10-06-2019, 08:38 PM
Real Name: Wes
Real Name: Wes
OME Trim Packers, worthless.
I recently installed a ICON stage 2 and of course started to experience some driver side lean. A whole inch of it to be exact. Right side measures at 24.5”, left 23.5. Ordered some OME Trim Packers to compensate for the lean, seems all it did was compress the spring even more, now it’s just tucked up in the wheel well with a slight camber (So now I get to spend another hour removing suspension to remove the packers) I’m considering 700lb springs, so I’m curious if those of you with 700lb springs still experience lean? I don’t have any aftermarket bumpers or a spare weighing it down, also only on a 1/4 tank of gas. I will eventually but not any time soon upgrade bumpers so the springs will eventually be necessary.
Reason: Spellcheck
10-06-2019, 09:23 PM
It’s not the trim packer. These rigs aren’t level no matter what sometimes. Mine had the lean and we adjusted it a full inch higher in the front on the drivers side yet I still had a lean. I am running two rear trim packers now on the drivers side yet still have a little lean. I gave up haha
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
10-06-2019, 09:30 PM
Real Name: Wes
Real Name: Wes
I guess what I meant to say is, I started off with 23.5” drivers side, 24.5” passenger.
Installed 2 trim packers on the drivers side, which seemed to make a half inch difference instantly but once it settled over night, it’s back to 23.5” and the tire now has a camber to it. The coil does look slightly more compressed than the other side.
10-06-2019, 09:35 PM
Why not just adjust the preload instead of adding trims?
I feel like you're going to have a super rough ride with the 700s, assuming you have no extra weight in the front. I have them on mine with about 250lbs up front and it's just about perfect.
YouTube
10-06-2019, 09:52 PM
Real Name: Wes
Real Name: Wes
Preload up front is maxed out at the recommended 2.13” on both sides. Both sides measure the same up front, and the passenger rear. The drivers rear is my only issue. If 700s would get me level, I’d be ok having a rough ride as I’m sure this can’t be good for tire wear. Besides, it’d give me a reason to upgrade bumpers sooner rather than later.
10-06-2019, 11:47 PM
back off the preload on the high side
10-07-2019, 09:06 AM
Real Name: Wes
Real Name: Wes
The front is level though...
10-07-2019, 10:08 AM
Interested to see what your CV boots look like with 4 inches of lift (23.5 center hub to lower fender).
10-07-2019, 11:05 AM
I have them on mine. They helped a little - got me within 3/4".
I adjusted preload as well to help... got it with in 1/4" then said F it. Like someone said its almost impossible to be perfect. My preload is close to 3/4" difference side to side.
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
10-07-2019, 11:09 AM
That likely also includes tires....
10-07-2019, 12:05 PM
Real Name: Wes
Real Name: Wes
I’m gonna have to play with that a little bit. I’d be content if it was within 1/4” but a whole inch is just ridiculous.
10-07-2019, 12:09 PM
Real Name: Wes
Real Name: Wes
I really don’t want to get off topic but like I said I do have the preload maxed out, which has me at 24.5” all around except the drivers rear obviously. I’m aware that’s a little excessive but I haven’t read anywhere what the actual “safe limit” is. So if I lower the preload in the front, then I’m gonna have rake, which I don’t want. But I guess it’s just gonna be a day of adjusting till I get it close. I’m still curious to know if people still have lean with 700lb springs.
I’m successfully running 285/75/17 with BMC and some minor trimming.
10-07-2019, 12:35 PM
I cant say for certain as I dont have them. My guess is yes you still will based on theory (guessing the springs are cut the same length and are not side dependent - whereas items like cornfed spacers are side dependent to help account for lean). You could look at dobs springs too (people like them here).
I think small rake is OK... full tank of gas, and if you add a dog or gear in the rear end - it falls pretty quick back there (then your shooting headlights in the sky and IMO reverse rake (towards the back) looks way worse then rake towards the front) but each his own.
To the tire comment. HUB to fender excludes the tire there brochacho. I can only give people top of rim to fender due to the "dish" of my wheels I cant locate center really well (just add 1/2 wheel dimension).
Think of it like:
10-07-2019, 03:34 PM
Icon coil overs maxed at 2.13 like the OP has very well might result in angry CV boots. Just because Icon states the max on their COs, it doesn't mean that it is healthy height for our IFS rigs.
10-07-2019, 03:47 PM
My guess is you're having a problem because you're trying to set too much lift resulting in the frame twisting under the forces and the body will never get to where you want unless you change the control arms in the rear. It's possible you have a rear spring out of position or something. But 24.5" is higher than what you can normally run. That would be close to 5 inches up front. I'm guessing you're at the full extension of the front shocks already.
FWIW - the 285/75/17's will fit at any ride height with the same trimming unless you never intend to hit bumps. I have 285/75/17's and currently set around 21" front. So if you're trying to max the lift for tire size - you can adjust down a bit. If you shoot for something more like 22.5" it'll probably work and also ride a lot nicer. Or it might be time to consider a bracket lift or long travel front setup for more height.
good luck
