12-16-2015, 12:37 AM
Christmas lights/rear power outlet
So I strung some Christmas lights around my Camelback roof rack and was all excited until I put the car in drive and the rear outlet turned off. Is there a way around this issue?
2013 LTD 4x4 Magnetic Gray; Weathertech liners, Airlift1000, Camelback Metal Gear roof rack, Interior LEDs, trail rocker panels, Shrockworks step sliders, TRD Pro wheels, Cooper Discoverer AT3s 255/75R17
12-16-2015, 01:13 AM
Yes, remove the Christmas lights.
Or you could buy these...
http://www.amazon.com/Wide-Angle-Mul...ristmas+lights
12-16-2015, 01:38 AM
Real Name: BobH
Real Name: BobH
The 120v outlets are limited to 100 watts when in gear. 400 watts in park or neutral. Leds solve this.
12-16-2015, 11:21 AM
Real Name: a
Real Name: a
christmas lites
thanks for the info, my 2016 4 runner had no problem with the christmas lites, but the led swap is a good idea.
12-16-2015, 01:06 PM
I use two strands of LEDs and have been since I bought my 4Runner. No issues and all I have to do is make sure my wife doesn't add more strands than the watt can handle
12-16-2015, 05:51 PM
Haha
Watt is love...baby don't hertz me...don't hertz me..no more
12-17-2015, 05:22 PM
Real Name: Tom
Real Name: Tom
Originally Posted by wfo9
I bought basically the same lights from Loews.
I have two strands and haven't had any issues. Love having the on/off switch already stock. They're pretty bright at night too.
_ 2014 Toyota 4Runner SR5 Premium 4WD _ Build & Adventure Thread
12-17-2015, 10:57 PM
Real Name: Paul
Real Name: Paul
So is the read window a crack open for the cord?
2010 Shoreline Blue LE / Navigation / Remote Start / 3rd row / fiamm horn / Color matched door edge guards / NAV BYPASS
12-18-2015, 04:00 AM
Shotgun Shell Lights
Went redneck on mine.
H&K, When Negotiations Fail
molṑn labé
12-18-2015, 11:01 AM
I did LED out the sunroof last year.
I found out the plastic covering on the lights could scratch the paint, so I put a piece of cardboard near where I was working.
It was sort of a PITA I would knock into the cord. It went from the rear center of the sunroof down to the console.
Curious how you run power out the back. I was worried I would pinch the cord. If the window is even the bit cracked the rear defogger wont go on.
12-18-2015, 11:12 AM
Yota X-mas Lights
Another Lowes Light Purchase with no power problems
So let it be written, so let it be done.
2016 Toyota 4Runner SR5
12-18-2015, 11:21 AM
Real Name: Pete
Real Name: Pete
As others have stated, buy a string of solar powered LED lights! Once you charge it up, string it wherever desired, the sun will re-charge and as the sky darkens, voila...Christmas Lights!
For example, I shot this 5:45am (45 minutes before morning twilight). This was shot at Sprague Lake in Rocky Mountain National Park. Nearest power outlet would be my 4Runner about 300 yards away (at best).
USKTog (aka Pete)
www.uskestrel.com
2014 TEP with KDSS, SunTek CarbonXP tint, WeatherTech Dark Smoke vent visors, FN f(x) Pro 17 x 8 (Matte Bronze), Cooper AT/3's [stock size]
12-19-2015, 12:01 PM
Real Name: Tom
Real Name: Tom
Nope .. ran out in between the weather stripping (be careful opening and closing the rear door because of it though) and up and out in between the backdoor and the exterior body. There is a little gap in between the door and the car to allow it to float in between and out.
Hope that all makes sense, ha.
12-19-2015, 06:15 PM
Real Name: Lou
Real Name: Lou
2011 T4R TE "Jemima"
JEMIMA BUILD THREAD
12-19-2015, 08:47 PM
Real Name: CJ
Real Name: CJ
I haven't had time to do it this year, but here is last years getup.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
