Old 08-20-2020, 11:03 PM #16
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
Originally Posted by usdmej View Post
it seems like the SQ community prefers the modularity of a standalone sound processing unit, if anything it looks like the industry is trending towards baking that into amps instead of head units
the basics remain the same irrespective of the application... that is CAR vs HomeTheater vs Music listening setup at home. first is the source and the uncompressed information it carries that can be converted and amplified to be played back in a system. Then comes the conversion (in this days mostly digital) of the source signal into analog signal that can be amplified. Then comes the EQ/Config/or-what-ever you call it that allows to achieve optimal listening experience by calibrating/configuring the system depending on the area/dimensions/placement/distance/or-many-other-parameters where the system is installed/hosted. ones' taste drives it all... that is how crazy one becomes to get the most value and satisfication from what they have
niadh0 is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 11:04 PM #17
you are so right man. i also wonder the same but haven't really know of any consumer grade setup that comes with such a self-service type calibrator.
I am using a Marantz AV8802A processor at home and it does a phenomenal job at learning and automatically applying the corrections needed for my HT.
Originally Posted by 1jzgte View Post
i might be behind the times with car audio but has any car audio company come up w/ a Auddsey type or YPAO type of microphone calibration for car audio?
If home theater receivers are able to self calibrate these days why not car audio receivers?
Old 08-20-2020, 11:13 PM #18
I never had any sound deadening material applied when i was using the OEMAudio+... never thought about it, and yet it sounded so good when i was playing hi-res via an external DAC via AUX in my 2019.
but this time, I spent two days in just applying the Noico mats in the door panels etc ... just so i have no regrets later. one thing for sure is that the doors (when I knock on them lol) sound solid. the quality of the door metal feels like my old 99-LTD 3rd Gen - Solid . most car audio installers online recommended putting the mats around the speakers at least and also put Fast-rings so that no sound can escape from the speakers.... so I did that.
will know how good it it once everything is done.
Originally Posted by GuySmiley View Post
... Can you take advantage of high quality audio components in a 4Runner without gutting the interior and putting in a layer or two of sound absorption material?
Old 08-20-2020, 11:35 PM #19
shdw03 shdw03 is offline
shdw03 will become famous soon enough shdw03 will become famous soon enough
Nor sure where you could mount that. Only thing that comes to mind is the center console? Depending if you have a 4wd. If you don't, next to the gear selector there is a ton of room. A vertical mount?
on a different note, why wouldn't you rather go dsp route? Helix sells modules you can add to HI-res aux in to the dsp.2 and dsp.3. Think minidsp takes an aux/toslink and spdif. They can both integrate with the factory system as well
shdw03 is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 11:43 PM #20
thx. mine is an OffRoad edition so unfortunately the centre bank is full if thats what you meant by putting vertical mount where the 4Hi-4Lo shifter is. Also thought about putting everything in the trunk but that is too much wires running (power cables as well as the speaker to/from the HU area). so i think i am stuck with the centre compartment.... which would not be a bad idea... at least i can easily operate if i need to.
Old 08-21-2020, 02:21 AM #21
Whippersnapper02's Avatar
Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light
Originally Posted by niadh0 View Post
BTW I am open for ideas for where to mount the AMPS and any alternative location besides the centre console compartment for the GS9.
Maybe an amp rack from Taco Tunes. I bought it to mount my amps and HAM but haven't used it yet.
I also need recommendation for the sub enclosure if anyone knows any make then let know - i need at least 0.9 cubic ft volume. so far i narrowed down to Sound Ordnance Bass Bunker Sealed single 12" subwoofer enclosure (Model BB12-95S) from Crutchfield. Thanks much
Taco Tunes also makes a 12" sub box but it's double the airspace you need. Maybe take some away with poly fill.
Old 08-21-2020, 10:53 PM #22
rc10mike rc10mike is offline
rc10mike is on a distinguished road
Im not sure of your system configuration, but if you are using passive crossovers with the mid and tweeter then you wont be able to properly align and EQ the drivers separately. This is only possible with an all active setup. Meaning each speaker has its own channel on the amp. Using passive crossovers severely limits actual tuning ability.
rc10mike is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 10:59 AM #23
great point and thanks for the input.
i am going with what Sony recommends from a components and connections point of view. Will be using passive cross overs however willing to draw two new wires just for the tweeters (killing the cross over module if its not optimal) to make a straight active connection. in comparison to the attached diagram, i will have identical setup for the front and the rear though. it will take me some trial-error to get everything optimally tuned. thx
Input Connections - Sony XM-GS4 Operating Instructions Manual [Page 6] | ManualsLib
@Audiophiles - Sony HI-Res RSX-GS9 in a 4R-capture-jpg
Old 10-18-2020, 01:45 PM #24
Parts list....
(01) Sony RSX-GS9 Hi-Res Media Receiver Retail $2000 x Qty 1
(02) Sony XM-GS100 Sub Amp Retail $329 x Qty 1
(03) Sony XM-GS4 4 Ch Amp Retail $329 x Qty 1
(04) Sony XS-GS1621C Front and Hatch Spkr Retail $350 x Qty 2
(05) Sony XS-GS1621 Middle Spkr Retail $279 x Qty 1
(06) Sony XS-GSW121D Subwoofer Retail $169 x Qty 1
(07) For 2020, Metra 70-1765 to connect Amplified speakers back to Factory Speaker Harness
(08) For 2020, Metra 71-1765 to connect to Factory HU Speaker Out to Sony RSX-GS9
(09) any type of 12inch Subwoofer enclosure you like
(10) wires fuses etc etc
(11) other sound dead Ning material was f your choice. I used Noico 80mil for all doors
(12) Roadkill Fast rings for all speakers
(13) Metra 72-8104 Qty 6 for connecting speakers
(14) Scosche SAT6 Speakers mounting brackets Qty 2 sets
(15) Metra 82-8147 Speakers mounting brackets Qty 1 set
(16) Toyota Factory Dash tweeter adapter (eBay) For 2010+ Toyota 4Runner Tweeter Dash/Front Speaker Harness Adapter Cable (Pair) | eBay
(17) ….I may have missed some small parts so I will list in the subsequent posts.
@Audiophiles - Sony HI-Res RSX-GS9 in a 4R-01-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-02-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-03-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-04-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-05-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-06-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-07-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-08-jpg
Old 10-18-2020, 01:47 PM #25
and some more pics... 2
@Audiophiles - Sony HI-Res RSX-GS9 in a 4R-09-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-10-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-11-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-12-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-13-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-14-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-15-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-16-jpg
Old 10-18-2020, 01:49 PM #26
some more pics 3
@Audiophiles - Sony HI-Res RSX-GS9 in a 4R-17-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-18-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-20-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-21-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-22-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-23-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-24-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-25-jpg
Old 10-18-2020, 01:52 PM #27
some more pics 4
have some more pics but tired of converting them into smaller size.. lol
will try to answer any questions.
thee series of posts are covering the install only....
i will post separately on the sound quality review... first impression is just wow.... far better than my expectations.
@Audiophiles - Sony HI-Res RSX-GS9 in a 4R-26-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-27-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-28-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-29-jpg  @Audiophiles - Sony HI-Res RSX-GS9 in a 4R-30-jpg
Old 10-19-2020, 09:58 PM #28
Originally Posted by Jernik View Post
A true audiophile wouldn't consider me one, but I do appreciate good, powerful, clean sound. I just can't justify the spend on the really good stuff. That said, I hope the system performs to your expectation. Do give us an update when it's up and running!
its done. uploaded some pics for reference. will post back on the quality review after playing around with some source files (varying sound quality).
I have all the gear needed for doing a proper REW tuning so it will take me a day to tune it all
REW - Room EQ Wizard Room Acoustics Software
Old 10-20-2020, 12:30 PM #29
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
So uhhh, yeah, your project is a little beyond what I have in mind for upgrading my stock system next year but if you work at a car audio shop in Toronto I'd appreciate a PM on where that is as I'd rather employ someone like yourself to be peeling back my interior with this kind of expertise & familiarity than some dude who is rocking a Civic out back with the entire hatch crafted out in subs, plexiglass and LED. Not that it doesn't take skill to do that either but I'm sure you understand what I mean. Cheers...
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 04:19 PM #30
i wish i had knew of a good shop near by that would take care of this properly but I don't; however checkout Audio Heaven, I did hear good reviews about them - speak to Jeff. they did tint on three of my 4Runners. anyways, I do architecture for living and this car thing and HTs are just hobbies.
factory , hi-res , mount , sony , unit
Audiophiles Question for you... bigjebus 4th Gen T4Rs 17 12-13-2015 12:45 PM
Speaker advice from audiophiles Illestreker 3rd gen T4Rs 25 05-22-2014 11:34 PM
Car stereo question for you audiophiles... yakobo75 3rd gen T4Rs 15 09-19-2013 10:46 PM
Calling all Audiophiles!! Lizardking Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-10-2005 01:47 AM
question for audiophiles... TranceKrayz Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-25-2004 07:40 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
