Old 03-17-2020, 11:35 PM #16
BlueEyedDevil's Avatar
BlueEyedDevil BlueEyedDevil is offline
BlueEyedDevil will become famous soon enough
Originally Posted by SKT_07 View Post
Any plans to install a set of amber Raptor grille lights in your TRD Pro grille swap? I’m not keen on the idea that these are a spin-off from the Raptor, but like you, I prefer the front Amber lights. I also think they actually catch people’s attention in a good way during inclement weather and limited visibility.
I’ve been looking at the below set (smoked amber w/ 4 lights), as their website says it is compatible for the ‘20s:
4Runner Raptor Light Kit Amber LED – Overland Depot
I like the idea of the 3 light set-up which locates them in the center of the upper grille; however, they seem very bulky and obvious. I prefer the low profile look of the 4 light set-up and the smoked lenses should keep them matching our MGM until they are on. Thoughts?
Not sure if I like 3 or 4 lights more. Both look nice and I kinda like the 3 light look too.
BlueEyedDevil is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 11:40 PM #17
Originally Posted by snowpeak View Post
Great news! New owners of the 2020MY with the new head unit have an option to turn on or off the DRL independently of the headlight switch, which means it’s now possible to run parking/marker lights without the DRL on. Even with the headlight switch set to DRL and the setting in the head unit set to OFF, the DRL will remain off. Previously, to run parking/marker lights without the DRL, the only option AFAIK was to alter the wiring or wiring harness.
The setting is located in: MENU > Setup > Vehicle > Vehicle Customization > Lights Settings
Ignition must be in the ON position to access these menus.
This is incredibly timely info for me. 500 miles on my 2020 TRDP and id like to dump the DRL’s for Raptor lights. Was t sure how to disengage them and it’s a freakin setting I can just turn off. Thank you.
By the way, here’s a more known setting but worth a reminder. The Nav screen has various settings too. One being the backlight color. It defaults to white, as in the OP’s pics, but it’s much easier on the eyes in a dark mode.
Old 03-18-2020, 08:08 PM #18
snowpeak snowpeak is offline
snowpeak has a spectacular aura about snowpeak has a spectacular aura about
I switched to dark mode soon after I took this picture, several months ago. Much better!
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
snowpeak is offline   Reply With QuoteReply With Quote
Old 03-18-2020, 08:11 PM #19
No plan to install grille marker lights right now, but if I did I would go tiny single LEDs and a dark tint to make it dark and discreet. 3 markers only. But I don’t see it as a priority right now. My GOBI rack is due to arrive tomorrow, and I added rock sliders the other day. It’s not expensive to add the marker lights, but I haven’t gotten around to my electrical projects yet.
Old 07-03-2020, 02:21 AM #20
ElDiabloTx ElDiabloTx is offline
ElDiabloTx is on a distinguished road
I actually installed in mt 2020 TRDP and they are really bright, so bright they could be used as DRL's now that I can actually turn my DRL's off it will look so much better. Only problem is that on the 2020 the fuse box is completely different from previous years and the lid will not close all the way. I'm using the INJ location though I wonder if there is a different location/fuse to use so that I can close the lid. I thought of even using a tape to keep dust and debris out of the fuse box.
Sent from my SM-N975U using Tapatalk
ElDiabloTx is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 10:51 AM #21
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
I prefer the look of the side ambers in daylight or early evening. DRL is safer, but if I was mostly interested in safety I wouldn’t have purchased a 4Runner.
Maybe you are not old enough to remember (looks like Whippersnapper02 is) , but these lights used to be called PARKING lights for a reason. I have seen clowns around here turn on their parking lights in the evening, then forget to turn on headlights when it gets dark and continue to drive. I respect that you prefer the look of amber lights, but in the evening or early morning, I prefer the look of headlights.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 12:06 PM #22
j485_ j485_ is offline
j485_ is on a distinguished road
Yeah there’s a lot of options. See the head unit owners manual here: https://www.toyota.com/t3Portal/docu...f/OM35B57U.pdf
Specifically page 18:
Thanks for sharing. First thing I turned off when I got my ORP.
j485_ is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 12:30 PM #23
Those fools don’t forget to turn on their headlights, they know exactly what they’re doing.
Old 07-03-2020, 01:01 PM #24
TOYO74's Avatar
TOYO74's Avatar
Yeah, I believe you are correct! We also have those that drive here at night with NO lights, hoping someone will flash their lights at them...not a good idea.
Old 09-22-2020, 12:55 PM #25
nmoeder nmoeder is offline
Real Name: Nate
nmoeder is on a distinguished road
Real Name: Nate
I have a 2020 TRD Pro with the Auto headlights. Turning them off in the head unit also turns off the parking lights in Auto mode. Does anyone know how to leave it on Auto, but make it so just the amber/parking lights are on? Seems like the DRT and parking lights are tied together via the head unit setting.
IG - @ROCKOWT
nmoeder is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 07:04 PM #26
4runneroffroad2020 4runneroffroad2020 is offline
4runneroffroad2020 is on a distinguished road
Canadian 2020 owner here.... i went to that screen and that option specifically is not available On my 2020. Even in the manual it says not available in Canada. How else can one go about doing this, since the fuse box is different compared to years passes as well.
4runneroffroad2020 is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 01:34 PM #27
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
That's no doubt because DRLs are mandated by law in Canada; that's not the case in the US so it's an option.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 09:38 PM #28
mrmike7189's Avatar
mrmike7189 mrmike7189 is offline
Real Name: mike
mrmike7189 is on a distinguished road
mrmike7189's Avatar
Real Name: mike
never thought much about DRL's
My 4runner is a lot safer than any other vehicle I've owned. It has 8 airbags, (more than other SUV's )plus the TSS .
As for DRL's......they are not required in my state, I rarely use them, leave the switch off.
mrmike7189 is offline   Reply With QuoteReply With Quote
Old 11-21-2020, 01:26 AM #29
I know there is a method to disable the DRL in pre-2020 models documented in this forum. It involves modifying a wire connector and looks pretty simple. Good luck!
Old 11-21-2020, 09:23 PM #30
Saker's Avatar
Saker Saker is offline
Saker's Avatar
You may have to bend pin 2 in the DRL relay to achieve this.
DRL Disable but keep Auto Headlights
Best Regards,
Saker
access , drl , lights , position , vehicle
2020 TRD PRO or 2020 GX460.... What do?!?! spc54 5th gen T4Rs 35 08-13-2019 08:58 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
Anyone running Bilstein 5100 on higher setting? YellowSnow 5th gen T4Rs 20 02-06-2019 08:52 AM
5100 top setting vs. stock setting with spacer RioRunner 5th gen T4Rs 9 09-10-2016 07:09 PM
heater motor only running on low setting Sidney Classic T4Rs 0 01-26-2008 08:19 PM
