Old 10-06-2019, 12:31 AM #1
daesonn daesonn is offline
daesonn is on a distinguished road
Spongy brakes after rotor/pad change
Hey guys, I recently decided to do a total brake pad change and rotor swap up front after I was experiencing some warped rotor issues. Since the swap, my vibratory issues have dissipated however my brakes feel sort of spongy. Sometimes my truck seems to get away from me that last few feet, if you know what I mean. I've put several thousand miles on the truck now since the change. The brake fluid looked clear in the reservoir when I did the swap and was limited on time so I figured I would be safe not bleeding the brakes.
Do you think this is just a simple matter of air in the brake lines? I've never had air enter the brake lines on a brake pad and rotor swap on previous vehicles....
Thanks
daesonn is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 01:13 AM #2
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Assuming you have a 5th Gen 4R.
The following is from a Tacoma site, but specific models of that vehicle use the same electric master cyl setup that 5th Gen 4Rs use.
In the thread below, the poster talks about using speed bleeders. You do not need to do that. What's important to know is that Toyota was kind enough to provide an auto-bleeder function for the rear brakes. The fronts are bled using the old 2 man method.
DIY, Brake fluid flush, 4x4 - TRD Off-Road with Speed Bleeders | Tacoma World
You can find similar info here at this site using the SEARCH function.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 09:01 AM #3
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I did my rotors a while back without bleeding the brakes and had no issues. Not sure how you would get air in the lines if you didn't bleed. The only sponginess would be the first time or two you press the pedal after forcing the caliper pistons in to accommodate new pads. My money is on something else, low fluid, or something not mechanically correct in the install. Did you use OEM parts or upgrade to something else?
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 10:57 AM #4
btcsxj btcsxj is offline
btcsxj will become famous soon enough btcsxj will become famous soon enough
what process did you follow for bedding your new brakes?
Super White 2016 4Runner Trail Edition
btcsxj is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 01:02 PM #5
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Time to do all 4, the rear is easy, front is old school or I used a Motiv vacuum tank for Mine. I used DOT 4 fluid and emptied most from the master cylinder first. Got out all the older fluid first.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 10:22 PM #6
I used some how-to I found. I don't remember exactly but I was pretty confident in my work. I also greased every God damn metal-on-metal surface and still ended up with a damn squeal. I have no idea how I ended up with air in the brake like but I definitely did. Noticed air bubbles in front left side during and brakes feel much better now. Problem solved.
Old 11-14-2019, 07:09 PM #7
N6WRV N6WRV is offline
N6WRV is on a distinguished road
Be aware that brake fluid is hydroscopic. Namely, it attracts water. Since brake fluid is lighter than water, water and dirt in the brake system will tend to accumulate in the wheel cylinders. Brake bleeding will clean the bad stuff out.
2015 4Runner Limited with X-REAS Sport Enhancement Suspension, 37qt ARB fridge wired directly to battery with ARB Wiring Kit.
N6WRV is offline   Reply With QuoteReply With Quote
brake , brakes , change , rotor , swap
2012 4Runner Spongy Brakes mikeinmass 5th gen T4Rs 41 02-16-2020 06:35 PM
Brakes extremely spongy after going offroad t-man 4th Gen T4Rs 31 09-07-2014 07:13 PM
Change Front Brakes, pad & rotor suggestion! AE1M 4th Gen T4Rs 0 08-13-2012 01:12 PM
noise front pads along with spongy brakes latreto 4th Gen T4Rs 0 11-24-2008 11:01 AM
Spongy brakes on 89 runner killasoundz Classic T4Rs 5 01-16-2008 08:32 PM
