Old 10-11-2019, 03:23 PM #16
trd6209 trd6209 is offline
trd6209 is on a distinguished road
Originally Posted by DenverTiger504 View Post
I’ve been limited on time recently and excuse me if we covered this but I believe the height/lift clip settings are different as per bilsteins website instructions for the 600 vs 650 coil setup. Might be worth glancing at.
I’ve test driven a rig with a 600lbs coil slightly preloaded with a spacer and a C4 bumper with winch and it drove soft but okay IMO - maybe something else to consider.
I saw that the HD springs when purchased as a standalone item note that theyse springs will increase height by .5 inches. On the B8 6112 kit it says 2.6 for non-KDSS so I am guessing that's somewhere around 3.2 or so. Maybe actually a little taller for my application.
Sent from my Pixel 3 XL using Tapatalk
trd6209 is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 05:03 PM #17
Guru6022 Guru6022 is offline
Guru6022 is on a distinguished road
I have the 6112 with the 650lb bilstein coils on the 4th setting with 10k winch and c4 fab winch bumper and there is more than 2" of lift. I havent driven the truck yet so i dont know if it will settle down. when i put the winch and bumper on, the front height hardly changed. I was told that the 650lb coils would not increase height, but the instructions mention additional 0.5". BUT, they dont say additional 0.5" loaded with the extra accessory weight or unloaded. Bilstein would not clarify, and this was talking with one of their mechanics.
Guru6022 is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 08:09 PM #18
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
I have 6112s with HD springs on the 6th setting (KDSS). I also have about 150lbs upfront and I'm sitting at ~3" upfront. I am actually a little higher than when I had the 600lbs springs on the 7th setting with no weight up front. Just some food for thought...
blksubykid is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 11:40 PM #19
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
What are your hub to fender numbers?
Nothing wrong running this setup until you get your bumper setup, it will drop .3 to .5" easily when everything settles. Do you think your rear 5100 will ride ok going up another inch?
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 10-12-2019, 10:19 AM #20
Maybe my logic is flawed, but if people run stock with 2 inch coil spacers I would think running 2 inch lift shocks with a 3 inch coil spring setup (2 inch 8con spring + 1 inch spacer) would be less detrimental to performance. If I did see an issue I think it would be at extremes of travel. If I do opt for for leaving the front alone I will add the 1 inch spacers for leveling and once I add the winch bumper up front I can remove the spacers if I don't like the rake.
I don't have my hub to fender numbers handy. I am currently out of town until Thursday. I will post them when I get back.
back , daystar , front , icon , springs
Can't decide. Bilstein 5100s w/ Eibach Pro lift springs or 6112s TimeZone 3rd gen T4Rs 1 08-07-2018 06:18 AM
FS: Icon 2 inch Rear Lift Springs - Denver - $175 Spudgey For Sale: Suspension/Wheels/Tires 16 05-15-2018 12:48 PM
FJ Springs with Billstein 5100s. Data? simple 4th Gen T4Rs 9 12-20-2017 08:48 PM
Is anyone running ICON UCAs w/ ICON RR COs?? A.Wilson013 3rd gen T4Rs 17 10-26-2015 08:35 PM
