21 PM #1
snowpeak snowpeak is offline
snowpeak has a spectacular aura about snowpeak has a spectacular aura about
2020 Running Lights - On/Off Setting
Great news! New owners of the 2020MY with the new head unit have an option to turn on or off the DRL independently of the headlight switch, which means it’s now possible to run parking/marker lights without the DRL on. Even with the headlight switch set to DRL and the setting in the head unit set to OFF, the DRL will remain off. Previously, to run parking/marker lights without the DRL, the only option AFAIK was to alter the wiring or wiring harness.
The setting is located in: MENU > Setup > Vehicle > Vehicle Customization > Lights Settings
Ignition must be in the ON position to access these menus.
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
snowpeak is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 09:25 PM #2
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
In my 2014, I have the option to turn on/off DRL using the headlight switch.
Did it become an 'always on during the day' thing with later years?
Originally Posted by snowpeak View Post
Great news! New owners of the 2020MY with the new head unit have an option to turn on or off the DRL. It’s located in: MENU > Setup > Vehicle > Vehicle Customization > Lights Settings
Daikon is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 10:48 PM #3
I updated my original post with more details. This feature allows the newer 5th gens to run the amber running/parking/marker lights with the DRL off, previously as I understand it the only way to do that was a wiring modification. That was going to be my first mod but a tap of the finger is much easier!
Old 10-04-2019, 11:31 PM #4
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
or this... https://www.toyota-4runner.org/1978499-post50.html
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 11:53 PM #5
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
On the 2020 with the safety sense is the inside rear view mirrow screw accessible easily if it ever gets loose or camera cover blocks it?
Old 10-05-2019, 11:42 AM #6
Whippersnapper02's Avatar
People use just their parking lights?
Old 10-05-2019, 12:04 PM #7
CF_Machete's Avatar
CF_Machete's Avatar
Yes, especially when you have led highbeams since they are the same as the drl
Old 10-05-2019, 05:09 PM #8
You can get the DTRL specific kit that works as both high and DTRL.
Old 10-05-2019, 06:15 PM #9
LRT LRT is offline
LRT is on a distinguished road
LRT LRT is offline
Are there any other customizable screens then what you showed?
LRT is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 01:35 AM #10
Yeah there’s a lot of options. See the head unit owners manual here: https://www.toyota.com/t3Portal/docu...f/OM35B57U.pdf
Specifically page 18:
Old 10-06-2019, 01:38 AM #11
I prefer the look of the side ambers in daylight or early evening. DRL is safer, but if I was mostly interested in safety I wouldn’t have purchased a 4Runner.
Old 10-06-2019, 02:30 AM #12
TheNormsk TheNormsk is offline
TheNormsk is on a distinguished road
I have this on my 4RL and have no issues running DRL with the LED. I don’t know why you would want to switch them off. 2020 Running Lights - On/Off Setting
TheNormsk is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 10:28 AM #13
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
2020 owner here. Confirmed yup..you can disable DRL on the big screen vehicle screen settings.
And inside rear view mirror screw not covered like on the 2017 corolla SE !!
Amazing 4 runner. Everything solid.
Old 10-07-2019, 04:52 PM #14
Daikon's Avatar
Daikon's Avatar
Thanks, makes sense now hah
Old 01-04-2020, 09:55 AM #15
SKT_07 SKT_07 is offline
SKT_07 will become famous soon enough
Any plans to install a set of amber Raptor grille lights in your TRD Pro grille swap? I’m not keen on the idea that these are a spin-off from the Raptor, but like you, I prefer the front Amber lights. I also think they actually catch people’s attention in a good way during inclement weather and limited visibility.
I’ve been looking at the below set (smoked amber w/ 4 lights), as their website says it is compatible for the ‘20s:
4Runner Raptor Light Kit Amber LED – Overland Depot
I like the idea of the 3 light set-up which locates them in the center of the upper grille; however, they seem very bulky and obvious. I prefer the low profile look of the 4 light set-up and the smoked lenses should keep them matching our MGM until they are on. Thoughts?
SKT_07 is offline   Reply With QuoteReply With Quote
access , drl , lights , position , vehicle
2020 TRD PRO or 2020 GX460.... What do?!?! spc54 5th gen T4Rs 35 08-13-2019 08:58 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
Anyone running Bilstein 5100 on higher setting? YellowSnow 5th gen T4Rs 20 02-06-2019 08:52 AM
5100 top setting vs. stock setting with spacer RioRunner 5th gen T4Rs 9 09-10-2016 07:09 PM
heater motor only running on low setting Sidney Classic T4Rs 0 01-26-2008 08:19 PM
